Quoting Miami (Reply 3): That's look really bad! I can't really tell but it looks like a double engine fire.. |
Quoting A332DTW (Reply 10): Wow... that could have been a lot worse. |
Quoting BMcD (Reply 5): FR24 confirming BA2276 |
Quoting FWAERJ (Reply 4): Wonder if they were GE90s or Trents? |
Quoting fbgdavidson (Reply 17): It's G-VIIO if it's the same aircraft that operated LGW-LAS, a GE90 aircraft. |
Quoting georgiaame (Reply 14): It could have been a lot better. What can cause a double engine fire, on super reliable engines? |
Quoting georgiaame (Reply 14): What can cause a double engine fire, on super reliable engines? |
Quoting AirlineCritic (Reply 19): Even with lots of smoke, and possibly fire only on engines... is this a write-off? And |
Quoting AirlineCritic (Reply 19): is this a write-off? |
Quoting georgiaame (Reply 14): Wow... that could have been a lot worse. It could have been a lot better. What can cause a double engine fire, on super reliable engines? |
Quoting SpaceshipDC10 (Reply 22): Emergency braking? |
Quoting A332DTW (Reply 28): It was a large fire, which makes me question what the ignition source might have been. Hot brakes alone I doubt would cause that large a fire. |
Quoting AirlineCritic (Reply 32): Hot brakes causing tires to burn |
Quoting BMcD (Reply 37): There are some serious flames from wing level: http://www.youtube.com/watch?v=n0Ecr5h_Y-M |
Quoting AirlineCritic (Reply 19): And how on earth does this start on the runway? |
Quoting Okie (Reply 11): Landing gear fire it looks like to me. Too dark of smoke and I can see the left turbine pretty clearly in the linked picture. |
Quoting BMcD (Reply 37): There are some serious flames from wing level: |
Quoting A332DTW (Reply 40): Is it just smoke and optical illusion, or does that fire look like it's just front of the landing gear? |
Quoting BMcD (Reply 37): There are some serious flames from wing level: http://www.youtube.com/watch?v=n0Ecr...h_Y-M |
