zchannel
NextGen Air Transportation System
Mon Nov 23, 2015 10:45 pm
Just saw this in my Facebook feed:
"Communities in San Francisco, Dallas, Denver, Phoenix and now Los Angeles are having major noise issues with the implementation of the Next Generation Air Transportation System (NextGen) that guides in jetliners using satellites instead of air traffic controllers."
The article states that it t promises a more efficient Air Traffic Control system by having satellites guide aircraft in and out of airports, but it comes at the cost of increased jet noise and has some NIMBYs pretty fired up.
Anyone know anything about this?
http://www.laweekly.com/news/is-mass...g-to-unsuspecting-la-video-6305819
ZChannel: Member FDIC
mcoatc
RE: NextGen Air Transportation System
Mon Nov 23, 2015 11:15 pm
Wait, if the satellites are doing everything, what on Earth are they paying me to do?
This is simply the implementation of new RNAV arrivals and departures, which is generally great for everyone not under an RNAV fix/airway. If you've ever seen the difference between a traditional SID and an RNAV, so far as noise profiles, it's quite stark. Now every plane is flying a nearly identical route, and ATC does very little to change the routes.....thats's the point, as they've been optimized for efficiency. Unfortunately, the same houses are now going to get hit with noise every time.
What I'm calling BS on....well, a lot of it. But where they're talking about the planes being lower, all of the metroplex airspace re-designs that have been occurring have profile climbs and descents as part of them. We know planes aren't fuel efficient down low, so the profiles allow fairly constant rate climbs and descents so jets spend LESS time down low, which is contradictory to what is being claimed by the folks in the article.
I guess we should blame the satellites....
mjoelnir
Mon Nov 23, 2015 11:21 pm
I would say NIMBYs on a roll. AFAIK the new system should reduce noise, reducing circling of waiting frames and allowing continuous approach with reduced engine use, less time over build up areas and so on. No idea how it should lead to increased numbers of low fling aircraft. I think they are afraid of increased aircraft numbers, but I do not believe in increased noise.
