Quoting lancelot07 (Reply 98): FDR/CVR should be evaluated in a few days, then we will know more. Right now, very many things are possible. |
Quoting BEG2IAH (Reply 95): I had the same question. If horizontal stabilizers fell off, that could explain upside down impact. |
Quoting GlenP (Reply 99): I leave it to everyone to assess the report & judge for themselves, bearing in mind that it is not official. |
Quoting lancelot07 (Reply 98): |
Quoting traindoc (Reply 103): Since Russia will never be held accountable, why not retailate and take down one of their planes? |
Quoting GlenP (Reply 99): How much credence we give to unnamed sources on the investigating committee is debatable, but the Egyptian news outlet, Al Ahram is reporting that some info on the black box analysis has been released: http://english.ahram.org.eg/NewsCont....aspx |
Quoting joejosh999 (Reply 105): To be VERY clear the HS have not been located. |
Quoting Lowbank (Reply 51): would you have a look closely at the fan set, i agree it was static when it hit the floor. look at the nose cone. it looks like it has heat damage with the paint looking blistered |
Quoting dmsolovyev (Reply 94): |
Quoting peterinlisbon (Reply 113): |
Quoting lancelot07 (Reply 111): I also can't find any traces of the fuselage between wings to the tail. |
Quoting Pihero (Reply 112): Apart from a major explosive surge ( unlikely in my opinion ) I don't understand how the soot and burn marks could have happened. |
Quoting wjcandee (Reply 110): Here, it's the Wild West |
Quoting peterinlisbon (Reply 113): I think these days we should have cameras on the outside of the aircraft also feeding into the flight recorder. |
Quoting enilria (Reply 117): Quoting wjcandee (Reply 110): Here, it's the Wild West Western Malaysia? |
Quoting litz (Reply 101): Consider also, the flight recorders are located in the tail, which fell away from the rest of the wreckage ... So at some point it separated ... obviously there is not going to be any data past that point. |
Quoting wjcandee (Reply 119): The second statement is bewildering in its cluelessness. We all know that autopilots disconnect when they become unable still to control the aircraft, and that knowledgeable human intervention is required. It's a classic symptom of automation complacency. Of course, this guy wasn't flying the plane. But, geez. |
Quoting wjcandee (Reply 119): The second statement is bewildering in its cluelessness. We all know that autopilots disconnect when they become unable still to control the aircraft, and that knowledgeable human intervention is required. |
Quoting wjcandee (Reply 119): Another viable accident sequence therefore is: engine issues, not responded to properly by crew, autopilot attempts to maintain altitude/speed/whatever until it can no longer do so, and then says, "Your airplane, guys." Upon disconnecting, causes an upset that crew doesn't respond to properly. Corkscrew and crash. Damage to stabs, etc., reminiscent of China Airlines 6. |
Quoting Pihero (Reply 120): Not good for the ghouls and the voyeurs : no intimate details from the CVR... No final words... tragic, aint'it ?But in fact, the DFDR would have revealed what caused the breaking-up.The rest is very easy for the investigators to re-create and analyze. |
Quoting wjcandee (Reply 119): "Smirnov said the plane dropped 300 kph (186 mph) in speed and 1.5 kilometers (about 5,000 feet) in altitude one minute before it crashed Saturday." and |
Quoting wjcandee (Reply 119): Quoting enilria (Reply 117): Quoting wjcandee (Reply 110): Here, it's the Wild West Western Malaysia? I changed it to, |
Quoting GlenP (Reply 29): Sorry for the time difference incurred delay in responding to your post, however, I would ask whether you are aware that there is rather a lot of geography between Egypt, even the Sinai Peninsula, & Iraq? |
Quoting lancelot07 (Reply 30): They claimed to have it shot down. You need some pretty advanced and sizeable equipment to shoot down a plane at that height. Equipment that would not go unnoticed and can't be transported so easily. |
Quoting sandyb123 (Reply 122): With respect, it's a bit clueless to assume that when the computer says no, its straight to manual flying in an Airbus. |
Quoting KELPkid (Reply 126): I hope France is a party to the accident investigation, because if they're not, we may never know what happened IIRC, France has done the DFDR readout in most Airbus accidents because reading the data is anything but trivial... There's an ICAO annex that states that the accident investigation bureau of the country of manufacture gets to be party to the accident investigation. |
Quoting enilria (Reply 127): Isn't that info more likely from Flightstats or one of the ADS-B services and notoriously unreliable? I doubt they have analyzed any FDR data yet. |
Quoting WPIAeroGuy (Reply 125): Short of an SR-71-style unstart (which requires an SR-71), there shouldn't be any engine issue that makes the airplane that uncontrollable. I really hope its not another case of poor pilot management of a survivable problem. |
Quoting wjcandee (Reply 130): The BEA is in it, but they are doing the right thing and saying nothing until there is something to say. So is Airbus. |
Quoting KELPkid (Reply 126): I hope France is a party to the accident investigation, because if they're not, we may never know what happened |
Quoting dmsolovyev (Reply 94): Sorry if it was mentioned before, but some russian media reported that the involved a/c underwent a "D" Check in 2014 (link). That was not so long ago. I suppose if the airframe had any evident structural issues, they would have been fixed. |
Quoting WPIAeroGuy (Reply 125): Short of an SR-71-style unstart (which requires an SR-71), there shouldn't be any engine issue that makes the airplane that uncontrollable. I really hope its not another case of poor pilot management of a survivable problem. The vertical speed changes, and what we know of a debris field seem to indicate rapid damage or separation of the horizontal stabilizer. Unfortunately, knowing more than that may require more analysis than the DFDR can provide, since I'm sure once the initial failure occurred, the rest started coming apart rather quickly. |
Quoting Kaiarahi (Reply 136): So Egypt, France, Germany and Russia are parties. |
Quoting AIRWALK (Reply 135): I expect the Egyptian CAA to release some information in due time, but they are under no obligation to release the preliminary report to the public, so the full details of the accident may not be known until the release of the final report. |
Quoting Kaiarahi (Reply 136): So Egypt, France, Germany and Russia are parties. "State of manufacture" is usually interpreted to include the engine manufacturer, if different from the airframe manufacturer. |
Quoting AIRWALK (Reply 142): The AAIU also sent a team |
Quoting KELPkid (Reply 144): So by this criteria, the US should also be in on it (for the engines only, perhaps?). Both CFM and IAE are 50% US |
Quoting Lowbank (Reply 140): You needs to read QF32 more closely, had one part of the disc been a degree different the whole outcome would have been different. The disc part would go into the fuselage and clean out the other side. It has happened once but luckily the plane was in the ground. The disc part ended up in embedded in the engine after passing clean through the plane. |
Quoting Kaiarahi (Reply 136): I guess I need to repeat it again. |
Quoting 777Jet (Reply 143): Hopefully anything coming out of Egypt is more believable than their take on EgyptAir 990... |
