777X
More DL 744 Woes
Tue Sep 22, 2015 9:34 pm
A DL 747-400 from AMS to ATL had departed AMS when they had to shut down the engine and return to AMS.
This marks the third DL 744 incident this September, and sixth since June. Is this just bad luck, or is it a fixable problem?
http://avherald.com/h?article=48cb9fbb&opt=0
Sightseer
RE: More DL 744 Woes
Tue Sep 22, 2015 9:38 pm
Quoting 777X (Thread starter):
It's likely just a reality of operating an old fleet, although concentrating the 744s solely at DTW might help slightly.
northwestEWR
Tue Sep 22, 2015 9:40 pm
Quoting Sightseer (Reply 1):
It will--The ATL routes have really struggled this summer with near constant delays due in part to problems on the ground at ATL but because they don't have a spare in ATL, that isn't the case in DTW and they can usually aircraft swap if there is going to be a significant maintenance delay.
The 747s are really good at what they do but they have to be pampered in order to do it. Moving them back to DTW will help a lot.
Northwest Airlines - Now You're Flying Smart
luv2fly
Tue Sep 22, 2015 10:57 pm
Didn't UA solve there 747 problems by keeping them SFO based?
DTWPurserBoy
Tue Sep 22, 2015 11:03 pm
DL is trying to run out the clock on the airplanes before parking them for good. They recently purchased a few simply for spares, primarily engines I would think.
The 744 is a good reliable machine and suffers no more maintenance issues than any other type. You have a lot more safety margin with 4 turning instead of 2. I have worked on flights that had an engine shutdown and passengers never even knew it had happened. The flight attendants all knew it because they are used to the normal sounds of the aircraft and can instantly tell when something has changed.
Qualified on Concorde/B707/B720/B727/B737/B747/B757/B767/B777/DC-8/DC-9/DC-10/A319/A320/A330/MD-88-90
northwestEWR
Tue Sep 22, 2015 11:12 pm
Quoting luv2fly (Reply 4):
That's my understanding--yes.
Quoting DTWPurserBoy (Reply 5):
Indeed, I've heard it was for both spare 747 parts and PW4000 engines--either for the 747s or 767s.
texdravid
Wed Sep 23, 2015 12:31 am
Lol, I think a lot of Anetters and myself included can discern the sound of one engine down in a 744.
The average person, no.
Tort reform now. Throw lawyers in jail later.
MSPNWA
Wed Sep 23, 2015 12:42 am
An engine issue sounds more like bad luck, but the DL 744 fleet has struggled for a little while. I think it has to be notied that these old 744s are among the oldest aircraft still flying for a major passenger airline. And with widebodies, it's not like you have plenty of spares laying around. Every maintenance issue becomes an issue.
mark2fly1034
Wed Sep 23, 2015 1:22 am
I was on the flight it happened right after takeoff I noticed we were not going above 6,000 feet, after a few minutes the pilot told us they had lost oil pressure in the #1 engine and we were going to dump fuel and return. After landing we taxied to a remote stand and after 3 hours they cans led the flight. Crew handed out water and snacks ever hour so it was more of a pain not knowing if we would leave again. They did start to let people off but told them it would take 2 hours to get checked bags and not soon after the word came to bus everyone over to the terminal. I just arrived off KLM in Atlanta crew did a great job, wish they had more buses to send people back it was a slow process
flyDTW1992
Wed Sep 23, 2015 1:32 am
Quoting northwestEWR (Reply 6):
Just did a major facepalm because I always just thought DL's 744s had CF6s. And I've seen them up close on several occasions before, too. Duh.
Now you're flying smart
northwestEWR
Wed Sep 23, 2015 2:39 am
Quoting flyDTW1992 (Reply 10):
Come on now, Northwest buy an engine that wasn't Pratt? Please.
Max Q
Wed Sep 23, 2015 3:34 am
Don't see why they weren't able to continue on three.
The Aircraft was designed to do so, the loss of one engine is not considered an emergency and its designed
to be able to complete the flight.
GGg
Flighty
Wed Sep 23, 2015 3:49 am
MaxQ. You probably know well about the BA flight that completed an Atlantic crossing on three. They made an emergency fuel stop short of their destination because they were cutting it too close. In the end, gutsy flying but not worth it.
northwestEWR
Wed Sep 23, 2015 4:15 am
Quoting Max Q (Reply 12):
Yes, technically legal and I'll have to check but I doubt it's in Delta's OpSpecs or 747 manuals where they can continue on 3. The carrier can be more restrictive than the FAA/EASA.
It just doesn't make sense for them to push the limit when you're that close to a major maintenance and passenger hub. Better safe than sorry.
mayor
Wed Sep 23, 2015 4:18 am
Quoting northwestEWR (Reply 2):
Sort of like the Tristars in the last few years of their service.
"A committee is a group of the unprepared, appointed by the unwilling, to do the unnecessary"----Fred Allen
Max Q
Wed Sep 23, 2015 4:24 am
Quoting Flighty (Reply 13):
They weren't cutting anything too close.
They continued that flight in accordance with the certification of the aircraft, the flight manual and in conjunction with their dispatch and maintenance departments who all concurred it was safe to do so. They had more redundancy remaining on their 747 after that engine failure than you have in your B767 with everything working.
Nothing 'gutsy' about it and they didn't make an 'emergency' fuel stop, they diverted to MAN for fuel as they would not be able to land at LHR with normal reserves (this happens regularly on flights without engine failures)
Four and three engine jet transports are designed and certificated to be able to continue to their destination with the loss of one engine. In this world of twins its easy to forget that, lose an engine on a twin and you land at the nearest suitable airport, no decision to be made.
Three and four engine transports do not have to comply with that, justifiably , because of their redundancy, they have been completing flights for decades with an engine shut down with no controversy whatsoever, it was only the unwarranted hysteria over the BA flight that drew attention to the practice and, incidentally that crew was exonerated of any 'wrongdoing' by both the FAA and CAA.
Rightly so, they were the authorities that approved the procedure.
GGg
AWACSooner
Wed Sep 23, 2015 6:53 am
Quoting mayor (Reply 15):
Don't mention that airplane...it still makes me cry that I will never get to fly on the sexiest airplane ever made!
747classic
Wed Sep 23, 2015 8:01 am
Quoting Max Q (Reply 16):
I couldn't agree more.
See my signature below.
Operating a twin over the ocean, you're always one engine failure from a total emergency.
bhmdiversion
Wed Sep 23, 2015 8:42 am
Kalitta charter is on the way to AMS now with a new engine and tooling... Flight is CKS503.
TC957
Wed Sep 23, 2015 11:35 am
Lets face it guys, that first batch of 10 ex-NW 744's are 25+ years old and knackered from being hacked across the Pacific all that time. Far newer frames are being withdrawn by others and parked up. For example, CI's first batch of 9 are also PW powered and starting to be sent to the desert, and are 8 - 10 years younger.
So at least there is a ready and plentiful spares solution.
Of course, DL can always order a few 748i's ....wishful thinking I know.
cathay747
Wed Sep 23, 2015 11:47 am
Quoting northwestEWR (Reply 11):
LOL, how true...Don Nyrop was famously once quoted, when
discussing an engine choice of which GE was possibly one,
"if I want to buy light bulbs I'll talk to GE".
Try a Little VC-10derness
bobnwa
Wed Sep 23, 2015 11:49 am
Quoting TC957 (Reply 20):
Why would it make a difference what ocean they were fly over, to make them "knackered up" Have no idea what that means
WesternDC6B
Wed Sep 23, 2015 1:27 pm
A British Airways crew did that, and was pilloried in the press for it. The very same press that writes up a ground accident as a crash, and tells us about incidents involving a "twin-engine DC8 Super Constellation".
[Edited 2015-09-23 06:36:32]
Never employ grandios verbiage when the utilisation of diminutive phraseology will suffice.
leothedog
Wed Sep 23, 2015 1:55 pm
Question: What's going to happen to the plane? Pictures don't look very good for repair (I'm no expert). If it can't be fixed to fly again, then what? Do they park it in a remote location, strip it, then have it with a giant back hoe?
I've got things to see and people to do.
Western727
Wed Sep 23, 2015 2:24 pm
Quoting leothedog (Reply 24):
As bhmdiversion states in reply 19, a new engine is being flown to AMS, so it looks like it'll be fixed to fly again.
Jack @ AUS
DTWPurserBoy
Wed Sep 23, 2015 2:50 pm
No, they change out the engine, make any other necessary repairs and return it to service. You don't scrap your car when the "check engine" light comes on, do you?
DL made one exception when a 744was seriously damaged by hail in SEL. The ferried it straight to MHZ for retirement and pulled another ship out of the desert. The cost of the repair and the length of time it would take made it uneconomical.
DL routinely swaps out parked airplanes with active ones to equalize the time on the airframes before a major overhaul is needed. Good business sense.
Just for the record, you have not lived until you have been on a 747 that blows an engine inflight. With a big KABOOM and an airframe rattling shudder, a flash of flame out the tailpipe and a lot of smoke. And the old girl doesn't even breath hard. The passengers freak--the crew are pissed because it means they won't get home on schedule.
diverted
There's pics?
Wouldn't imagine it would be anything more than an engine change and ferry the aircraft home.
Yakflyer
Wed Sep 23, 2015 2:54 pm
Any four engine airplane should be and typically is safer than a two engine airplane, but your statement about suffering no more maintenance issues than any other type is just not true. An ETOPS twin engine airplane is at least 50% if not more less likely to have an engine failure or shutdown than a four engine airplane. Additionally, ETOPS engines are required to be maintained to a higher standard than non ETOPS engines (that does not mean different operators do not maintain non ETOPS engines to the same standard). Statically you double the likelihood of an issue if you double your exposure.
questions
Wed Sep 23, 2015 3:05 pm
How much more fuel efficient is a 77W vs a 748? (ballpark figure)
mark2fly1034
Wed Sep 23, 2015 3:18 pm
A few photos from DL73 First one was at the gate area waiting for departure
http://i246.photobucket.com/albums/gg120/DVA4890/DSC_6938_zpsiu65hmyc.jpg
Fuel dump in flight
http://i246.photobucket.com/albums/gg120/DVA4890/DSC_6944_zpsvbyq4bdh.jpg
Using Air Stairs getting off the plane
http://i246.photobucket.com/albums/gg120/DVA4890/DSC_6945_zpsha7ug4ls.jpg
http://i246.photobucket.com/albums/gg120/DVA4890/DSC_6947_zpsdgj1j83f.jpg
readytotaxi
Wed Sep 23, 2015 3:20 pm
Quoting bhmdiversion (Reply 19):
Curious, once replacement has taken place can Delta return with the engine in the cargo bay or will Kalitta do the return trip?
Growing older, but not up.
MSPNWA
Wed Sep 23, 2015 4:15 pm
A lot of irony in this flight. It's a former NW freighter - a rare 742 - with, you guessed it, PW JT9 engines. The old PWs were carrying a newer PW.
airnorth
Wed Sep 23, 2015 4:29 pm
Quoting questions (Reply 29):
Good question, I often wonder the same thing, but there are so many variables.
Using Google this old thread popped up:
What Is The Fuel Burn Rate Of B777-200LR/300ER (by philippelouis1 Apr 26 2011 in Tech Ops)
Lots of heated discussion about "the numbers"!
This quote might help, but it does not include the 747-8:
Per previous posting by Zeke these are the fuel burn rates used by CX pilots for calculations
772/A343 6900kg/hr
A333 6000kg/hr
A346 8900kg/hr
744 11100kg/hr
77W 8100kg/hr
audidudi
Wed Sep 23, 2015 4:49 pm
Quoting DTWPurserBoy (Reply 26):
The DL B744 was actually en route from DTW>ICN when it encountered the hailstorm over China and continued on to ICN, and was subsequently ferried to MZJ when sufficient repairs had been completed.
DTWPurserBoy
Wed Sep 23, 2015 6:00 pm
Quoting audidudi (Reply 34):
Thanks for the clarifications. Mx friends had told me the ship would be retired.
captainstefan
Wed Sep 23, 2015 6:05 pm
Quoting northwestEWR (Reply 14):
I'm thinking that the phase of flight played a big role in the decision. Had they lost the engine at, say, FL340 halfway across the ocean I bet they would've continued the flight to Atlanta. However... losing the engine so early in the flight, and (possibly) not knowing if it's an isolated issue or one that can escalate to include other engines - it only makes sense to turn back. And that's just my opinion as an armchair pilot, I doubt the SOPs are that lenient.
Quoting MSPNWA (Reply 8):
From the mouth of a DL 744 Captain I spoke to two weeks ago in NRT, the biggest reason is that Delta is continually taking lower-time/better condition engines off the 747s and putting them on 767s, placing the higher-time more worn out motors from the latter on the former. While I haven't confirmed it with anyone else, that seems like a pretty plausible explanation. While unfortunate, It seems that DL would rather operate two 767s reliably than one 747 when forced to choose.
Long Live the Tulip!
mayor
Wed Sep 23, 2015 6:32 pm
Quoting DTWPurserBoy (Reply 35):
I thought they had to do some repairs, just to be able to ferry it to MHZ, where it's being retired.......but I could be wrong.
UA444
Wed Sep 23, 2015 6:36 pm
Quoting mayor (Reply 37):
They did a few repairs to permit them to get a ferry permit then flew it straight to the desert. It would've been retired this year anyway.
diverted
Wed Sep 23, 2015 6:41 pm
Quoting captainstefan (Reply 36):
Makes total sense really. I've heard of BA doing the same (And AC when they had them. Though that was from a college prof who was an ex AC captain, so I can't verify it's truth)
You have an engine failure on a 767, it's an emergency situation. Have it on the 744, it's an inconvenience.
I was under the same impression. They did a few temp repairs to get a ferry permit, and she went straight to the desert, and another ship was reactivated from the desert to replace her.
PSU.DTW.SCE
Thu Sep 24, 2015 3:19 am
Quoting captainstefan (Reply 35):
Never really paid much attention but is it true they use the same engines (and they are interchangable) of the DL (former NW) 744s and the DL 763s?
UA444
Thu Sep 24, 2015 4:32 am
Quoting PSU.DTW.SCE (Reply 39):
They are interchangeable. UA has used 744 and 763 engines interchangeably too.
flyDTW1992
Thu Sep 24, 2015 4:54 am
Quoting readytotaxi (Reply 30):
We didn't return to ATL with the bad engine, though we have done that many times before (just so happens we are doing a round-trip "engine rescue" for another major airline as we speak). It can't be carried on the lower deck, so it must be staying in AMS for now.
N776AU
Thu Sep 24, 2015 1:27 pm
If things get so bad they downgrade my 747 round trip to Minneapolis in November I'm gonna very upset
Careful, doors are closing, and will not reopen. Please wait for the next train.
diverted
Thu Sep 24, 2015 1:57 pm
Quoting flyDTW1992 (Reply 41):
Could they not put it onthe 5th pod and get it home that way? (On one of their birds, not the Kalitta bird)
QF744ER
Thu Sep 24, 2015 2:31 pm
Pretty sure only Rolls Royce engines can be carried in 5th pod under slung configuration.
diverted
Thu Sep 24, 2015 2:49 pm
Quoting QF744ER (Reply 44):
After doing a little more reading, it seems that it was an option on the 744, and only QF took it.
mayor
Thu Sep 24, 2015 4:02 pm
I have no idea if this is true or not, and I'm unable to determine the credibility of this, but someone has told me that they were told by DL senior leadership that the 747s would remains in service until 2024.
Don't shoot me, I'm only the messenger.........
papatango
Thu Sep 24, 2015 4:18 pm
It's time for Delta to retire all the 747's and pick up some used 777-300's!
diverted
Quoting mayor (Reply 46):
It's possible....the second batch is a few years newer than the originals. Though it wasn't that long ago DL announced their wind down plan for the fleet. I know things change often, but it does seem strange. I won't at all complain to see a few of them stay longer. However, it would be a bit weird to go to the museum in 2024 and see a 744 which has been there nearly 10 years, while some of her sisters are still flying. Again, not complaining though!
SELMER40
Thu Sep 24, 2015 9:19 pm
Quoting Western727 (Reply 24):
...fixed to fly again.
N668US is back in DTW.
Teaching this old dog a new trick
