Please check out the linked article.
http://www.flightglobal.com/news/art...ot-performance-assumptions-415293/
[Edited 2015-08-02 22:13:46]
Quote: 777-8X ..... 8,700nm ..... 9,390nm |
Quote: 777-300ER ..... 7,370nm ..... 7,850nm |
Quote: 777-9X ..... 7,600nm ..... 8,200nm 747-8 ..... 7,730nm ..... 7,790nm |
Quoting Prost (Reply 2): |
Quoting WALY777 (Reply 4): Airbus using a similar methodology would see a similar drop in max ranges |
Quoting Prost (Reply 2): So are These numbers more closely aligned with methodology that Airbus uses? |
Quoting tommy1808 (Reply 5): What do you mean with "would"? Airbus is using realistic assumptions for a long time, otherwise they would state the A338neo range with 8200m, and the A339neo with 7000nm instead of the numbers they use. Since that 750-800nm difference is bigger than what Boeing now shows, Airbus might use even more realistic assumptions. |
Quoting KarelXWB (Reply 10): However, these new range numbers are still not the same as airline configurations. For example, they don't take revenue cargo into account. |
Quoting tommy1808 (Reply 11): On the other hand, brochure range is pretty irrelevant once the payload/range charts are public, and in that regard Boeing always was a model citizen in giving ranges for OEW+Payload and not just for payload with an overly optimistic DOW. |
Quoting ap305 (Reply 13): A bit unrelated but for some reason Airbus is not publishing the payload range chart for the a350... |
Quoting tommy1808 (Reply 5): |
Quoting barney captain (Reply 7): MAX 7 now has less range than a MAX 8 ??? And the 8 and 9 now have the same range ?? NEW OLD 737 Max 7 126 126 3,350nm 3,850nm 737 Max 8 162 162 3,515nm 3,660nm 737 Max 9 178 180 3,515nm 3,630nm |
Quoting WALY777 (Reply 15): The methodology doesn't include just seat config. |
Quoting ap305 (Reply 9): Many a Boeing devotee on this forum who were using the realistic Airbus figures as a stick will now no doubt be very pleased... ![]() |
Quoting Stitch (Reply 18): It was the Airbus Aficionados who (with just cause) were consistently criticizing Boeing using 1990's methodologies for their brochure figures. So it is they who should now be pleased Boeing has updated them to more accurately reflect current seating configurations. |
Quoting ap305 (Reply 19): The supposedly lacking range on the a350 as compared to the 787 was used many a time by the Boeing lot |
Quoting ap305 (Reply 19): It is the guarantees,nominals and the space between these figures which count for an airline... and this is something which 99.9% of us have no access to. |
Quoting KarelXWB (Reply 10): Quoting tommy1808 (Reply 5): What do you mean with "would"? Airbus is using realistic assumptions for a long time, otherwise they would state the A338neo range with 8200m, and the A339neo with 7000nm instead of the numbers they use. Since that 750-800nm difference is bigger than what Boeing now shows, Airbus might use even more realistic assumptions. Airbus adjusted its performance numbers years ago as it introduced more realistic cabin configurations. However, these new range numbers are still not the same as airline configurations. For example, they don't take revenue cargo into account. |
Quoting par13del (Reply 23): How does this affect the contractual terms Boeing used when selling their a/c, do carriers now have a claim for a/c not meeting specs? |
Quoting par13del (Reply 23): If not, this whole thing is...........???? |
Quoting Stitch (Reply 26): Quoting par13del (Reply 23): How does this affect the contractual terms Boeing used when selling their a/c, do carriers now have a claim for a/c not meeting specs? No, because the sales contracts would not be using brochure or OEM figures for operating weights as the basis for those guarantees. They're irrelevant in that regard. Quoting par13del (Reply 23): If not, this whole thing is...........???? To end the a.net debates about how Boeing uses out-dated seat counts. |
Quoting N62NA (Reply 25): What is a "737 Max 200200" ???? |
Quoting tommy1808 (Reply 11): brochure range is pretty irrelevant once the payload/range charts are public |
Quoting Planesmart (Reply 27): You have summed it up brilliantly. The disclosures will not come as news to the US3, ME3, EU3, or Airbus, only to a.net and uninformed aviation media/industry experts. |
Quoting Wingtips56 (Reply 28): I'm thinking it is the high capacity machine Ryanair is looking at with 200 seats.. is it's nickname the "Max 200" indicating that capacity? Then I think the 200200 is just the 200 from the title running into the 200 in the seat column without room for a space as posted. I.e. 737 Max 200 (space) 200 (seat column). |
Quoting Ruscoe (Reply 21): Also it is Boeing not Airbus who have changed the typical range numbers, so Airbus numbers have not changed., and yes, the lack of superiority of the 359 between 20T and 50T payload is still a surprise considering its extra MTOW and higher thrust engines. |
Quoting tommy1808 (Reply 11): On the other hand, brochure range is pretty irrelevant once the payload/range charts are public, |
Quoting Ruscoe (Reply 21): Also it is Boeing not Airbus who have changed the typical range numbers, so Airbus numbers have not changed |
Quoting Viscount724 (Reply 24): They also don't consider winds, elevation, and high temperatures so you still to reduce the quoted ranges by roughly 10% to get realistic numbers. |
Quoting enilria (Reply 17): |
Quoting WALY777 (Reply 15): I believe karelxwb once put up a an airbus presentation to an eu airline for the 339 and 359 showing expected max range for that airline. |
Quoting KarelXWB (Reply 39): |
Quoting WALY777 (Reply 4): It's very close to real airline operating ranges. It's often underestimated just how much the real airline dow has on the max range of aircraft, especially the newer gen aircraft where each additional 1ton reduces range farther than previous generations. Airbus using a similar methodology would see a similar drop in max ranges. We certainly know this from presentations using our configs for our network. |
Quoting JetBuddy (Reply 41): There should be an industry standard for range figures. Like MTOW range minus the suggested 10% for winds, routing and so on. |
Quoting Ruscoe (Reply 21): Also it is Boeing not Airbus who have changed the typical range numbers, so Airbus numbers have not changed, and yes, the lack of superiority of the 359 between 20T and 50T payload is still a surprise considering its extra MTOW and higher thrust engines. |
Quoting ap305 (Reply 35): You are reaching this conclusion without looking at the a350 payload/range chart which is not yet public? |
Quoting JetBuddy (Reply 41): Still not real numbers, just look at Boeing vs Lufthansa 747-8i numbers. And Airbus has been using the closer to reality calculations for a very long time. |
Quoting JetBuddy (Reply 41): |
Quoting WALY777 (Reply 45): "I believe the difference for LH 747-8 range would be the heavier than planned weight of the first few frames." |
Quoting Stitch (Reply 46): |
Quoting WALY777 (Reply 45): Did you conveniently ignore this part of my response? "I believe the difference for LH 747-8 range would be the heavier than planned weight of the first few frames." |
Quoting WALY777 (Reply 45): For the record, no airline or lessor takes Airbus's numbers about Boeing or Boeing's numbers about Airbus seriously. If you want to see the analysts sweat a little during such presentations, continuously quiz them on exactly what details where used in the numbers for the competitors. |
Quoting WALY777 (Reply 45): If you want a standard base for airbus or boeing, get them to crunch numbers using your specifications and you get a clear answer. The above are all brochure numbers...however the increase in pax and seat weights brings the ranges much closer to real operating ranges. There will still be variances....e.g our 3 and 2 class birds have significantly different payload/range abilities. |
