OzarkD9S
What Airline Has The Most Gates At One Airport
Fri Aug 14, 2015 12:05 am
Simple question, what airlines has "control" of the most gates at a single airport?
Next up: STL DEN PSP DEN STL
DeltaXNA
RE: What Airline Has The Most Gates At One Airport
Fri Aug 14, 2015 12:09 am
DL ATL
AA DFW
Just guessing, but these two airlines have a lot of gates at there largest hubs.
northwestEWR
Fri Aug 14, 2015 12:15 am
Quoting DeltaXNA (Reply 1):
DL ATL
AA DFW
Those are the ones that immediately come to mind for me too. Add DL@MSP, it's almost entirely DL save for a handful of OAL gates.
Is there a UA hub that has a lot of RJ gates that might put them in the running? ORD? Been a while since I was over there.
We should also add WN@DAL!
Northwest Airlines - Now You're Flying Smart
flyDTW1992
Fri Aug 14, 2015 12:20 am
Quoting northwestEWR (Reply 2):
DTW has about 120 DL gates, but the North Terminal is reasonably large (30 or so gates) so the ratio may not be what it is at the other hubs.
Now you're flying smart
BTVB6Flyer
Fri Aug 14, 2015 12:23 am
TPA: WN
filler
diverted
Fri Aug 14, 2015 12:24 am
PD in YTZ; IIRC 9 of 10 gates are theirs, and 1 is for AC.
Would imagine some others would include
UA in DEN
EK in DXB
BA in LHR
RWA380
Fri Aug 14, 2015 12:25 am
Quoting BTVB6Flyer (Reply 4):
TPA: WN
DAL & MDW also with WN
707 717 720 727-1/2 737-1/2/3/4/5/6/7/8/9 747-1/2/3/4 757-2/3 767-2/3/4 777-2/3 DC8 DC9 MD80/2/7/8 D10-1/3/4 M11 L10-1/2/5 A300/310/320
AA AC AQ AS BA BD BN CO CS DL EA EZ HA HG HP KL KN MP MW NK NW OZ PA PS QX RC RH RW SA TG TW UA US VS WA WC WN WP YS 8M
FWAERJ
Fri Aug 14, 2015 12:29 am
You can't ask that question at FWA. It's been an all-CUTE airport for quite some time, with gate usage varying (in some cases, wildly) by time of day.
B721/722/731/732/733/735/73G/738/739/742/752/753/762/763, A300/319/320, DC-9/10, MD-82/83/88/90, ERJ-140/145, CRJ-200/700, Q200, SF340, AS350
JetBlueCLT
Fri Aug 14, 2015 12:34 am
American Airlines-CLT
Pittsburgh Penguins, Steelers, Pirates and Charlotte Hornets Fan
americanairdfw
Fri Aug 14, 2015 12:41 am
United airlines at IAH
burnsie28
Fri Aug 14, 2015 12:44 am
DL ATL
AA DFW
Technically all of E and F are CUTE so you would have to remove those, I would think DL at DTW is probably one of the highest.
contrails
Fri Aug 14, 2015 12:49 am
I'd guess AA at DFW. They have 3 terminals there.
Flying Colors Forever!
FWAERJ
Fri Aug 14, 2015 12:54 am
Quoting ipodguy7 (Reply 10):
What the hell does FWA have to do with anything being talked about above?
I was just bringing up that no airlines control gates exclusively at FWA, unlike some other airports. The same could be said for any all-CUTE airport.
LAX also qualifies as an airport where airlines have little control over gates. Many gates and the whole TBIT are CUTE, and even the airline-dedicated terminals (1 for WN, 4 for AA, 5 for DL, and 7 for UA) don't have too much of a difference in terms of gate numbers, especially when it comes to UA vs. AA.
I'll add some other airports where one airline controls the majority of gates.
-CDG: AF
-EWR: UA
-LGA: DL
-SEA: AS
-PDX: AS
-OAK: WN (all of Terminal 2)
-STL: WN (all of Terminal 2; excludes mothballed ex-TW/AA gates)
-LAS: WN
dfwagt
Fri Aug 14, 2015 3:52 am
D16 is no longer an AA gate at DFW. When the airport refurbished it to accommodate the A380 they moved AA to D6. D6 still on rare occasions will be used by OAL as was the case earlier this week when KL departed from there.
slcdeltarumd11
Fri Aug 14, 2015 4:15 am
Controls would mean has the largest percentage of gates i would think. I bet fortress hubs like
AA in CLT
DL in SLC
DL in DTW
US in IAH
I bet you those are all pretty high percentages of hub carriers controlling gates. You do see some airlines using that control. Take AS in SLC they keep begging for more gate space but its hard for them to add flights when Delta pretty much controls the gates.
northwestEWR
Fri Aug 14, 2015 4:20 am
I did the math for Delta's main hubs.
ATL: 159/201 = 79%
DTW: 121/147 = 82%
MSP: 102/128 = 80%
SLC: 65/83 = 78%
Anybody have the numbers for AA and UA?
BMcD
Fri Aug 14, 2015 5:15 am
WN at DAL? (Please don't shoot me for that one...)
DC-8, DC-9, DC-10, MD-11, MD-80/2/3, 717, 737, 747, 757, 767, 777, 787, L1011, CRJ2/7/900, A320, A321, A330, Saab 340
northwestEWR
Fri Aug 14, 2015 5:25 am
We should probably exclude airports without one of the US3 and those with less than 10 gates or some similar number. Otherwise it'll be very easy to find airports with only UA for example that has 3 gates and all UA. --> 100%
Quoting BMcD (Reply 18):
At 18/20 = 90% it's probably going to be one of the very highest by percentage
TWA772LR
Fri Aug 14, 2015 5:42 am
Quoting slcdeltarumd11 (Reply 16):
US in IAH
Either you meant US in IAD or UA in IAH.
When wasn't America great?
flyDTW1992
Fri Aug 14, 2015 6:31 am
Quoting northwestEWR (Reply 17):
ATL: 159/201 = 79%
DTW: 121/147 = 82%
MSP: 102/128 = 80%
SLC: 65/83 = 78%
Interesting, and by my quick calculations, for June 2015, Delta and Delta Connection, plus AF and VS who use DL gates, accounted for approximately 77% of enplaned pax at DTW. Pretty close correlation there.
Lofty
Fri Aug 14, 2015 9:02 am
What is meant by "control" are we talking about the airlines allocating their own dedicated gates / stands?
flyDTW1992
Fri Aug 14, 2015 9:15 am
Quoting Lofty (Reply 22):
Well, given the discussion has stayed rather USA-centric, I think thus far we've been talking about actual operational ownership via lease, given CUTE gates are the exception rather than the rule in this country.
us330
Fri Aug 14, 2015 10:01 am
Based on my rough DFW estimates earlier (AA with 136 gates, and 32 available for others, so 136/168), AA controls about 78.5% of the gates at DFW, which is almost identical to DL at ATL.
Actually, considering that Southwest flies to many alternative airports, it wouldn't be that surprising to see WN at the top of the list because of their presence at places like HOU and MDW.
Gazdon121
Fri Aug 14, 2015 10:39 am
IAG at LHR is a good bet
burnsie28
Fri Aug 14, 2015 10:51 am
ATL: 159/201 = 79%
I only counted 131 for Delta, E & F can't be included. If 131 is correct tenth number would drop to 65%
stlgph
Fri Aug 14, 2015 12:14 pm
Quoting burnsie28 (Reply 26):
does that include the Humphrey Terminal?
if assumptions could fly, airliners.net would be the world's busiest airport
Andy33
Fri Aug 14, 2015 12:38 pm
Quoting Gazdon121 (Reply 25):
Not really, because Terminal 2,3 and 4 gates are common-user (even if some are used by the same airlines day in day out in practice, they're under airport control). Only at Terminal 5 is gate allocation controlled by BA (or any other airline) and there are 53 numbered gates (the numbers go higher but there are gaps to allow for expansion). So plenty of examples have already been given of airlines controlling far more gates elsewhere,
RyanairGuru
Fri Aug 14, 2015 12:54 pm
Quoting TWA772LR (Reply 20):
And maybe you meant UA at IAD or US at DCA?
Hardly, they control about 30% of gates at LHR. Even if you counted any gates they use regularly at T3 it wouldn't come close.
Worked Hard, Flew Right
YouGeeElWhy
Fri Aug 14, 2015 1:26 pm
the ME3 at their respective hubs will have a high % of gates controlled. Same with ET at ADD. My guess is DOH and QR have the highest % out of these 4.
727LOVER
Fri Aug 14, 2015 2:14 pm
Are we talking about actual number
OR
Are we talking about percentage
Because if its the former, how would WN @ TPA, MDW or DAL even count?
Also, are we including regionals....because airports have separate contracts for regionals.
DL in ATL
T = 8
A = 35 ish
B = 35 ish
D = 10 ish
so that's around 88
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
dumbell2424
Fri Aug 14, 2015 2:23 pm
Quoting northwestEWR (Reply 19):
In that case US at FLO... 1/1 = 100%
washingtonflyer
Fri Aug 14, 2015 2:39 pm
Same with HHH (or is it HXD)...
superjeff
Fri Aug 14, 2015 3:30 pm
Quoting contrails (Reply 12):
100% of A, B, and C, and about 60% of D.
burnsie28
Fri Aug 14, 2015 4:05 pm
Quoting stlgph (Reply 27):
The numbers I was referenceing were for ATL.
Quoting 727LOVER (Reply 31):
DL in ATLT = 8A = 35 ishB = 35 ishD = 10 ishso that's around 88
Thats the first that I heard anything about the RJ's being different. Either way Delta has gates on C.
liftsifter
Fri Aug 14, 2015 4:16 pm
I don't have figures, but UA controls about 35% of gates at ORD with all of T1 and most of T2 as well. Also, WN at MDW, they essentially have the entire airport apart from a few leftovers.
A300 A310 A319 A320 A321 A332 A333 A342 A343 A346 A380 B736 B737 B738 B744 B763 B77L B77E B77W B788 E190
jkrugman22
Fri Aug 14, 2015 4:40 pm
What about EK at DXB?
asteriskceo
Fri Aug 14, 2015 4:43 pm
B6 at LGB
filler
Rdh3e
Fri Aug 14, 2015 4:44 pm
I'm fairly certain UA's highest number of gates is at IAH.
Quoting diverted (Reply 5):
UA in DEN
UA only has the one concourse which is less than 70 gates.
Not usually at hubs.
[Edited 2015-08-14 09:49:35]
PSU.DTW.SCE
Fri Aug 14, 2015 4:47 pm
ATL: 159/201 = 79%
DTW: 121/147 = 82%
MSP: 102/128 = 80%
SLC: 65/83 = 78%
Does this account for the ~7 gates that DL shuttered in Concourse C at DTW earlier this year?
Not to mention the roughly 5-6 gates in A & B that are not in service and used for GSE parking?
intotheair
Fri Aug 14, 2015 5:01 pm
Quoting RDH3E (Reply 39):
There are 77 gates at Concourse B in DEN. I would say that *only* having one concourse is still pretty big, especially seeing that they're the only airline with one to themselves, and DEN only has three concourses. UA also operated some gates in the A concourse some time ago, and international arrivals still arrive there in the city-owned gates.
300 319 320 321 332 333 345 346 380 717 733 734 735 73G 738 739 744 752 753 762 763 772 77W 788 789 CR2 CR7 CR9 CRK Q400 E175 DC10 MD82 MD90
AA AF AS AY AZ B6 BA BR DL F9 FI GA HA KF LH MI QX SK SN SQ UA US VY WN
GSPFlyer
Fri Aug 14, 2015 5:13 pm
AA & US at CLT: 85/97 = 87%
Could this be the highest percentage of gates owned by one airline at a "primary" airport for a large city?
[Edited 2015-08-14 10:16:19]
BOStonsox
Fri Aug 14, 2015 5:18 pm
B6 in BOS. They have control of (almost?) all of Terminal C. AS and SY are also in Terminal C, as are EK departures. I wouldn't be surprised if EI moves there sometime as well.
2013 World Series Champions!
gatibosgru
Fri Aug 14, 2015 5:31 pm
Who has the most @ BOS? B6?
@DadCelo
Andy33
Fri Aug 14, 2015 5:38 pm
Quoting BOStonsox (Reply 43):
Well, they might, but as they are about to become part of IAG and (as far as we know) OneWorld too, aren't they likely to want to be with AA and BA?
727LOVER
Fri Aug 14, 2015 5:52 pm
Quoting burnsie28 (Reply 35):
You are correct...just had a friend who works there confirm that for me.
Rdh3e
Fri Aug 14, 2015 5:59 pm
Quoting intotheair (Reply 41):
DIA only has 67 gates on their map of the concourse. They are also doing some construction, so to my knowledge there are several gates out of service.
http://www.flydenver.com/maps
B4REAL
Fri Aug 14, 2015 7:44 pm
In 2005 or so, all DL-coded flights (in particular mainline + DL Connection) at CVG had more gates that ATL.
That'll win you a bet a bar!
floridaflyboy
Fri Aug 14, 2015 8:02 pm
Quoting GDG9 (Reply 48):
Easy, he's just discussing his home airport. Just because its not a fortress hub does not make comment irrelevant.
Exactly! Nothing wrong with chiming in about smaller airports. Always interesting to hear about airports I most likely won't use and thus wouldn't know about.
On that note, BTM is 100% DL
Good goes around!
canadianpylon
Fri Aug 14, 2015 8:21 pm
Quoting FWAERJ (Reply 7):
Likewise with YWG. All gates (and counter space and checkin kiosks) are common use...
Orange
Always looking for the longest route with the most transfers.
RyanairGuru
Fri Aug 14, 2015 8:26 pm
Quoting jkrugman22 (Reply 37):
Definitely not EK. Dubai is a bit more difficult to figure out because so many aircraft board on remote stands, but if you combine contact positions and remote stands together for Concourses A, B & C you get to 100 positions for Emirates. This is out of 220 positions, so EK have 45% of stands. I can't figure out FZ as Terminal 2 is CUTE but I would be surprised if EK and FZ combined were much over 50-55%.
It's often forgotten but 140 airlines not called Emirates fly to DXB.
EY@AUH and QR@DOH might be safer bets.
