777GE90
VS A340 Arrives Without Winglet?
Sat Oct 24, 2015 8:05 pm
I just noticed this: https://www.airliners.net/photo/Virgi...Airways/Airbus-A340-642/2721621/L/
Anyone know what happened to the winglet?
coolian2
RE: VS A340 Arrives Without Winglet?
Sat Oct 24, 2015 8:08 pm
The aircraft hit a fence at JFK so they removed it.
Q300/ATR72-600/737-200/-300/-400/-700/-800/A320/767-200/-300/757-200/777-300ER/
747-200/-300/-400/ER/A340-300/A380-800/MD-83/-88/CRJ-700/-900
777GE90
Sat Oct 24, 2015 8:09 pm
Oh right? When did this happen?
So it is allowed to fly without it's winglet? Did they have to remove the one on the other side too?
coolian2
Sat Oct 24, 2015 8:11 pm
I don't know. I just read the caption on the photo.
It's fine to fly as I understand, from the actual experts replies to this previously there are some fuel burn penalties.
rbavfan
Sat Oct 24, 2015 8:14 pm
Its says what happened in the photos caption. See reply 1 for verification.
Note: Im shocked at the number of times people have asked questions about a photo on a*net without reading the caption first. This is a site heavily geared for reading after all.
starrymarkb
Sat Oct 24, 2015 8:16 pm
Yep, A330/A340 can fly with a single Winglet. IIRC so can the B744
777GE90
Sat Oct 24, 2015 8:17 pm
@rbavfan,
I read the caption and it said exactly: "Anybody noticing anything different in this picture? You have got to love Heathrow for the variety and sheer number of airliners that come and go in a steady stream, but for sure it is not an everyday event to photograph an A340 missing a winglet! Don't know what actually happened, but looking closely it seems it was ripped off [Canon 7DII + EF 100-400 f/4.5-5.6L IS II USM].". However, it was updated after I posted this thread.
Regardless, thank you for posting.
[Edited 2015-10-24 13:35:43]
coolian2
Quoting rbavfan (Reply 4):
I didn't verify anything but quote the caption almost verbatim.
EZYAirbus
Sat Oct 24, 2015 8:30 pm
Similar thing happened a few years ago with an Air Canada 747-400 arriving at Heathrow missing a winglet.
Photo © Ryan Hemmings
Glenn
http://www.glenneldridgeaviation.com
777GE90
Sat Oct 24, 2015 8:33 pm
Quoting starrymarkb (Reply 5):
Quoting ezyairbus (Reply 8):
Ah that's interesting, I'm surprised they can operate with only one winglet. I would have thought for aerodynamic reasons they would either have to have both or none of them. But guess I was wrong, thanks for clearing that up :P.
starrymarkb
Sat Oct 24, 2015 8:46 pm
From what I've read it's more a paperwork issue rather then engineering reasons. The aircraft is tested with both winglets and with one missing, but the OEMs don't test for both (I'm guessing the loss of one either on the ground or during flight is considered more likely then the very slim chances of loosing both)
FredrikHAD
Sat Oct 24, 2015 9:14 pm
Since the winglets lower fuel burn, that has to mean that there is more drag on the wingtip that lacks a winglet. Apparently, fuel savings are 4-6 %, so the momentum of the extra drag at the end of the long wing should be anything but insignificant. I'd be tempted to guess that there's a button somewhere in the menus to klick when you remove/lose a winglet that makes avionics compensate for the asymmetric drag...
/Fredrik
[Edited 2015-10-24 14:29:35]
migair54
Sat Oct 24, 2015 9:44 pm
Quoting FredrikHAD (Reply 11):
The rudder will compensate the difference in drag, but we are talking about a very little difference.
There's a document in all the planes called CDL Configuration Deviation List, any external item can be checked in that list and if they are missing that document will tell how to dispatch the plane, if it's possible, and it will give a reference to another place to calculate the penalty for the extra fuel or the conditions, maybe not able for etops, or in case of icing conditions etc...
Quoting coolian2 (Reply 3):
I am not sure how much will be the penalty but I think maybe around 2-3%.
Quoting 777GE90 (Reply 9):
A winglet is not a big issue, much more penalty and bigger issue if for example when Qantas used to carry a 5th engine under the wing, or ferry a DC-10 on 2 engines, that has much more complex preparation. It's very interesting issue.
LAXintl
Sat Oct 24, 2015 9:59 pm
Quoting 777GE90 (Reply 2):
Search and you find
VS Jet Wing Clips Blast Fence At JFK (by readytotaxi Sep 19 2015 in Civil Aviation)
zkncj
Sun Oct 25, 2015 2:38 am
About 15 years back an UA 744 was pushed into the Terminal at AKL, they simply removed the Winglet and after some checks headed back to LAX
conaly
Sun Oct 25, 2015 3:58 am
A removed winglet has somewhat only a very minor effect on the operation of the aircraft. In fact, some airplanes could operate with a much higher imbalance on either one of the wings:
Photo © Steve Ruttley
Photo © Sunbird Photos by Don Boyd
Photo © AirNikon Collection-Pima Air and Space Museum
And my personal favorite:
Photo © Norman Gage
Airports 2019: ADB, ALG, AMD, ATL, BOS, CTS, DEL, DTW, DUS, EWR, FRA, FUK, HAM, HIJ, HND, IST, JFK, MUC, NGO, NUE, OKA, PHL, SIN, STN, YYZ
Planned 2019: BOG, CDG, FRA, MUC, NUE, ZRH
LAX772LR
Sun Oct 25, 2015 5:09 am
Quoting conaly (Reply 16):
Heck, the #4 engine looks like it's hanging on by a thread as well!  Wow!
strfyr51
Sun Oct 25, 2015 5:23 am
Winglets are auxiliary structure. Nice to have but not necessary for safe flight. they're listed in the Configuration Deviation List
or the ICAO DDG Dispatch Deviation Guide . No winglet is primary structure but they can cost a penalty in range and performance.
jeffh747
Sun Oct 25, 2015 2:51 pm
The Aerolineas Argentinas A340 that hit the AF 77W in MIA a few years back had to have the winglet removed. It actually flew for quite a few months (maybe a year or two?) before they fixed it IIRC
A318 A319 A320 A320neo A321 A321neo A332 A333 B717 B727 B734 B73G B738 B739 B752 B762 B763 B772 B788 CRJ2 DHC6 DHC8-300 E145 E190 MD82 MD83 MD90 SF340B
Whiteguy
Sun Oct 25, 2015 3:03 pm
Quoting strfyr51 (Reply 17):
Depends on the aircraft.....
flylku
Sun Oct 25, 2015 3:18 pm
Quoting zkncj (Reply 14):
Do you know how long it was delayed? Hours? A day?
...are we there yet?
Airbus_A340
Sun Oct 25, 2015 3:49 pm
You are looking at an approximately 1.3% fuel penalty for 1 missing winglet on A340 aircraft and 1.2% on A330.
People. They make an airline. www.cathaypacific.com
AirlineCritic
Sun Oct 25, 2015 5:03 pm
Quoting conaly (Reply 15):
Photo © Norman Gage
Wow. The caption says that the engine was carried on main deck. So we still had a four-holer, but one of the engines was in the cargo space!
XAM2175
Sun Oct 25, 2015 10:24 pm
Quoting LAX772LR (Reply 16):
The slot in the pylon accommodates the thrust reverser sleeve.
LAX772LR
Mon Oct 26, 2015 3:24 am
Quoting XAM2175 (Reply 23):
I'm aware. I'm referring more to the build-up of soot that's apparently been there for quite a while, and runs the risk of masking rust/corrosion.
727LOVER
Mon Oct 26, 2015 3:27 am
There's actually a disagreement about this pic in the photography forum:
Exaggerated Photo Comments (by G-CIVP Oct 24 2015 in Aviation Photography)
"We must accept finite disappointment, but never lose infinite hope." - Martin Luther King, Jr.
Viscount724
Mon Oct 26, 2015 3:39 am
Quite a few photos in the database of aircraft operating with only one winglet.
