Quoting ACDC8 (Reply 2): I could be mistaken |
Quoting SpaceshipDC10 (Reply 3): Quoting ACDC8 (Reply 2): I could be mistaken You are not. I believe they came to replace the 72S. |
Quoting MEA-707 (Reply 12): They used the 734s to Europe in the 1990s but a pure 757 fleet was more efficient. Even while it was a bit big for some European destinations, a 757 could be rostered to Europe at daytime and do a return to America at night so all in all it made sense to use the 757 instead of having a small fleet of 737s which couldn't do much at night due to curfews at most of their European destinations. |
Quoting eaa3 (Reply 14): Ironically, the same logic applies for the B737-9 |
Quoting MEA-707 (Reply 15): True, although their network has grown fivefold since the 1990s and there's now more room for a dedicated people mover to Europe, say LHR, CPH and AMS, if KEF doesn't have a night curfew they can also depart 2 am to these destinations (arriving 5-6am) and offer an extra bank of connections. Also as the 739 MAX should have longer legs then the old 737-400s so it can probably be used to BOS, YYZ, JFK and such as well. Still I think they should have gotten the 321LR to reach Denver, Seattle and Calgary and such. |
Quoting eaa3 (Reply 16): I actually even doubt that they'll reach BOS, YYZ, JFK without having to be weight restricted. The B737-9's lackluster take-off performance probably prohibits a full load out of most airports, incl. KEF. Its a strange choice to not go for the A321LR when it costs about the same, uses the same amount of fuel, takes a little bit higher load but can serve all your destinations. I don't think the B737-9 will be a part of their future because eventually they will have to order the A321LR as its the aircraft that can best replace their current fleet of B757's (with less cargo though. The A321LR is techincally a smaller aircraft). It make zero sense to operate the B737-9 and A321LR together at a small to medium sized airline. And it makes no sense to operate an A321LR and the B737-8 when you could operate the A320NEO and have almost 100% commonality. |
Quoting eaa3 (Reply 16): |
Quoting zkokq (Reply 10): Dont forget they own the PX fleet as well! |
Quoting Bluebird191 (Reply 19): Including the Fokker F100's, Dash-8's and 737's PX have? I distinctly recall PX ordering Q400's a few years back in their own right and not having them leased. It's only their 767's for clarification, unless their 737's are leased from Icelandair too? |
Quoting mjoelnir (Reply 18): If there is an airport were the 737-9MAX will be able to operate at MTOW , than it is KEF. Long enough runways, only a little above sea level and never hot. They will be able to do the east coast of NA and Europe. |
Quoting mjoelnir (Reply 18): I do not imagine the A321neo or A321LR at Icelandair. They have been a Boeing only airline for quite a while, and that also in their wet leasing and MRO operation. And at Icelandair the A321neo or LR does not really replace the 757-200 at this point in time. The reason is the limited cargo capabilities of the A321neo or LR. |
Quoting eaa3 (Reply 21): Two problems: 1: It does get hot at their North American airports and you might have 30 degree days where the B737-9 would suffer ridiculously on the return flight to Iceland. 2:More importantly, the runways at KEF are 10,056 ft. long and it doesn't get particularly warm. Even with those factors, the B737-9 would not be able to take-off fully loaded. It's obvious by looking at the runway length requirements for B737-900ER and keeping in mind that the B737-9 is heavier, has the same wings and has the same thrust. What I'm saying is that I don't think the B737-9 will be able to be dispatched to North America with any reliability and if it is then it will be weight restricted. I have not seen any evidence to the contrary but I have seen evidence that show's that I'm right. |
Quoting eaa3 (Reply 21): WE GET IT. Please stop making this point. You've stubbornly made it hundreds of times on here. The B757 and the A321LR are not the same aircraft. The B757 can carry more cargo. Those are the facts. But there is no other option that will replace the A321LR. So they're going to have to move in that direction. |
Quoting mjoelnir (Reply 22): You do not get it!!!!! Icelandair has just moved the training of 757 pilots home to Iceland and invested in a brand new 757 simulator, including a new building that you pass on the left side driving through Hafnarfjörður on the way to Keflavík before you pass on the right side the aluminium smelter of Ísál. It is very difficult to imagine, that that investment is done if FI will stop flying the 757 soon. |
Quoting mjoelnir (Reply 22): And I am getting tired of this A321LR BS about being as capable as a 757-200. |
Quoting mjoelnir (Reply 22): I assume that the needed runway length for a 737-9MAX at MTOW will not exeed that for a 737-900ER and that is at sea level and under 25° C 9,850 feet. |
Quoting eaa3 (Reply 23): If you look at the aircraft planning, then the 9.850 feet take-off distance for the B737-900ER is for a standard day, 15 degree Celsius. The B737-900ER has at most a 27,300 pound thrust engine. The B737-9 is at most a 28,000 pound thrust engine. In other words, it has 2.5% more thrust. However, the B737-900ER has a MTOW of 85,130 kg. whereas the B737-9 is 88,314 kg. or 3.7% higher. I sincerely doubt that the aircraft will be able to take off on a runway of 10,056 feet. |
Quoting mjoelnir (Reply 24): The 737-900ER is used on SEA-HNL flights. That is 2326 nm. |
Quoting eaa3 (Reply 25): But then at Seattle there is an 11,901 foot runway. 1,900 foot longer than at KEF At Honolulu there's a 12,312 foot runway. 2312 feet longer than at KEF. |
Quoting mjoelnir (Reply 26): Both see far higher temperatures than KEF ever does, at 30°C you need 10° more runway than at 20°. And let us not forget that KEF offers runways in four directions 90 degrees on each other and has usually some wind. Every knot of wind speed reduces take off roll by about 1°. So you would have to find very unusual condition, that you find only during summer and than only on very few days, to not be able to take off at MTOW and on those days I would not expect very heavy headwinds going west. |
Quoting Fallap (Reply 30): Why have FI decided to reacquire two B767? |
Quoting Fallap (Reply 30): |
Quoting diverted (Reply 17): |
Quoting eaa3 (Reply 27): You still haven't made any case for the B737-9 being able to operate at MTOW from KEF. You can't rely on the wind because the runway is too short! |
Quoting mjoelnir (Reply 33): Apart from everything else, I do not believe that the 737-9MAX will need more than 10,000 feet runway at MTOW, it will be designed to not exceed that. |
Quoting bmacleod (Reply 35): ...until the 737MAX arrives, the 757 has the range needed to connect Iceland to North America... |
Quoting prebennorholm (Reply 36): Those 737MAX are just perfect for the routes from KEF to UK and continental Europe where they will gradually replace the older 757s in the FI fleet. |
Quoting eaa3 (Reply 37): Quoting prebennorholm (Reply 36): Those 737MAX are just perfect for the routes from KEF to UK and continental Europe where they will gradually replace the older 757s in the FI fleet. They´re good for that. Problem is that one of the big reasons why they got rid of them in the first place, in around 2000, was that they couldn't do North American flights which meant that they would generally get way worse usage out of them i.e. they would do perhaps 2 flights to Europe a day. The trick to efficiency at Icelandair is to have aircraft that can fly both to Europe and N.A.. Therefore, the choice between A321LR and the B737-9 should be an obvious one. |
Quoting jfk777 (Reply 39): But is there enough demand for such a bird when the A321 and 737-9 do almost 757 flights, even Hawaii, except for the European flights. |
Quoting IADCA (Reply 40): There would be if, and only if, that plane were superior to the 739 and A321NEO on more than just the extreme long end of the range envelope. However, Boeing has in the past shown some reluctance to have models competing with each other, except where one is the clear successor to the other (e.g., 773ER vs 744 and the unfortunate result of the MDD merger), so there might be some reticence to build a plane that overlaps the 738/9MAX unless those models are getting hammered by the competition. |
Quoting UsAir737 (Reply 7): They can't haul enough fish. As we all know only a 757 can haul fish |
Quoting mjoelnir (Reply 22): And I am getting tired of this A321LR BS about being as capable as a 757-200. It is not. |
Quoting mjoelnir (Reply 41): The 737-9MAX is getting hammered by the competition. |
Quoting jfk777 (Reply 39): Seems the "perfect" for Icelandair is the 757neo or whatever plane Boeing is talking about building for 200 passengers and 3,000 to 4,000 miles range. |
Quoting lightsaber (Reply 42): Quoting mjoelnir (Reply 41): The 737-9MAX is getting hammered by the competition. Yet Icelandair has ordered 7. For closer in higher demand markets, it is wise for them to have several gauges of aircraft. |
Quoting IADCA (Reply 40): Boeing has in the past shown some reluctance to have models competing with each other, except where one is the clear successor to the other (e.g., 773ER vs 744 and the unfortunate result of the MDD merger), so there might be some reticence to build a plane that overlaps the 738/9MAX unless those models are getting hammered by the competition. |
