timz
What's This? ("meteorological Equipment" SFO 1967)
Fri Oct 16, 2015 1:30 am
barney captain
RE: What's This? ("meteorological Equipment" SFO 1967)
Fri Oct 16, 2015 1:45 am
Wow, absolutely no idea - interesting find.
It looks like something that would fire a laser.....
http://www.whatsageek.com/wp-content/uploads/2014/12/Dr-Evil.jpg
Southeast Of Disorder
tribird1011
Fri Oct 16, 2015 7:49 am
Although it seems "fancy" my guess is a wind measuring device (speed/direction) -- only a guess though
WIederling
Fri Oct 16, 2015 3:59 pm
Quoting tribird1011 (Reply 2):
only a guess though
The part pointing away from the viewer is a helical antenna. The plate with radials the reflector.
I'd guess the diameter is around .5m? that would fit ~300MHz ?
I can't make anything out of the two "thingies" projecting towards the viewer.
they seem to be movable up and down.
Murphy is an optimist
jox
Tue Oct 20, 2015 6:35 am
I asked some radio amateur friends. They thought it is a helical antenna that is (was) used to listen to weather balloons. The "fins" at the back are probably counterweights of some sort that also takes the wind load that otherwise would try to rotate the antenna. The reason that they are pointing in different directions is probably that they shouldn't block each other regardless of wind direction.
timz
Tue Oct 20, 2015 9:30 pm
Do airports still use weather balloons? If not, what has replaced them?
WIederling
Tue Oct 20, 2015 9:56 pm
Don't know about airports.
But the National weather service ( Germany, Europe in general?)
still does start ballons on a regular basis:
http://www.radiosonde.eu/RS00-D/RS02H-D.html#ancre220984
I've visited Schleswig Wetterwarte ~15 years ago.
They had a start at noon and at midnight each day.
( Seem to still do so going by my link.)
Afair the tracking antenna ( via the radar reflector on the payload ) there was a parabolic mirror.
Can't remember what they used for data reception ( ~400Mhz).
Viscount724
Wed Oct 21, 2015 12:44 am
Quoting timz (Reply 5):
Weather balloons are still in widespread use. This video is a year old.
http://www.youtube.com/watch?v=UUe8KyIEfrU
PSAjet17
Wed Oct 21, 2015 4:02 pm
Yes they launch from 102 sites in the US.
http://www.ua.nws.noaa.gov/factsheet.htm
timz
Wed Oct 21, 2015 5:11 pm
Do those 102 sites have helical antennas like the one at SFO? If not, what instead? Anyone seen circa-1967 pics of antennas like that at other airports?
nikeherc
Wed Oct 21, 2015 5:42 pm
It is a helix or helical antenna. The flat plate is not actually a reflector, but is the antenna ground plane. Helix antennae have good gain and are quite directional. The structures behind the ground plane are counter weights.
DC6 to 777 and most things in between
