barney captain
Sky Airline A319 Engine Cowl Doors Separated
Thu Oct 15, 2015 5:45 am
Why does this image look so familiar?  Wink
 http://avherald.com/img/sky_a319_cc-aic_santiago_151014_1.jpg
http://avherald.com/h?article=48dca107&opt=0
[Edited 2015-10-14 22:46:28]
Southeast Of Disorder
rlwynn
RE: Sky Airline A319 Engine Cowl Doors Separated
Thu Oct 15, 2015 6:12 am
That is a major design flaw and I do not understand ehy after so many times the aviation authorities and not demanded a fix.
I can drive faster than you
bennett123
Thu Oct 15, 2015 7:28 am
Is this issue. Specific to the A319.
What about the NEO?.
Clydenairways
Thu Oct 15, 2015 8:00 am
Quoting bennett123 (Reply 2):
No i've seen photos of the same thing on 320's over the years. It's odd they haven't redesigned it by now as it keeps happening.
DocLightning
Thu Oct 15, 2015 8:08 am
Specific to the A320 CEO series. The mechanism that holds the cowling together on the bottom can appear locked when it is not locked.
-Doc Lightning-
-Carl Sagan
sulzerjan
Thu Oct 15, 2015 8:34 am
There is no mechanical issue with the locks,
It is just that people don't like to bent over / want to sit on there knees to check, that's human behavior.
But as humans are humans they should change the design anyway, even though there is nothing wrong with it.
AIRWALK
Thu Oct 15, 2015 10:26 am
There's a video of it
http://www.youtube.com/watch?v=8pXQ4jtrMcM
and yes, ignore the video title
I'm sure this thread will take off soon
caoimhin
Thu Oct 15, 2015 11:29 am
Quoting sulzerjan (Reply 5):
I understand your meaning, and I'm glad you agree with the conclusion that the design should be changed. However, as you point out, human factors are important. In the more abstract sense, I think you can make an argument that something is wrong with a design if the interaction between humans and that design results in multiple failures via the same exact mechanism.
What's more, if inspection protocols are not uniformly in agreement that a physical check, rather than a visual check, of the doors is necessary, then the design is insufficient if it would satisfy the visual check while in fact being open.
Still, your point is well taken; when properly latched, it's secure.
I used to work in the amusement ride industry, where this sort of differentiation between visual and physical verifications of devices (restraints, access panels, etc.) is also quite important. An apparently secured restraint that is not physically verified as secure could result in serious injury or fatality.
As an additional industrial crossover (of which I find many in reflecting upon aviation), I note that one commenter on AVH says something like, "Even my dishwasher won't start unless it's locked." Indeed, a very good point that also applies to amusement rides. Many, especially newer, attractions simply won't start without proximity sensors triggered, unless the ride is in some sort of maintenance mode. This is a very simple and crude electro-mechanical safety feature that has probably saved more lives than we'll ever realise. Why is such a feature not common on a turbofan engine? Absent a maintenance bypass mode, the engine should not start without the sensor triggered.
Aesma
Thu Oct 15, 2015 11:51 am
Hasn't it already been redesigned ? I seem to recall so.
Or rather, it's the manual/checklist that has been redesigned to emphasize that weak point.
[Edited 2015-10-15 05:41:37]
starrymarkb
Thu Oct 15, 2015 12:51 pm
IIRC Easyjet have a added big "this door must not be left closed and unlatched" stickers on the cowls of their Airbii
Tristarsteve
Fri Oct 16, 2015 9:22 pm
Quoting Aesma (Reply 8):
Yes there is an Airbus mod being trialed this month.
the fwd latch is locked with a key. This key can only be removed when the latch is secured for flight. The key has a big red streamer on it, and two keys are kept in the flight deck for the crew to check every departure. It is being fitted to a few aircraft this month to see if it works.
a36001
Fri Oct 16, 2015 9:33 pm
Well I'm glad they are making a change to the cowling locking mechanism (after only what? 25 years)
Can the debris from an engine cowling be big and strong enough to cause significant damage to the vertical and or horizontal stabiliser? Enough damage to cause control issues? what would happen if the cowling detached and hit said control surfaces at 800km/h as opposed to 220km/h? The piece that broke off looked pretty big to me and was headed straight towards the back of the plane!
The potential for disaster here boggles the mind!
tb727
Fri Oct 16, 2015 11:32 pm
I heard the other day that the NEO will actually have a warning on the ECAM if they aren't latched since they will be only 17" off the ground and harder to see. I'll still be looking.
I always look from 4 different angles at each engine on my walk around. That's about the last thing I want to happen to me.
e38
Fri Oct 16, 2015 11:44 pm
and I always count as well . . . on the A-319 aircraft (A-320 as well) powered by the CFM-56 series engine there are seven latches on the bottom of each engine.
e38
bluesky73
Sat Oct 17, 2015 12:02 am
Seems to be two posts on this.
http://m.liveleak.com/view?i=694_1444975730
So is this same issue BA had with G-EUOE back in May 2013? BA A319/320 engines are IAE V2500 but looks to be problematic (if rarely) on the A32X.
