Quoting Web500sjc : They just found a flapaeron that has been sitting in the ocean for 1.5 years, how can you guys infer anything about an airplane crash? |
Quoting jpetekyxmd80 (Reply 3): Look how beat up the ailerons got on US1549. In a lot of ways the flaperon is in pretty remarkable condition. |
Quoting TheRedBaron (Reply 4): |
Quoting seahawk (Reply 6): But this one was in full down position when it hit the water. If the other was in up position it suffered much less direct impact. |
Quoting Nouflyer (Reply 8): If this disappearance was a nefarious act pretty much anywhere from central Asia to the Indian Ocean, the perpetrators - if it was not the crew - have had ample opportunity to plant what they want where they want. |
Quoting jpetekyxmd80 (Reply 10): So they wanted to steal a 777 but still haven't used it? |
Quoting seahawk (Reply 6): But this one was in full down position when it hit the water |
Quoting 77west (Reply 13): This thread now being referenced by the media: http://www.telegraph.co.uk/news/worl....html |
Quoting WingedMigrator (Reply 15): Nonsense. You're looking at a control surface torn off a wing. All it proves is that the plane hit the water. You can make no reasonable inference about its position. A metallurgist might, after looking at fracture surfaces very closely, but not you. You probably think the plane was ditched intact, and confirmation bias kicked in. |
Quoting SpinalTap (Reply 16): Also interesting in the Telegraph's news blog was the debris/current map |
Quoting 77west (Reply 13): Not surprisingly the aviation forums have been abuzz with informed speculation. |
Quoting morhas (Reply 20): Why the colour of flaperon not in Gray as the colour of MH370? My naked eye see it as white colour. |
Quoting COOEE (Reply 22): Could this debris (flapper) be part of a Boeing 767-200ER, as in the 1996 ditching of Hijacked Ethiopian Airlines Flight 961 of Grande Comore - this island is on the other side of Madagascar - one media report noted barnacles? Does that not suggest a longer time afloat. |
Quoting theaviator380 (Reply 26): Not being funny, but apart from aircraft landed/crashed in the ocean..what else information single Flaperon can give us? |
Quoting jpetekyxmd80 (Reply 1): The nature of the damage to the piece could hold a fair amount of clues to the planes position when it impacted the water, which could be very critical. |
Quoting thunderboltdrgn (Reply 29): According to the Guardian, local journalists at Reunion says that badly damaged suitcases have been found very close to where the aircraft debris was found: |
Quoting scarebus03 (Reply 31): in a previous post on the first thread I alluded that the number mentioned as BB670 sounded like an Airbus access panel when in fact reversed as 670BB it is most likely the flaperon of a B777-200/300. Subzone 670 corresponds to the r/h wing, specifically flap fairings. I'm sure it will be confirmed shortly by an expert. |
Quote: So, it seems to me that this makes the Southbound turn VERY unlikely and rekindles the theory that the plane was heading toward at least generally toward Diego Garcia. Anybody want to tackle either of those? Also, all the Inmarsat data would be false, would it not? |
Quoting Nouflyer (Reply 12): it has been obvious from the start that a number of major powers know precisely what happened but have elected not to reveal that information |
Quote: Vast, rotating currents sweeping the southern Indian Ocean could have deposited wreckage from a missing Malaysia Airlines passenger jet near Africa, thousands of kilometres from where it is thought to have crashed, oceanographers said on Thursday. |
Quote: Malaysia is "almost certain" that plane debris found on Reunion Island in the Indian Ocean is from a Boeing 777, the deputy transport minister said on Thursday, heightening the possibility it could be wreckage from missing Flight MH370. |
Quoting MadameConcorde (Reply 36): I am with you on this 100% They know. |
Quoting Byrdluvs747 (Reply 38): Its been 20+ hours now. Shouldn't there have been contact between Boeing and Reunion officials to locate specific S/N numbers to verify the identity of the aircraft this piece came from? |
Quoting Byrdluvs747 (Reply 38): |
Quoting photchan (Reply 30): |
Quoting jpetekyxmd80 (Reply 39): It will likely need to be dissected to find them, which im sure they haven't done yet. |
Quote: BREAKING 657-BB code found on wreckage is Boeing 777 flaperon according to manual |
Quoting theaviator380 (Reply 26): It will be great relief for all those relatives, friends n families gone through the tough times...(if this proved to be MH370 part). |
Quoting Byrdluvs747 (Reply 38): Its been 20+ hours now. Shouldn't there have been contact between Boeing and Reunion officials to locate specific S/N numbers to verify the identity of the aircraft this piece came from? ** Sorry if this has been answered in the previous thread. |
Quoting jpetekyxmd80 (Reply 32): I don't believe any of this suitcase stuff. Highly unlikely they drifted the same as the flaperon. |
Quoting seahawk (Reply 17): The US Airways flight ditched intact with flaps down and they seem to have held up pretty okay. The flaperon could have been up and survived a way stronger crash in that position. |
Quoting JoeCanuck (Reply 47): I think a more likely result of a ditching in the ocean would be Ethiopian 961. It came pretty close to being a controlled ditching but the plane ended up cartwheeling and breaking into pieces. |
