Quoting 76794p (Reply 72): I did IAH-MEX on their E-190 in March of 2014. Really comfortable. I fell in love with the aircraft then |
I flew the up leg (MEX-SAT on the 190, really confortable but the 135 is HELL.
TRB
Quoting einsteinboricua (Reply 60): And to think I almost booked this segment just to log an E175...it was the A319 and that was unbearable, I can't imagine an E175. |
Quoting thegoldenargosy (Reply 58): 3 hrs on a 50 seater is a bit much. I've seen the bathroom line up to exit row before a ERJ-135. |
Quoting KaiTak747 (Reply 55): In Europe they are so rare, last year I managed to fly the Eastern Airways ERJ-135 from SOU-LBA, it was such a treat! The 3 across config is excellent, having a window and aisle seat all to yourself. I remember people on the flight baffled by how small the plane is, I guess everyone in Europe is so used to the 737/A320! |
Quoting RJ321 (Reply 86): I would say FlyDubai and their flights to Bratislava and other Eastern European cities from Dubai with 737s. The flights can easily exceed 6 hr. Also, Ethiopian fly their 737s from ADD to TLV and BEY non stop. |
Quoting DolphinAir747 (Reply 4): AC sends the ERJ on YYZ SEA and EWR YYC. |
Quoting PEK777 (Reply 8): Between that and the longhaul AC flights mentioned above Star Alliance should be on trial for crimes against humanity. |
Quoting PEK777 (Reply 10): I thought he meant ERJ135/145. The bigger ones are fine, but UA's flagship would be brutal on a route like that |
Quoting BoeingGuy (Reply 102): I remember reading that CO did BFL-IAH on an ERJ145. |
Quoting mtnwest1979 (Reply 33): Longest CRJ-200 flight I ever did was OO SLC-XNA. Wasn't too bad as there were only 13 pax on plane. Probably why it was short lived..... |
Quoting steex (Reply 42): It doesn't really matter so long as you use the same units for direct comparison. |
Quoting jrfspa320 (Reply 109): |
Quoting Viscount724 (Reply 113): YYZ-SEA 1.791 nm |
Quoting jetblue1965 (Reply 93): Exactly how are we classifying "RJ" here ? Just the 50-seaters, or all the way up to E195 ? |
Quoting TheRedBaron (Reply 70): flew AM embraer 135, from SAT to MEX... not again EVER... Rather drive... yep 23 hours, those seats were designed by satan himself. |
Quoting TheRedBaron (Reply 100): a) CRJ's - all models (100/200/700/900/1000) - same seat widths/configuration b) ERJ's - all models (135/145) c) Avro's - all models d) 328's - both prop and Jet models e) EMB 120 f) ATR's - all models (42/72) g) Q Series/ DHC - (100/200/300/400) (DHC's) h) Beech 1900 i) Antonov 24 j) Dornier 228 k) Fokker 50/60 l) Xian M60's m) Pilatus P12 n) SSJ100 o) EJet E170/175 but not 190/195 (just an opinion) |
Quoting AMIKI (Reply 118): |
Quoting afcjets (Reply 120): Quoting AMIKI (Reply 118): I didn't realize there were so many, not sure if they all have RJ in the full name so maybe that is not the best determination. I flew the Beechcraft 1900 in 1993 and the 1900D a few years later (and the fact that you could actually stand up in the 1900D made it 100 times better), and they were both props, have they changed to jet engines now?? |
Quoting northstardc4m (Reply 121): These are the grey area RJs: CRJ-700/900/1000 EMB170/175/190/195 |
Quoting northstardc4m (Reply 121): Problem with the "grey area" ones is they can get into the range of the 737-500/600, 717, A318/319... which we don't consider RJs at all. |
Quoting afcjets (Reply 122): When an aircraft maker names a jet CRJ-1000 and ERJ-190 and the RJ in that name stands for Regional Jet, I don't consider that a gray area considering they made and named the jet. Besides, no two regions are the exact same size and there will likely never be a consensus on what range constitutes a regional jet when you are borrowing and trying to interpret the name from the aircraft maker. |
Quoting jetblue1965 (Reply 123): |
Quoting Airontario (Reply 119): Quoting RWA380 (Reply 114): 1822 nm YYZ-PDX on an AC CR9. To my knowledge Jazz has never operated PDX from YYZ. AC has always operated PDX from YYZ, so the smallest aircraft would've been the E190. |
Quoting BoeingGuy (Reply 131): Quoting rlwynn (Reply 130): airBaltic DH4 RIX-BRU 894sm. QX did a DH4 on LAX-LAP. It was 837 sm. |
Quoting Airontario (Reply 129): AC/QK flight IAH-YYC on the CRJ705(900) which is 1,750 sm, and can be anywhere from 3:45 to 4:10. |
Quoting steex (Reply 42): Quoting RWA380 (Reply 40): I think many here use nautical mileage when talking miles, PDX-STL is 1484 nm as a reference. It doesn't really matter so long as you use the same units for direct comparison. At any rate, AS has not announced any E75 routes longer than PDX-STL, so not sure to what route you are referring. Do you know something we don't? |
Quoting jetmatt777 (Reply 138): You're wrong. SEA-OKC is 1,519 nautical miles on an E75. |
Quoting afcjets (Reply 140): Is CLT-DEN the longest E190 route? |
Quoting longhauler (Reply 141): Quoting afcjets (Reply 140):Is CLT-DEN the longest E190 route? Not even close |
Quoting Viscount724 (Reply 142): AC has many much longer E190 nonstop routes, some over 50% longer. |
Quoting crj 900 (Reply 24): 1747 miles on Jazz for AC EXPRESS YYC-IAH CRJ705 |
Quoting Yellowtail (Reply 144): Quoting crj 900 (Reply 24): 1747 miles on Jazz for AC EXPRESS YYC-IAH CRJ705 I have done this one twice (after UA cancelled my flights) and it was horrible. By the time you fly over Dallas you are about ready to pull your hair out |
Quoting Viscount724 (Reply 145): Quoting Yellowtail (Reply 144):Quoting crj 900 (Reply 24): 1747 miles on Jazz for AC EXPRESS YYC-IAH CRJ705 I have done this one twice (after UA cancelled my flights) and it was horrible. By the time you fly over Dallas you are about ready to pull your hair out |
