queb
First Boeing 737 MAX Fuselage Completed
Thu Aug 13, 2015 5:31 pm
ODwyerPW
RE: First Boeing 737 MAX Fuselage Completed
Thu Aug 13, 2015 5:47 pm
What are the significant differences between a 738NG fuselage and a 738MAX fuselage?
I know the MAX8-200 has different exits, but is the standard 738MAX fuselage all that different from the 738NG?
(I know the 7s are in fact different, with a plug combined with the rear section, but don't know what is specifically different in the 8 and 9).
learning never stops.
questions
Thu Aug 13, 2015 5:58 pm
Why has Boeing never redesigned the cramped nose/cockpit, especially since these aircraft are used in much longer missions than the original series? Would it changed the aerodynamics of the aircraft significantly?
Arniepie
Thu Aug 13, 2015 6:05 pm
Quoting questions (Reply 3):
My guess would be that they change as little as possible to keep commonality and certification.
[edit post]
litz
Thu Aug 13, 2015 7:00 pm
Now let's see if BNSF can get it to Boeing without dropping it in a river ...
hiflyeras
Thu Aug 13, 2015 7:40 pm
Sigh...wish it was about 12" wider. People aren't getting any smaller.
AM744
Thu Aug 13, 2015 9:05 pm
Quoting ODwyerPW (Reply 1):
There aren't many visible changes in the fuselage AFAIK . I don't think materials change either. (I'd love to know from someone knowledgeable if they do)
Major changes for the MAX will affect the wing and engines.
JAGflyer
Thu Aug 13, 2015 9:40 pm
Quoting AM744 (Reply 8):
No changes in materials? I thought they were going to Dreamlinerize this new "MAX" variant of the 737 by using composite materials. I'm still curious why they chose to use pneumatic starters vs. electric ones (on the GEnx).
If you flew today, thank a Flight Dispatcher!
KC135Hydraulics
Thu Aug 13, 2015 10:05 pm
Didn't they have to add a little bulge under the nose to accommodate taller landing gear? If you look closely, you can see a small bulge in the lower right hand side of the fuselage under the nose.
MSgt, USAF
KC-135R / C-17A Pneudraulic Systems Mechanic Supervisor
Natflyer
Thu Aug 13, 2015 10:13 pm
Wow! This looks like...another 737. (Yawn).
Ruscoe
Thu Aug 13, 2015 10:22 pm
Unless it has changed, the MAX has a completely new rear fuselage on all models, which is why the photo is disappointing because we cannot see that.
Ruscoe
bgm
Thu Aug 13, 2015 11:36 pm
Quoting HiflyerAS (Reply 7):
You mean like the A32X?
This is one seriously pimped out 737. Boeing definitely have gotten their money's worth out of this vintage design...
Boeing778X
Fri Aug 14, 2015 12:06 am
Quoting bgm (Reply 13):
I'm really eager for Boeing to move to the NSA/YA/797/737-X, but the 737 will always be my favorite type. Really excited for the MAX, and perhaps some of the progress made by it can be carried over to the next single aisle Boeing.
United Airlines: $#!ttin' On Everyone Since 1931
AA737-823
Fri Aug 14, 2015 12:09 am
Quoting KC135Hydraulics (Reply 10):
That feature, though added at one point, has since been engineered out.
Quoting Jagflyer (Reply 9):
Because an electric starter on anything larger than a PT-6A is a terrible idea. The only reason you go that route is out of necessity, a-la the fact that the 787 has no useful bleed system to start engines with. The pneumatic starter- in use for decades- has two moving parts: the on/off valve, and the spinny-real-fast thing. An electric starter has..... SOFTWARE. The nemesis to reliability.
AirPacific747
Fri Aug 14, 2015 12:34 am
Quoting queb (Thread starter):
Are you sure you didn't post a picture of an NG?
Ruscoe
Fri Aug 14, 2015 12:54 am
Quoting AirPacific747 (Reply 16):
You can see 5602 stamped on the fuselage, which according to Karadion's Post is the first one for South West.
Ruscoe
WROORD
Fri Aug 14, 2015 1:00 am
Exactly, and why do big people always take up my space just because I am thin? I pay for the whole seat and not the half.
KELPkid
Fri Aug 14, 2015 1:07 am
Quoting litz (Reply 6):
   However, I believe the train was actually on MRL (Montana Rail Link) trackage when the derailment happened...
AirPacific747
Fri Aug 14, 2015 2:05 am
Quoting Ruscoe (Reply 17):
It was a joke... but to the untrained eye, there's no difference what so ever.
NWAROOSTER
Fri Aug 14, 2015 3:01 am
Boeing can't make any significant or major changes on the 737 as the aircraft is grandfathered in.
I wonder how long the grandfather can survive??????
Procrastination Is The Theft Of Time.......
aerokiwi
Fri Aug 14, 2015 4:37 am
I'm interested to see how the aircraft's attitude looks on the ground with the new, taller landing gear.
The NGs had more of a nose-down attitude to the Classics, and looked the better for it. The MAXs, I suspect, will have similar lines to the Classics.
TWA772LR
Fri Aug 14, 2015 5:00 am
Quoting NWAROOSTER (Reply 21):
Well EIS of the MAX is about 2017, and the 100s EIS was in 1968. NG productions about 20 years old with a huge backlog, say 5 years max. So the MAX could see production until 2040. Throw in the secondhand market and the 737 series could very well see 100 years of service! A milestone that will probably only be matched by the B52 and maybe the C130 and TU95, and probably the DC-3 in remote parts of the world!
When wasn't America great?
hz747300
Fri Aug 14, 2015 5:14 am
Still 42k ceiling service, or did they bump it up to 45k? Can they make it a teensy bit wider too.
Keep on truckin'...
32andBelow
Fri Aug 14, 2015 5:19 am
Quoting TWA772LR (Reply 23):
I'm sure DL will still be adding DC-9s
hiflyeras
Fri Aug 14, 2015 5:36 am
Quoting hz747300 (Reply 24):
They won't make it any wider because then they wouldn't be able to ship the fuselages by rail from Wichita to Renton, WA. God forbid they built the MAX fuselage near the assembly plant and widened it to equal the Airbus narrow bodies. I thought this was a huge mistake on Boeing's part but sales have been good. Still, an opportunity lost.
I also felt they should have moved the L1 (forward left door) back a bit, in a similar configuration to the L2 door on the 757 but that was just my preference...would make for a more civilized boarding process.
csturdiv
Fri Aug 14, 2015 5:52 am
Quoting Natflyer (Reply 11):
Wow, imagine that, a 737 Max looking like a 737. What were you expecting, for it to look like?
An American expat from the ORD area living and working in SYD
Ruscoe
Fri Aug 14, 2015 10:52 am
Quoting AirPacific747 (Reply 20):
OK my apologies.
The MAX however does look obviously different from the side in the rear fuselage behind the pressure bulk head.
Ruscoe
barney captain
Fri Aug 14, 2015 10:54 am
Maximum certified altitude is FL410 for the NG's. I suspect the MAX will be the same.
Southeast Of Disorder
neutronstar73
Fri Aug 14, 2015 12:52 pm
I think the part you are looking at is the landing gear bay cut-out, and the image is deceptive in that it may appear to be a bulge. If you look real closely, there are no nose gear bay doors installed.
cathay747
Fri Aug 14, 2015 1:05 pm
Quoting Karadion (Reply 2):
FYI, the two digit customer codes does not exist anymore. Boeing stopped that when they started the 787 programme and that will continue onto the 737 MAX as well as any future projects. For example, 737-8H4, 737-8GP, etc will not carry on.
Yes, and I really wish they had not done this. I always liked
how you could tell the original customer of an airplane by that
code, no matter how many times it changed hands.
Try a Little VC-10derness
par13del
Fri Aug 14, 2015 1:54 pm
Quoting HiflyerAS (Reply 26):
....or they could have gone the 777X route and try to "narrow the walls internally" with improved sound insulation.
VC10er
Fri Aug 14, 2015 1:58 pm
Will Captain Kirk fly a 737? If they add anti-gravitational propulsion, perhaps!
To Most the Sky is The Limit, For me, the Sky is Home.
Polot
Fri Aug 14, 2015 2:03 pm
Quoting neutronstar73 (Reply 30):
Boeing found a way increase the height without the nose bump years ago, it was fairly early on in the program. You will notice that renderings of the aircraft don't have it. I agree that it is an optical illusion making it appear liek there is a small bulge in the picture from the landing gear cutout.
http://www.boeing.com/commercial/737max/#/gallery
[Edited 2015-08-14 07:05:14]
jayfred
Fri Aug 14, 2015 2:24 pm
Quoting Ruscoe (Reply 28):
OK my apologies.
I'm curious - I haven't seen this. Can someone explain the difference (perhaps with a good picture or two illustrating the differences?
Polot
Fri Aug 14, 2015 2:32 pm
Quoting jayfred (Reply 36):
The MAX has a 787 style APU outlet/rear fuselage. You can see it in the pictures that I linked to in reply 35. Compare that to the stubbier version found on the current 737:
Photo © Andrés Contador - AirTeamImages
Revelation
Fri Aug 14, 2015 3:04 pm
Add to the list the KC-135 which is the basis for the 707 and is scheduled to keep flying till 2040.
dergay
Fri Aug 14, 2015 3:14 pm
Maybe throw in the AN-2
Flown on A300,A310,A318,A319,A320,A321,A330,B707,B720,B727,B737,B747,B757,B767,L382,L1011,C5,DC-3,DC8,
liftsifter
Fri Aug 14, 2015 4:15 pm
Did they at least raise the window line so that, you know, you can actually look out the window... One of my biggest pet peeves with the 737, besides the narrow and short cabin.
A300 A310 A319 A320 A321 A332 A333 A342 A343 A346 A380 B736 B737 B738 B744 B763 B77L B77E B77W B788 E190
Sooner787
Fri Aug 14, 2015 4:20 pm
Quoting liftsifter (Reply 39):
Agreed, never noticed the difference until I flew to LAS last Sunday on an AA 737
and returned on a S80. The old S80 windows were at perfect height
citationjet
Fri Aug 14, 2015 4:56 pm
It is amazing to think that all 737 fuselages built since the late 1960s were built in Wichita (first by Boeing, now Spririt) and shipped by rail to Renton. I am sure multiple generations of families have worked on the 737 program.
Boeing Flown: 701,702,703;717;720;721,722;731,732,733,734,735,73G,738,739;741,742,743,744,747SP;752,753;762,763;772,773,788.
GSPFlyer
Fri Aug 14, 2015 5:02 pm
How tall are you that you have that problem? I'm 6'0," I flew on a DL 737-900 recently, and found it to be about the right height.
Now I flew on a CRJ-200 a few years ago, and my neck hurt because of the awkward angle I had to bend down to see out the window.
bgm
Fri Aug 14, 2015 5:56 pm
I'm glad I'm not the only one who noticed that. It's by no means as bad as the CRJ-200, but they are definitely a bit too low. Are Boeing also going reduce the cabin noise in the 737 MAX? I always found it noiser than the A320.
lostsound
Fri Aug 14, 2015 6:57 pm
Quoting GSPFlyer (Reply 42):
I'm 6'3 and the 737s window height hurts for me. I look like an idiot trying to look out the window lol. The CRJ-200 is definitely worse though. I needed a chiropractor after that!
iahcsr
Fri Aug 14, 2015 7:31 pm
How much higher will the Max sit than the NG? Not as much as the A320 obviously.
Natflyer
Fri Aug 14, 2015 8:52 pm
Well, the -7 Grandfather is already on a ventilator.
barney captain
Fri Aug 14, 2015 9:43 pm
Quoting iahcsr (Reply 45):
The -700NG has a 1% nose down stance, the MAX will sit at 0%. I don't believe the overall height will change.
14ccKemiskt
Fri Aug 14, 2015 9:56 pm
A 60s aircraft for the 2010s? Not sure if it is going to survive very long. But for now, it will do.
Revelation
Fri Aug 14, 2015 10:12 pm
Quoting 14ccKemiskt (Reply 48):
That's OK, some people were saying the same thing back in 1968...
yeelep
Fri Aug 14, 2015 10:15 pm
The MAX will sit 8 inches higher at the nose gear, the mains will stay the same.
AS512
Fri Aug 14, 2015 11:22 pm
Quoting yeelep (Reply 50):
Wouldn't the mains need to sit higher to account for the larger engines?
