Quoting Cornishsimon (Reply 8): I could however see a well times JER-LCY service to offer onward JFK connections, however once the LGW New York route kicks in it's doubtful even that would be needed ! |
Quoting [email protected] (Reply 5): bmi launched LHR-JER in 2007 2x daily. I flew it a few times (320) and always pretty inexpensive and quite low loads. |
Quoting fcogafa (Reply 14): which was pretty impressive off a 5100ft runway |
Quoting N1120A (Reply 15): The little bit of transfer can do the dance, and is likely to have business somewhere else anyway. |
Quoting N1120A (Reply 15): JER has a 5600' runway. |
Quoting Curiousflyer (Reply 18): Also, the wealth in JER may like to remain discreet... Business travelers might be happier landing in a quieter airport. They might even think that buying a trip to JFK on a single ticket would draw attention anyway... |
Quoting AAMDanny (Reply 19): Don't forget that JER has a lot of competition to pretty much every major airport in the UK, and LGW to central London is only 30 minutes via the Gatwick Express. |
Quoting skipness1E (Reply 20): However not a lot of options connecting out ot Gatters if you're not a fan of easyJet or BA sun routes. |
Quoting AAMDanny (Reply 22): If the market for connections was strong enough, BA would have started the route from LHR... |
Quoting skipness1E (Reply 23): It was started at LHR, it all kicked off when it was moved to LGW in the 90s and the Jersey customers have been wanting it back ever since. |
Quoting skipness1E (Reply 16): Firmly still in "impressive for an L1011 category" though I think we can both agree. |
Quoting Lofty (Reply 21): Is LHR T5 set-up to handle a JER operations. It would have to use the same Gate 23 for arrivals as the DUB. |
Quoting Johnwaynebobbet (Reply 24): I have waned to win the lottery too but its not happened. |
Quoting N1120A (Reply 25): Couldn't they use whatever they use for domestic flights? Or does JER require customs? |
Quoting skipness1E (Reply 26): Nicely sarcastic but LBA and INV came back and I would say JER has a stronger business balance. You disagree? Quoting N1120A (Reply 25): Couldn't they use whatever they use for domestic flights? Or does JER require customs? Jersey and the Channel Islands as well as the Isle of Man are Crown Dependencies, British Territory outside the United Kingdom but within the Common Travel Area of the UK and Ireland. So no passport required but there's a Customs issue. I think (!) |
Quoting N1120A (Reply 15): BD couldn't offer the same connections as BA. |
Quoting [email protected] (Reply 29): JER-LON is very much a local market. |
Quoting shuttle9juliet (Reply 28): We use to send the 75 down there too, plus I think also for maintenance in the early 90s |
Quoting PieterBoth (Reply 35): Did AF or any other French regional airline ever serve Jersey? There doesn't seem to be a service to France today. Is there no demand or I guess the demand there is use a ferry service from Cherbourg? |
