elbandgeek
SkyWest Chooses Surface 3 For Pilots
Thu Oct 01, 2015 6:06 pm
https://blogs.windows.com/devices/2015/10/01/skywest-inc-chooses-surface-and-windows-10-over-ipad-for-7500-pilots/
Airlines replacing flight bags with tablets (of varying platforms) isn't really new, but to my knowledge OO/EV would be the first regionals to do so (correct me if I'm wrong). For all the choices airlines have with these either iPads or Windows or Android tablets and I'm happy to see Microsoft get some love. I know a few carriers use the Surface Pro but I think the non-pro is probably the best overall option because it has the size and weight benefit but also now has an intel atom CPU running full Windows as opposed to the ARM based RT (which I believe DL uses). For what it's being used for it doesn't really need the high-end specs of the pro but has the option for classic programs in addition to new style windows 10 apps.
boeingrulz
RE: SkyWest Chooses Surface 3 For Pilots
Thu Oct 01, 2015 7:56 pm
Does anyone know if these electronic flight bag tablets are subject to any FAA regulations?
32andBelow
Thu Oct 01, 2015 9:05 pm
Quoting boeingrulz (Reply 1):
They need to be approved by the FAA to be used in the cockpit.
N1120A
Thu Oct 01, 2015 9:12 pm
Quoting elbandgeek (Thread starter):
Yeah - the new Surface 3 is a major step up from the old RT ones. They have full Windows, so they can put programs that are not Windows apps on the computer. This is a good thing if they want to do things like put a reservations system on the computers.
C767P
Thu Oct 01, 2015 9:14 pm
Envoy, Compass and Republic have iPads. I don't believe any of them are required to have paper backups.
XE/EV has been receiving the Surface 3 since late July or early August.
Mir
Thu Oct 01, 2015 9:15 pm
Envoy has already done it.
-Mir
ScottB
Thu Oct 01, 2015 9:20 pm
For all the choices airlines have with these either iPads or Windows or Android tablets and I'm happy to see Microsoft buy some love.
Fixed that for you...
Quoting N1120A (Reply 3):
Most of those sorts of applications can be delivered through a web browser these days. And if SkyWest, Inc. were going to use custom enterprise apps on those tablets, you can bet MSFT would have highlighted it.
N1120A
Thu Oct 01, 2015 9:39 pm
Quoting C767P (Reply 4):
I'm a little surprised Envoy would have iPads and not Samsung, given how AA has gone.
Quoting ScottB (Reply 6):
Klaus? People have been looking for you
durangomac
Thu Oct 01, 2015 9:53 pm
Apps are already being developed and the Manual application was built in house. I suspect they will see a lot of apps built by the IT group specifically for the pilots.
Mir
Thu Oct 01, 2015 10:07 pm
Quoting N1120A (Reply 7):
AA has iPads in the cockpit as well.
-Mir
N1120A
Thu Oct 01, 2015 10:16 pm
Quoting Mir (Reply 9):
I thought they used Galaxy Tabs but just found they didn't. Was that the initial option?
Mir
Thu Oct 01, 2015 10:55 pm
Quoting N1120A (Reply 10):
As far as I know, they've never used anything but iPads. iPads were the first EFB application of a generic tablet - it took some time for others to follow - and AA was a pretty early adopter (IIRC, either they or AS were the first airline to use them).
-Mir
flyDTW1992
Thu Oct 01, 2015 10:59 pm
Republic doesn't, I worked on their EFB implementation. They needed backups during an initial trial period, but not anymore. Their pilots have iPad Airs and iPad Air 2s, I believe. Jeppesen's app was only recently extended to Windows if I remember correctly. It was not yet available last year when I talked to Jeppesen's sales people.
Now you're flying smart
LAXintl
Thu Oct 01, 2015 11:05 pm
Quoting Mir (Reply 11):
AA was the first US commercial carrier to receive FAA approval to use a tablet during all phases of flight in December 2011.
KELPkid
Thu Oct 01, 2015 11:41 pm
There's a plethora of good flight planning software that has existed for MS Windows since at least the late 1990's...a ready made library. They probably just picked something off the shelf to run on their tablets
EDIT: At any rate, I'm sure that they'll beat Apple on cost by a long shot, because the hardware is less expensive and requires no custom programming or integration
[Edited 2015-10-01 16:42:33]
32andBelow
Fri Oct 02, 2015 2:37 am
The second pilots iPad is the backup.
Quoting KELPkid (Reply 14):
I think the big advantage to apple is that you can go to an apple store and get it replaced on an RON or whatever if you accidentally smash it. I believe ours can be updated to company specs remotely and become good to go.
ericm2031
Fri Oct 02, 2015 4:32 am
I believe Mesa uses iPads too, not sure exactly, but have definitely seen a tablet in their cockpit and was quite surprised.
ScottB
Fri Oct 02, 2015 4:40 am
I don't really see that given that the base cost of the Surface 3 is identical to the most recent iPad. And it almost certainly will require custom programming to design proprietary apps which work with the tablet interface. A desktop app may run but it also might be near-impossible to use without the add-on keyboard and/or a stylus which add cost & complexity (styluses tend to get lost easily).
KELPkid
Fri Oct 02, 2015 4:54 am
Quoting 32andBelow (Reply 15):
Swap Apple Store with Best Buy. Problem Solved
KELPkid
Fri Oct 02, 2015 4:59 am
Quoting ScottB (Reply 17):
There's a lot more Windows programmers in the world than Apple App developers   And a fairly large library of already written code in Windows...especially in flight planning and navigation software!
b747400erf
Fri Oct 02, 2015 5:14 am
Quoting KELPkid (Reply 19):
Pilots have no interest in a flight planning application. The tablets are going to have a charts database application and a load and balance/takeoff application. Custom programmed for the tablets to be stable. Or they could cut costs and only use a web app inside a browser. It does not matter that there is a "large library" or "more programmers" the only important fact is the ability to program stable applications for pilots to use.
