Quoting Green12324 (Reply 1): I'm not familiar with Allegiant's history of incidents, but one like this makes me seriously question their operation. |
Quoting FLIHGH (Reply 7): Not true. Planes do wheelies all the time down the runway when on soft runways. That's what we are supposed to do. Now, if the angle of attack is too high, a tail strike is very possible. |
Quoting Caryjack (Reply 3): If uncontrolled, I'd guess a stall. |
Quoting FLIHGH (Reply 7): Now, if the angle of attack is too high, a tail strike is very possible. |
Quoting infiniti329 (Reply 12): LOL, fine the FAA good one. You can't execute the executioner |
Quoting LAX772LR (Reply 13): Probably the worst that would happen is that the Secretary of Transportation fires the head of the FAA, or someone else in the Executive department does it, even up to the President himself. I doubt anything would happen to the department itself. I guess a criminal investigation (and ensuing consequences) could also occur, in some circumstances. |
Quoting TUSdawg23 (Reply 10): You could make the argument they fly older equipment, but so does DL and I don't see their MD-80's and 757's having the kinds of mechanical issues that are taking place lately at G4. |
Quoting wjcandee (Reply 16): Because those issues don't make the paper, and their pilots' union isn't obliging the media by helpfully furnishing them with detailed info on every operational hiccup. |
Quoting Green12324 (Reply 1): A malfunctioning elevator is no light matter. I'm interested to hear their explanation as to why the aircraft made it to the runway. |
Quoting MD95sOverATL (Reply 6): I'm an aircraft n00b, but could this have anything to do with the infamous jackscrew assembly and it needing frequent lubrication and attention? Maybe it got jammed in one position? |
Quoting rbavfan (Reply 11): Was it not elevator issues with improper maintenance on Alaska that caused tier MD80 crash |
Quoting flyDTW1992 (Reply 17): Nah. Delta Techops is a truly top-notch organization, |
Quoting wjcandee (Reply 24): (Referring to G4's current, and former, maintenance providers.) |
Quoting n471wn (Reply 28): hardly.....spoken by a true legacy |
Quoting cbphoto (Reply 30): Apparently the left elevator boost actuator had become disconnected. It's entirely possible and likely it came out of contract maintenance on a heavy or light check, and hadn't been attached properly. Aircraft was back in service a few hours later and an inspection on the entire fleet was completed with no issues found! Granted, you get what you pay for, but there is often more to the puzzle when you have contract maintenance thrown into the picture, as opposed to doing your maintenance in house! |
Quoting cbphoto (Reply 30): Apparently the left elevator boost actuator had become disconnected. It's entirely possible and likely it came out of contract maintenance on a heavy or light check, and hadn't been attached properly. |
Quoting 777X (Reply 2): What happens if the nose rises and the plane does a wheelie down the runway until the speed is high enough to lift off? Even if the pilots are in control? |
Quoting National757 (Thread starter): 138 miles (222 kilometers) |
Quoting jfklganyc (Reply 37): Pilots use neither mph or kph when referencing any sort of speed (Indicated Airspeed, Ground speed, True Airspeed, Static Airspeed, Calibrated Airspeed) |
Quoting badgerguy (Reply 38): Did I not hear several months ago, the FAA told G4 no new planes or routes. Yet there was a thread regarding them posting new routes. I thought this was because of the maintenance/operational mishaps happening. Does anyone else remember this? What ever happened to that decision? |
Quoting sandyb123 (Reply 34): I'm not a (commercial) pilot but isn't this the kind of thing that gets caught in the pre-flight checks? |
Quoting Max Q (Reply 44): Yes, but you can't blame this incident on Contract maintenance, outside work should still be monitored and checked by the purchasing carrier. |
Quoting Mir (Reply 45): Quoting sandyb123 (Reply 34): I'm not a (commercial) pilot but isn't this the kind of thing that gets caught in the pre-flight checks? The larger the plane, the more stuff gets hidden internally with no easy way of looking at it from the ground, especially in an aircraft with the horizontal stabilizer at the top of the tail as the MD-80 has. It may have looked perfectly normal to someone doing a walkaround. |
Quote: .....a recent rash of emergency landings and unusual flight incidents have put Allegiant in the spotlight and have left many observers asking if the company's old fleet has worn out its welcome. Since the beginning of 2015, there have been 16 reported incidents involving Allegiant flights that resulted in emergency landings, flight diversions, aborted takeoffs or, maybe the most bizarre of all, a passenger-initiated evacuation. The most serious incident occurred in Las Vegas on Aug. 17 when the nose of a twin-engine MD-80 jet on its takeoff roll began rising prematurely, defying the flight crew's attempts to keep it down. When the plane reached 138 mph, the pilot aborted the takeoff, bringing the jet to a halt, according to a report filed with the Federal Aviation Administration. A preliminary FAA investigation found that a nut on a component that moves the left elevator had fallen off, causing the control surface to become jammed in the up position. A similar circumstance led to the crash of an Alaska Airlines MD-80 over the Pacific Ocean on Jan. 31, 2000. |
