Quoting Stitch (Reply 184): We have actual numbers for the 787-9 and A350-900 posted by Chaostheory for his airline and it shows the 787-9 (and, by extension, 787-10) with a fractional advantage (200-400kg per hour over 3000nm) so the A350-900 and 787-10 appear to be effectively identical in terms of fuel burn (at least for regional missions) so the RFP will be influenced by other factors (price, capacity, availability, etc.). |
Again, Ferpe's numbers show the 787-9 as being better than the A350-900 (as you suggest) and the 787-10 about the same to a fraction (and a small one at that) worse.
Which seems to be in agreement with your comment , and
CT's numbers
Quoting tortugamon (Reply 188): If there was no weight benefit for the tube vs panel approach than I doubt Boeing would have done it the way that they did. |
Where did I say "no" advantage? I said "meaningful".
Where the A350-900 might have an OEW 6-8t higher than the 787-10, I'm willing to bet that only about 200kg of that would disappear if it were made from barrels..
Quoting tortugamon (Reply 188): The part I was interested in in the quote was the fewer fasteners part. I don't think that has changed. |
Again, it is unquestionable that too much is made of this. especially by the Aspire article
There are still vast numbers of fasteners in both aircraft to secure the CFRP to the frames.
You only have to look at the photo linked by Zeke
The number of extra fasteners required by 3 long seams is very small in that context.
So why did Boeing go barrels? Because they went for the moonshot and left
nothing on the table. Not even c. 200kg (IMO)
Whether that was actually worth it in the end is a question we will never know the answer to.
It unquestionably resulted in a superb aeroplane.
But then so have the panels on the A350
Quoting tortugamon (Reply 190): If the fuel difference was minimal I would think this wouldn't be too much of a negotiation (in favor of the A359) |
Why?
A 787-10 burning about the same fuel as an A350-900 will unquestionably have better fuel burn
per seat by dint of it's 3 extra rows.
The question is what other advantages might the A350-900 bring to offset this natural advantage to the 787-10?
