JETnyc
Plane Door Falls On Golf Course
Wed Aug 19, 2015 11:17 pm
CBS news has reported that a door from a AA flight is found on golf course / article → http://cbsn.ws/1KwzXEO
LandSweetLand
RE: Plane Door Falls On Golf Course
Wed Aug 19, 2015 11:33 pm
Would that be a case to get a drop-ball or would you need to play it as it lies?
KELPkid
Wed Aug 19, 2015 11:50 pm
Should be "access panel" and not "door". It would have been much more serious had it been an actual door    And yes, some access panels have hinges and latches...
KELPkid
Wed Aug 19, 2015 11:56 pm
Quoting LandSweetLand (Reply 1):
I think AA is going to take a Mulligan on that one...
777Jet
Thu Aug 20, 2015 12:17 am
That would be a case of go and buy a lotto ticket after your round of golf because you are lucky that that access panel did not land on your head and kill you!
lightsaber
Thu Aug 20, 2015 4:22 am
Did anyone else notice the panel didn't even create a divot in the grass in the article photos?
Wouldn't one just play through?
At the 19th hole, that panel probably grew to the size of a C-5's tail door...
Lightsaber
liftsifter
Thu Aug 20, 2015 4:27 am
Quoting lightsaber (Reply 5):
Considering it's from a 321, it's probably completely composite materials which would mean it doesn't weigh more than a couple pounds. I wouldn't expect it to careen towards earth and create a massive crater..
A300 A310 A319 A320 A321 A332 A333 A342 A343 A346 A380 B736 B737 B738 B744 B763 B77L B77E B77W B788 E190
cabochris
Thu Aug 20, 2015 4:34 am
Almost an ace! Nice shot.
imagoagnitio
Thu Aug 20, 2015 6:48 am
Quoting cabochris (Reply 7):
"Falling from the sky, twirling around in circles and land approximately 40 yards to the right of the green," he said.
Serious question, should the golfers or CBSN be moving it to get their 'story shot' or should it have been left where it landed, 40 yards away?
aviatorcraig
Thu Aug 20, 2015 7:19 am
I think the bigger story here is the "other incident" referred to on the news clip. On Saturday another A321 at CLT took out some "runway lights" whilst attempting to land in windshear and was substantially damaged.
Do they mean the approach lights??? I haven't seen this reported anywhere.  Wow!
707 727 Caravelle Comet Concorde Dash-7 DC-9 DC-10 One-Eleven Trident Tristar Tu-134 VC-10 Viscount plus boring stuff!
KELPkid
Thu Aug 20, 2015 8:09 pm
Quoting imagoagnitio (Reply 8):
I don't think it's going to hurt anything. There are laws about not touching aircraft wreckage in the USA, but I don't think this qualifies as wreckage, seeing how the incident is not an NTSB reportable accident.
The law in the US says that you can only move aircraft wreckage in order to save survivors (unless you are an NTSB investigator or FAA inspector).
I have personally picked up parts that have fallen off of aircraft, as I used to work at a small airport   Usually things like circular inspection panels that have fallen off, or the occasional screw, cotter pin, or nut...don't want those parts to cause FOD for subsequent aircraft.
Yflyer
Thu Aug 20, 2015 8:19 pm
Quoting aviatorcraig (Reply 9):
That incident is being discussed here:
AA A321 Tailstrike @ CLT (by zanl188 Aug 19 2015 in Civil Aviation)
Q
Thu Aug 20, 2015 11:09 pm
I bet ground crew was going to get the open door for electric or drain pipe but there is a missing door. Ground crew may already report to pilot not to fly because of missing door. The plane must be repair as son as possible get replace new door.
Q
KELPkid
Thu Aug 20, 2015 11:26 pm
Quoting Q (Reply 12):
I wonder if the access panel in question is on the MEL...you'd be surprised what a plane is allowed to fly without sometimes
copter808
Thu Aug 20, 2015 11:35 pm
Quoting 777Jet (Reply 4):
Unless it falling in a "knife edged" manner, I doubt there would be any injury--at least until it was reported to the press or lawyers!
Quoting liftsifter (Reply 6):
Quite sure it doesn't weigh anywhere near that much!
It would--or should be--reported so the arriving station doesn't take the "hit" for the damage. If anything, maintenance would probably just tape it over with high speed tape.
CairnterriAIR
Fri Aug 21, 2015 4:07 pm
"Falling from the sky, twirling around in circles and land approximately 40 yards to the right of the green."
That's pretty much how most of my golf shots end up!
