Quoting Qantas744er (Reply 134): Regarding the fuel: Russian operators have been tankering as much as possible within Russia, to save on refueling outside the country. This due to the devaluation ofnthe ruble and thus significant increase in foreign fuel costs. |
Quoting EMAman (Reply 146): The captains wife has been saying that he had many concerns about the condition of the aircraft. Does anybody believe that this is a credible lead in the investigation? |
Quoting EMAman (Reply 150): |
Quoting cougar15 (Reply 151): A321 wont make it there & back at full load with tankered fuel from origin! |
Quoting EMAman (Reply 150): CNN are reporting this morning a mid-air break up. This certainly could be entirely consistent with the bomb theory, however, it certainly gives a lot of weight to the bulkhead theory, particularly in view of the historic repair and the reports that are starting to come in about the condition of the aircraft. I am not favouring a missile based on the fact that ISIL supposedly do not have the capability and the state of the wreckage that I have seen is not consistent with a missile. CI611 all over again?? |
Quoting by738 (Reply 156): Has MetroJet been grounded? thought I caught something on the news |
Quoting tu204 (Reply 145): From what I can gather, the investigation will be Egyptian/Russian with assistance from French and German specialists. |
Quoting lancelot07 (Reply 152): I don't believe any pilot in civil aviation would fly a plane with known serious issues. |
Quoting wjcandee (Reply 159): CNN are idiots. |
Quoting liquidair (Reply 153): But the fr24 plot shows - to + 6000FPM descent then climb... Within 20 seconds. Would that much difference be possible to explain if the bulkhead went? |
Quoting EMAman (Reply 162): the climb could have been more rapid to start with due to the reduced weight and drag of losing the tail section. |
Quoting horstroad (Reply 163): The horizontal stabilizer produces downward lift. Gravity also forces it downwards. So with the tail missing you would expect the nose to go down as the tail does not balance it out anymore. |
Quoting EMAman (Reply 164): Well perhaps I misread the original post anyway, because actually it says that the ADSB showed a decent before a climb. Perhaps it did descend, and then climbed briefly following some further failure event. |
Quoting AIRWALK (Reply 165): That could be the result of a phugoid, not with completely erratic climb and descent rates though |
Quoting EMAman (Reply 162): Quoting liquidair (Reply 153): But the fr24 plot shows - to + 6000FPM descent then climb... Within 20 seconds. Would that much difference be possible to explain if the bulkhead went? |
Quoting jetblueguy22 (Reply 116): Where did you read this? I just find it unbelievable that anything besides the FDR and CVR still work after looking at the crash site. Not to mention getting service in the Sinai? I can't get service in the elevator in my building a kilometer from the tower, never mind in the middle of a desert. |
Quoting liquidair (Reply 153): Would that much difference be possible to explain if the bulkhead went? |
Quoting CF-CPI (Reply 168): I am just speculating like the rest of you, but bulkhead blowout would be consistent with cruise flight, where pressure differential has maxed out. |
Quoting crownvic (Reply 172): 206 replies on Pt 1 and now 120 replies on Pt 2 and all useless except for the photos and reply 77 |
Quoting PanAm1971 (Reply 177): |
Quoting crownvic (Reply 178): yes my bad when I started to post it was at 120 but was delayed when I hit the post message..either way I agree and get frustrated at all the speculation on a public forum |
Quoting Aither (Reply 181): How it could not be a bomb, a missile, or someone crazy taking controls ? modern aircraft don't explode mid air, even when there is an engine breakup. |
Quoting aircatalonia (Reply 182): This almost proves foul play, doesn't it? Has any modern airliner ever broken up in flight by accident? |
Quoting francoflier (Reply 107): Egypt has already started to proffer its own truths to save face... They'd rather blame the airplane straight away rather than acknowledge the presence of islamist radical activists on its soil and its lackadaisical airport security. |
Quoting SAS A340 (Reply 117): ""According to Russian news media, investigators will looking through Domodedovo Airport who was the plane's base. Investigators will also take samples of jet fuel at the site where the plane was last refueled, the Russian city of Samara."" http://www.aftonbladet.se/nyheter/article21680956.ab Ok.... that can´t be right... right? regarding the fuel? Don´t you refuele from the airport you take off from? or did it come from Samara with no passengers? |
Quoting dc863 (Reply 120): Depends on how expensive fuel is at that particular station. Some airlines during the '73/'74 Oil Embargo would tank up at airports where fuel was cheaper along their route. Of course that's a dire situation. |
Quoting ltbewr (Reply 190): Many are very concerned if this was a bomb or missile attack. |
Quoting BackSeater (Reply 192): Remotely controlled bomb? If the ISIL video is genuine (link in thread 1), the only sure way to film the explosion is to have detonated the bomb from the ground while the a/c was on its expected flight path, just overhead. No problem getting a radio signal to be received in the cargo hold. Fuel ignited later. Second incendiary device? |
Quoting GlenP (Reply 193): Sorry, but it is so unlikely to have been the result of a missile attack as to render that a dead end line of enquiry. |
Quoting EMAman (Reply 194): Remote control bomb possible but not for the reason you suggest, as most commentators have written the ISIS video off as a phoney animation. Unfortunately youtube had removed the video before I could look for myself. |
Quoting EMAman (Reply 195): 2. ISIS are widely reported not to have the capability of hitting a target at 31,000 ft |
Quoting GlenP (Reply 193): Other SAM systems would require dedicated vehicles & specialised radars, but there is no indication whatsoever of the Sinai based militants having access to these systems. |
