LHRlocal
Mahan Air 747 Engine Parts Falls Off On Take Off
Thu Oct 15, 2015 11:57 am
Link to article on Sky News:
Not 100% clear if this was all of the engine or part of the #3 engine.
Mahan air 747 take off from Mehrabad
Plane parts hit the fuselage on separation.
Landed safetly afer incident.
http://news.sky.com/story/1570057/pa...planes-engine-falls-off-in-mid-air
LHRlocal
bennett123
RE: Mahan Air 747 Engine Parts Falls Off On Take Off
Thu Oct 15, 2015 12:02 pm
The article says "engine part", but the picture seems to suggest otherwise.
trent1000
Thu Oct 15, 2015 12:08 pm
MSN News reporting
The 747, with 300 passengers on board, was on a flight from the capital's Mehrabad airport to Bandar Abbas in southern Iran when one of its engines crashed into a nearby field, forcing the jumbo to return and make an emergency landing.
Would it be a 742?
GILLESPATRICK
could have been a worse case scenario if the part's have hit the fuselage or the stabilizer with a full plane loaded
thanks all went well
factsonly
Thu Oct 15, 2015 12:11 pm
NAV30
Thu Oct 15, 2015 12:15 pm
Just plain 'wonderful,' in my view, that no-one appears to have been hurt, in the air or on the ground.............
N14AZ
Thu Oct 15, 2015 12:23 pm
Quoting NAV30 (Reply 5):
The pilots were reading a.net during take-off and read your most favorite statement (the time of 4-holers is over) so - unlike many a.netters - they did not start discussing but immediately took action and discharged one engine ....
Just kidding, yes, thankfully nobody was hurt.
Can anyone explain under which circumstances such a large part of the engine can fall off?
Part147
Thu Oct 15, 2015 12:31 pm
Quoting N14AZ (Reply 6):
You beat me to it
It's better to ask a stupid question during training, rather than make a REALLY stupid mistake later on!
ltbewr
Thu Oct 15, 2015 12:49 pm
Of course, this gets into one of the serious problems the sanctions as to Iran can lead too. I suspect there is serious damage that will make it questionable about continued operation of this aircraft.
747classic
Thu Oct 15, 2015 2:37 pm
A Boeing 747-3B3 operated by Mahan Air returned to land at Tehran-Mehrabad Airport, Iran after it lost part of the no. 3 engine.
The rear, Low Pressure Turbine, section of the Generel Electric CF6-50E2 engine broke away and fell to the ground in the Eslamshahr area.
See : http://aviation-safety.net/wikibase/wiki.php?id=180400
Operating a twin over the ocean, you're always one engine failure from a total emergency.
qslinger
Thu Oct 15, 2015 5:07 pm
With sanctions being lifted on Iran..when is Iran likely to order from the big 2? I am guessing all these years of embargo has probably created a great bit of thirst for planes, among other things.
Raj Koona
penguins
Thu Oct 15, 2015 5:24 pm
Quoting factsonly (Reply 4):
Reminds one of ELAL 1862 B742 over Amsterdam 1992:
Also reminds of AA 191.
tjcab
Thu Oct 15, 2015 5:26 pm
Quoting ltbewr (Reply 8):
Probably not; happened to an air Canada 777 in 2012 (may) just after takeoff at YYZ. we need to know the facts.
AIRWALK
Thu Oct 15, 2015 5:41 pm
Engine 3 and 4 were both shut down - part of Engine 3 separated and Engine 4 was shut down due to an oil pressure warning.
I'm sure this thread will take off soon
747classic
Thu Oct 15, 2015 6:31 pm
Several uncontained CF6 engine failure are recorded.
A safety recommendation was issues by the NTSB in May 2010 :
http://www.ntsb.gov/safety/safety-recs/recletters/A-10-098-101.pdf
Despite that, an identical CF6-50E2 uncontained engine failure happened in Cairo, with HS-VAC, a former KLM 747-306M, operated by Phuket Airlines (leased to Saudia)
See : http://aviation-safety.net/database/record.php?id=20100717-0
And : http://www.baaa-acro.com/2010/archiv...shap-of-a-boeing-747-300-in-cairo/
http://www.baaa-acro.com/wp-content/uploads/2010/07/HS-VAC-1.jpg
HS-VAC, identical damage pattern
[Edited 2015-10-15 11:43:50]
Adipasquale
Thu Oct 15, 2015 6:36 pm
DH8A DH8B CR1 CR2 CR7 CR9 E45 E70 E75 E90 D93 M88 318 319 320 321 333 343 712 732 733 734 73G 738 739 744 752 753 762 763 772 77L 77W
dashdrvr
Thu Oct 15, 2015 9:13 pm
No problem it was just the muffler that fell off.
rbavfan
Thu Oct 15, 2015 9:52 pm
Quoting bennett123 (Reply 1):
Pics show tailpipe fell off. But the news noted the 300 terrified passengers so it would make CNN.
solarflyer22
Fri Oct 16, 2015 12:31 am
Quoting tjcab (Reply 12):
It's hard to say. Neither NTSB nor Boeing would have made any effort to share the information with Iran and if it required a new part Iran would not have been able to purchase it. I suspect the NTSB bulletin would have required a new part of some sort.
Quoting qslinger (Reply 10):
Next year.
As I've said many times on ANET, and received heat for it, aviation parts sanctions on Iran are a threat to both civilian passengers in the air and on the ground and violation of ICAO's charter promoting safe aviation. The US in particular is after Mahan Air because they fly into Syria and this event happened literally 1 day after a long expose promoting sanctions on them.
http://www.businessinsider.com.au/th...he-assad-regimes-lifelines-2015-10
Wouldn't surprise me if CIA was actively sabotaging Mahan's frames. Yes, I know sounds like a conspiracy theory.
UA444
Fri Oct 16, 2015 2:55 am
The Iran Supreme Dictator just called off all talks with the US a few days ago.
tozairport
Fri Oct 16, 2015 7:07 am
Quoting solarflyer22 (Reply 18):
No, Iran can start using it's own metal to fly it's people around. If the country is so great, then develope a respectable aviation industry and stop using the assets of the West which it so hates. It is really simple. They do not have a right to Boeing jets or the spare parts to fly them. Done.
Meet the new boss, same as the old boss.
777way
Fri Oct 16, 2015 7:26 am
Boeing is itching to sell planes to Iran, your opinion is irrelevant.
CrimsonNL
Fri Oct 16, 2015 7:39 am
Quoting tozairport (Reply 20):
Sure, because what country wouldn't want to invest in a multi-billion dollar aviation industry without prior experience. After all, how hard can it be? It goes so easy for an experienced manufacturer like Boeing that their newest model was only delayed EIS by about 3 years. And it's so complex they can't even manufacture all the parts themselves so they outsource it to places all over the world. So yeah, really simple.
Martijn
a300
Fri Oct 16, 2015 8:07 am
Quoting 747classic (Reply 14):
My thoughts exactly. Two others have also involved Iranian aircraft: the Iran Air event at ARN in January 2010 and Qeshm Air at IST earlier this year. Both were A300-605R with CF6 engines.
The mother of them all was the July 1989 United DC-10-10 crash landing at Sioux City, Iowa (IATA code SUX, perhaps pun intended). The UA flight involved the CF6 in the number 2 position.
Boland Aseman Jayegah Man Ast.
747classic
Fri Oct 16, 2015 8:54 am
Quoting a300 (Reply 23):
A300-605R aircraft have CF6-80C series engines installed.
The CF6-80A/C engine is an advanced development of the earlier CF6-50 series engine, but despite superficial resemblance, it is a completely new engine with no interchangeable parts
The Mahan Air B747-300 has the older CF6-50E2 engine type installed.
CF6-50 series and the partly identical CF6-6 series are also installed at :
DC10-10 (CF6-6)
DC10-30 (CF6-50C, C2, C2B)
B747-100SR (CF6-45*), B747-200 (CF6-50E, E2), B747-300 (CF6-50E2)
All A300 series (CF6-50A, C, C2), except -600(R) series.
* CF6-45 is a derated CF6-50 engine.
[Edited 2015-10-16 02:06:06]
solarflyer22
Fri Oct 16, 2015 1:49 pm
Typically American attitude. If you endanger someone else's civilians over foreign policy then don't complain when I dunno they take your metal and fly into your civilian buildings? There is no requirement to deliver safety related parts but be prepared for the consequences and don't assume that it's just Iranians being killed. Eye for an Eye means you go blind too.
Adipasquale
Fri Oct 16, 2015 1:59 pm
Lol       Iran is not nearly as bad a place as some would like you to think it is.
In all seriousness though, you do realize that if Iran bought new Boeing jets, it would be good for the American economy, right?
jetwet1
Fri Oct 16, 2015 2:38 pm
Quoting solarflyer22 (Reply 25):
To take that argument a step further, if you are endangering YOUR civilians by allowing them to fly in unsafe aircraft, then maybe you should fly your aircraft into YOUR buildings ? Responsibility for your own actions.
Really, taking the situation and justifying 9/11 with them is really not cool, and certainly has no place on A'Net.
Anyways, i'm glad to see the aircraft made it down safe and sound.
747classic
Fri Oct 16, 2015 4:00 pm
Quoting 747classic (Reply 24):
Below is a link to the FAA AD-2012-92-07 regarding the LPT rotor stage 3 disk failures of the CF6-45/50 series, as installed at the Mahan Air 747-306 aircraft.
We don't know if all maintenance requirements, mentioned in this FAA AD, have been completed by Mahan Air TD.
See : http://rgl.faa.gov/Regulatory_and_Gu...57996004e81d3/$FILE/2012-02-07.pdf
flyingcat
Fri Oct 16, 2015 5:33 pm
Quoting 777way (Reply 21):
Interesting newsletter on the potential Iranian aviation market summarized by this great line:
"The lesson: an aging legacy fleet doesn’t necessarily indicate a strong replacement market. In fact, very often it indicates that there’s really no market at all."
Richard Aboulafia June newsletter
aryonoco
Sat Oct 17, 2015 12:27 am
Quoting flyingcat (Reply 29):
Richard Aboulafia has been spouting that nonsense for a while. Unfortunately, reality will prove him wrong.
Expect a big Airbus order from Iran in 2016.
solarflyer22
Sat Oct 17, 2015 2:14 am
I mean he has to be basically crazy. They are actively talking about 400 orders and if you look at the internal and external travel rates its very high. They have around 3 million tourists per year which can easily double post sanctions.
Quoting jetwet1 (Reply 27):
Try that argument with Turkey or Dubai when one these bird sheds an engine over downtown and kills some royal family in their Bentley. "ITS YOUR FAULT, you let them land after all! and they decided to fly an unsafe plane!"
Yeah its the internet. This is the place for that. And I'm not justifying it but if you put innocent lives at risk over nebulous foreign policy goals, then you own the consequences.
Either way, I've always said, don't feed the hand that bites you. I'd actually give Airbus the coveted M word if they dumped US suppliers. I'd offer them a 25 year monopoly in exchange for punting US parts.
PlanesNTrains
Sat Oct 17, 2015 2:41 am
Actually, all our opinions are ultimately irrelevant.
What an odd connection to make.
I guess you believe that us having sanctions justifies 9/11 type events, but I see it somewhat differently: You don't have a safe plane, don't fly it. Whether you agree or disagree with the sanctions is a separate issue. No one is holding a gun to their head and saying "Now go fly this unsafe aircraft over a city and see what happens".
-Dave
-Dave
MAX’d out on MAX threads. If you are starting a thread, and it’s about the MAX - stop. There’s already a thread that covers it.
777way
Sat Oct 17, 2015 8:33 am
But that event wasnt even linked to Iran sanctions, almost all of the men were from affluent Saudi Arabia.
747classic
Wed Oct 21, 2015 6:14 am
Another identical CF6-50 failure (March 26 2009) at the DC10 engine position #2, NTSB final report just released :
http://www.avherald.com/h?article=4171239c&opt=0
diverted
Wed Oct 21, 2015 9:40 am
Quoting solarflyer22 (Reply 25):If you endanger someone else's civilians over foreign policy then don't complain when I dunno they take your metal and fly into your civilian buildings?
Um, you folks are all aware it was Saudis who flew airplanes into your buildings right? The same Saudis Lockheed Martin is selling $11B worth of combat vessels to. The enemies of the Iranians. The whole anti-Iran agenda in the middle east is only benefitting the house of Saud and their business partners.
