PHOTOS: @SpiritAero celebrates first fuselage completion to @BoeingAirplanes on the #737MAX program pic.twitter.com/Hqd8ZMF7BN
— Spirit AeroSystems (@SpiritAero) 13 Août 2015
Quoting questions (Reply 3): Why has Boeing never redesigned the cramped nose/cockpit, especially since these aircraft are used in much longer missions than the original series? Would it changed the aerodynamics of the aircraft significantly? |
Quoting ODwyerPW (Reply 1): What are the significant differences between a 738NG fuselage and a 738MAX fuselage? |
Quoting AM744 (Reply 8): I don't think materials change either. |
Quoting bgm (Reply 13): Boeing definitely have gotten their money's worth out of this vintage design... |
Quoting KC135Hydraulics (Reply 10): Didn't they have to add a little bulge under the nose to accommodate taller landing gear? |
Quoting Jagflyer (Reply 9): I'm still curious why they chose to use pneumatic starters vs. electric ones (on the GEnx). |
Quoting AirPacific747 (Reply 16): Are you sure you didn't post a picture of an NG? |
Quoting litz (Reply 6): Now let's see if BNSF can get it to Boeing without dropping it in a river ... |
Quoting NWAROOSTER (Reply 21): wonder how long the grandfather can survive?????? |
Quoting TWA772LR (Reply 23): Well EIS of the MAX is about 2017, and the 100s EIS was in 1968. NG productions about 20 years old with a huge backlog, say 5 years max. So the MAX could see production until 2040. Throw in the secondhand market and the 737 series could very well see 100 years of service! A milestone that will probably only be matched by the B52 and maybe the C130 and TU95, and probably the DC-3 in remote parts of the world! |
Quoting hz747300 (Reply 24): Can they make it a teensy bit wider too. |
Quoting Natflyer (Reply 11): Wow! This looks like...another 737. (Yawn). |
Quoting AirPacific747 (Reply 20): It was a joke... but to the untrained eye, there's no difference what so ever. |
Quoting hz747300 (Reply 24): Still 42k ceiling service, or did they bump it up to 45k? Can they make it a teensy bit wider too. |
Quoting KC135Hydraulics (Reply 10): Didn't they have to add a little bulge under the nose to accommodate taller landing gear? If you look closely, you can see a small bulge in the lower right hand side of the fuselage under the nose. |
Quoting Karadion (Reply 2): FYI, the two digit customer codes does not exist anymore. Boeing stopped that when they started the 787 programme and that will continue onto the 737 MAX as well as any future projects. For example, 737-8H4, 737-8GP, etc will not carry on. |
Quoting neutronstar73 (Reply 30): I think the part you are looking at is the landing gear bay cut-out, and the image is deceptive in that it may appear to be a bulge. If you look real closely, there are no nose gear bay doors installed. |
Quoting jayfred (Reply 36): |
Quoting TWA772LR (Reply 23): Throw in the secondhand market and the 737 series could very well see 100 years of service! A milestone that will probably only be matched by the B52 and maybe the C130 and TU95, and probably the DC-3 in remote parts of the world! |
Quoting hz747300 (Reply 24): Well EIS of the MAX is about 2017, and the 100s EIS was in 1968. NG productions about 20 years old with a huge backlog, say 5 years max. So the MAX could see production until 2040. Throw in the secondhand market and the 737 series could very well see 100 years of service! A milestone that will probably only be matched by the B52 and maybe the C130 and TU95, and probably the DC-3 in remote parts of the world! |
Quoting liftsifter (Reply 39): Did they at least raise the window line so that, you know, you can actually look out the window... One of my biggest pet peeves with the 737, besides the narrow and short cabi |
Quoting HiflyerAS (Reply 26): They won't make it any wider because then they wouldn't be able to ship the fuselages by rail from Wichita to Renton, |
Quoting liftsifter (Reply 39): Did they at least raise the window line so that, you know, you can actually look out the window... One of my biggest pet peeves with the 737, besides the narrow and short cabin. |
Quoting GSPFlyer (Reply 42): How tall are you that you have that problem? I'm 6'0," I flew on a DL 737-900 recently, and found it to be about the right height. |
Quoting NWAROOSTER (Reply 21): |
Quoting iahcsr (Reply 45): How much higher will the Max sit than the NG? Not as much as the A320 obviously. |
Quoting 14ccKemiskt (Reply 48): A 60s aircraft for the 2010s? Not sure if it is going to survive very long. But for now, it will do. |
