Quoting FriscoHeavy (Reply 3): This is great news. However, I am a little surprised that the plane needs nearly 2 years of flight testing before first delivery, especially since it's a derivative of a plane that has been in business for some 40 or so years. |
Quoting DocLightning (Reply 74): Quoting WIederling (Reply 24): If this increases lift significantly before rotation you have a problem. That lift comes with induced drag that will take away from available thrust for acceleration. Not to mention if you have too much lift and the aircraft tries to start flying before Vr and then an engine goes out, you may not have enough control authority to remain directional control in a setting of asymmetrical thrust. Obviously, the people at Boeing know how to build airliners so they have some solution for this. |
Quoting Ruscoe (Reply 95): The new single-aisle airplane will deliver 20 percent lower fuel use than the first Next-Generation 737s and the lowest operating costs in its class – 8 percent per seat less than the A320neo |
Quoting astuteman (Reply 93): Nice to see MAX make an appearance. First flight is? |
Quoting 817Dreamliiner (Reply 73): photos in the database: |
Quoting by738 (Reply 111): cue repeated incident reports of winglet damage on ramp... recipe for disaster |
Quoting LAX772LR (Reply 115): In the ground it will be lighter on the tires than the NG How come? Bigger tires, or did you mean as a result of lift? |
Quoting StTim (Reply 98): marketing speak and as we know it has been repeated so often it becomes accepted fact. It may be true under specific considerations but yu could take other scenarios where it isn't true. It sort of reminds me of VW |
Quoting KELPkid (Reply 112): Just me or is the landing gear taller? |
Quoting astuteman (Reply 106): Is it perhaps worth pointing out that airlines that assessed both types, and are perhaps a tad more independent, are said to have put the difference at around 2 percent per seat? |
Quoting astuteman (Reply 106): That was said before the rumoured issue with the Leap 1B's SFC, and P+W's promise of a 2%-3% PIP on the A320 by 2018. |
Quoting StTim (Reply 23): One of the changes as I understand it is the length of the nose gear to allow the larger fans to fit. So to my mind this is going to give the MAX a slightly nose up attitude. |
Quoting lightsaber (Reply 52): Yes, the front gear is longer. |
Quoting CrimsonNL (Reply 78): increased length of the nose gear strut. |
Quoting roseflyer (Reply 117): The taller nose gear |
Quoting JAAlbert (Reply 122): It seems from the photos that the MAX is sitting a bit higher on its landing gear. |
Quoting bellancacf (Reply 125): Here's a (lone?) vote for the split scimitar wingtips, which appeal to me: I think they are well-shaped, give definition to the wingtip better than other winglets, and remind me, at least, of a hawk's primaries in strong flight. I'm looking forward to seeing them around. |
Quoting roseflyer (Reply 117): |
Quoting MaverickTTT (Reply 116): Quoting by738 (Reply 111): cue repeated incident reports of winglet damage on ramp... recipe for disaster I said the same when split scimitars went into service. So far, I've been wrong. |
Quoting Ruscoe (Reply 119): Quoting KELPkid (Reply 112): Just me or is the landing gear taller? I thought it looked taller also but the frame is "production" complete, not "customer" complete so it will be quite light. |
Quoting bobdino (Reply 92): ......................Combined with the winglets, re-lofted tail cone and other changes, Boeing still intends to deliver the 737 Max with a 14% overall improvement in specific fuel consumption......... |
Quoting StTim (Reply 102): I thought the most interesting word in there was "Intend" |
Quoting PEK777 (Reply 134): It just isn't a good looking airplane - and that is a scientific fact. |
Quoting PEK777 (Reply 134): It just isn't a good looking airplane - and that is a scientific fact |
Quoting bucky707 (Reply 132): You can only put so much lipstick on a pig. |
Quoting gatibosgru (Reply 136): Looks good! Excited for the NEO/MAX era! |
Quoting StrandedAtMKG (Reply 138): I'd still much rather fly a 737 versus an A320, but it's time for something new and exciting. Bring on the MOM. |
Quote: Meanwhile, Airbus’ stretched A321 is what many airlines are now choosing to replace their 757s, with domestic legacies like American and Delta both adding A321s. Many within the industry expect that Boeing is currently developing an enhanced 757-style derivative, what is tentatively called the NMA, or “Next Midsize Aircraft,” likely to be dubbed the 797 once it is officially on the market, entering service no earlier than 2022. |
Quoting jrfspa320 (Reply 142): all this fan fare about the roll outs and then..oh meh basically the same |
Quoting gatibosgru (Reply 143): Haven't we known these would be the changes all along? |
Quoting Boeing778X (Reply 140): The heck you lecture us on "scientific fact." Truth is, the 737 is a beautiful looking plane! |
