nitepilot79
QF 738 Tailstrike Investigation Results
Tue Nov 17, 2015 11:30 pm
I don't even remember this happening. It looks like the ATSB has finished the investigation, and here's what was found:
http://arstechnica.com/gadgets/2015/...as-caused-by-ipad-data-entry-fail/
Article quote:
"On August 1 last year, a Boeing 737-838 (VH-VZR) operated by Qantas performed a "tailstrike" while taking off from Sydney airport. Today, the Australian Transport Safety Bureau (ATSB) has concluded that the strike was caused by the co-pilot fat-fingering the plane's takeoff weight: instead of typing the plane's actual weight of 76,400kg into the iPad, he accidentally typed 66,400kg. As a result, the plane didn't have quite enough thrust to clear the runway without clipping the ground with its tail."
AIRWALK
RE: QF 738 Tailstrike Investigation Results
Wed Nov 18, 2015 12:14 am
Yeah, I don't recall there being a thread about it here. I haven't had the chance to look over it properly but an interesting point the report highlighted was that a QF procedure regarding a speed check could be misinterpreted. I believe QF advised a change to the FCOM because of this.
Link to report:
http://www.atsb.gov.au/media/5727742/ao-2014-162_final.pdf
I'm sure this thread will take off soon
777Jet
Wed Nov 18, 2015 12:19 am
Quoting nitepilot79 (Thread starter):
EK407 in a Boeing
TruemanQLD
Wed Nov 18, 2015 12:21 am
Quoting AIRWALK (Reply 1):
Probably didn't make the news at the time as the aircraft continued to its destination and only once they got there did they see that they had a tail strike (beyond the FA hearing a "Squeak")
