Quoting IslandRob (Reply 4): |
Quoting gasman (Reply 2): This is highly irresponsible reporting. |
Quoting zeke (Reply 5): It is however entirely possible, they could have removed the different power sources and packs to isolate smoke. |
Quoting TheRedBaron (Reply 7): If this turns to be true, Illl put a statue of PIHERO in my garden. Back in the first 15 or so threads he entertained a failure due to liquid spill or fire in the cockpit that made the flight be almost uncontrollable and then flew without intervention to the middle of the SIO. |
Quoting B8887 (Reply 10): I just hope one day we will find out. |
conspiracy theory |
Quoting gasman (Reply 2): This is highly irresponsible reporting. It's being put forward as fact, whereas it's nothing more than (yet another) educated guess about what happened. |
Quote: First, the theory widely advanced in the early days of the disaster that as a first step to make the airplane “vanish” the pilots switched off the transponder. Nobody switched off anything at that moment—it now appears that a power interruption or failure could have disabled the transponder. |
Quoting seahawk (Reply 18): Could they please pin point the location of the fault? I can not come up with one position in the whole plane that could turn off the transponder, radio and sat phone within minutes, knock out the pilots and yet leave the autopilot and plane controls undamaged or make them do strangely coordinated manoeuvres. |
Quoting seahawk (Reply 18): The fact that the plane flew straight and level long enough for all CVR data from the manoeuvre phase to be gone, is another strange coincidence. |
Quoting 7BOEING7 (Reply 9): A fire is totally plausible if you can find something to burn but oxygen is your only choice and if you had an Egypt Air event the odds of the airplane flying for another 6 hours are not at all realistic. |
Quoting aerosol (Reply 20): Same as the Germanwings case - someone in the cockpit wanted the specacular ending. |
Quoting karungguni (Reply 6): That is the biggest problem I have with any theory without human intervention. The plane came back across Malaysia short of the transfer to Vietnam to the south of problematic Patani in Thailand and then north of problematic Aceh in Indonesia and then made a turn south over the Indian Andaman Islands with no local radar coverage. Too many coincidental threading of the needle. |
Quoting TheRedBaron (Reply 7): If this turns to be true, Illl put a statue of PIHERO in my garden. Back in the first 15 or so threads he entertained a failure due to liquid spill or fire in the cockpit that made the flight be almost uncontrollable and then flew without intervention to the middle of the SIO. The plot thickens... |
Quoting 7BOEING7 (Reply 8): The "pilot did it" or alternatively a terrorist did it are still just as plausible as many other valid theories put forward so far. Diego Garcia and somewhere in Asia are not valid. |
Quoting 7BOEING7 (Reply 8): The lithium ion batteries theory sounds good but you'd have a fire warning long before the radios were knocked out and you'd be talking to somebody because you're looking for a place to land. |
Quoting 7BOEING7 (Reply 8): Say they couldn't talk to anybody and the pilots became incapacitated, the same fire that knpocked out the radios would have also taken out the autopilot and the airplane wouldn't have continued flying for 6+ hours. |
Quoting art (Reply 16): Quote: First, the theory widely advanced in the early days of the disaster that as a first step to make the airplane “vanish” the pilots switched off the transponder. Nobody switched off anything at that moment—it now appears that a power interruption or failure could have disabled the transponder. Rubbish reporting. It is speculation that the aircrew switched off/did not switch off the transponder. It is presented as a fact (ie 100% certain) that the aircrew did not switch the transponder off. |
Quoting YoungMans (Reply 23): You forgot to mention Sir Tim Clark's words, where he indicates that he doubts that MH370 is where they say it is. |
Quoting britannia25 (Reply 12): Red your post just made me laugh! A mad cat woman! Lol. |
Quoting nordair737242c (Reply 14): Thank you Red for being the true voice of sanity ..... you have our total support behind this theory |
Quoting lancelot07 (Reply 22): Then why didn't he go for a spectacular ending ? - Petronas Towers - a government building in KUL - the forbidden city in Peking and certainly some other spectacular targets along the way. But no, this "somebody" did NOT choose a spectacular ending, he chooses to fly into one of the remotest areas of this world until he runs out of fuel. AND in contrast to all other somebodys, he flies for many hours instead of putting the nose down at the first opportunity. AND this "somebody" does it without a motive being discovered in 21 months. Sorry, this theory has holes in it like Emmentaler cheese. |
Quoting aerosol (Reply 20): Same as the Germanwings case - someone in the cockpit wanted the specacular ending. 1.) timing of end communication: switch of frequencies 2.) out of a 360 degree compass that bird flies in the oposite direction to were it is expected 3.) the area it goes down is the one least frequented on earth and a deep ocean 4.) due to variation a simple heading select wouldn't have gotten the bird to that area meaning it is flown there on purpose Sorry but Ockhams razor... |
Quoting SCQ83 (Reply 26): Also, your attack to the Petronas Tower |
Quoting lancelot07 (Reply 28): The thesis was that he did something spectacular. Fact is he didn't. |
Quoting SCQ83 (Reply 26): My theory is that it was probably a subtle sign. I guess it comes all down to psychology, some people like to show off, others are more subtle. Also, your attack to the Petronas Tower... well who knows what would happen in Malaysia is that happens. A mess probably. The guy was against the government, not against Malaysia itself as a culture or a country. |
Quoting 777Jet (Reply 24): Quoting YoungMans (Reply 23): You forgot to mention Sir Tim Clark's words, where he indicates that he doubts that MH370 is where they say it is. And is his opinion more valid because he is the CEO of the airline with the world's largest 777 fleet? |
Quoting YoungMans (Reply 31): His opinion would be no more valid than others 'Because' he is a CEO. But ... in his position he almost certainly would have access to information that is not otherwise publicly known or available. |
Quoting RedChili (Reply 30): He has not caused any damage to the government at all, but he has caused damage to the country and the taxpayers, because tourism and the economy of the national airline have been affected, and a lot of tax payers money has been spent on search efforts. |
Quoting lancelot07 (Reply 32): Quoting YoungMans (Reply 31): His opinion would be no more valid than others 'Because' he is a CEO. But ... in his position he almost certainly would have access to information that is not otherwise publicly known or available. Actually, his published(!!) opinion is LESS valid because he is CEO of the largest operator of the 777. He has massive vested interests. |
Quoting YoungMans (Reply 33): Would T/C have access to information, because of his position, that is not publicly available, perhaps not even to the investigators. I'm thinking here of information that might have been of some real importance. |
Quoting YoungMans (Reply 33): What should he do or should have done if he has such exclusive information? |
Quoting YoungMans (Reply 33): Would he have a moral obligation or legal ones in that situation? |
Quoting YoungMans (Reply 33): And why would the 'Der Spiegel' have interviewed him anyway? |
Quoting TheRedBaron (Reply 7): fire in the cockpit that made the flight be almost uncontrollable and then flew without intervention to the middle of the SIO. |
Quoting 777Jet (Reply 24): The article's headline: """Exclusive: MH370 Was Crippled by Sudden Electrical Failure"""" That wording is nothing more than clickbait and irresponsible reporting. |
Quoting aerosol (Reply 20): Sorry but Ockhams razor... |
Quoting Pihero (Reply 35): That Australian ATSB report at least dismisses one of the main point s of the BDCS : that , without autopilot the plane would enter an increasing bank, roll into a death spiral... . Apparently, it could, from cruise level, with the assymetry associated with a failed ( starved ) engine, remain on its course... So much for the reliability of a Boeing so-called test piloit on his system knowledge. |
Quoting SCQ83 (Reply 27): I assume psychological problems (seriously to kill +200 people) + political views = disaster. |
Quoting 777Jet (Reply 24): Some fire! |
Quoting 7BOEING7 (Reply 37): "SIMULATOR DATA The aircraft behaviour after the engine flame-out(s) was tested in the Boeing engineering simulator. In each test case, the aircraft began turning to the left and remained in a banked turn. In many cases, but not all, a phugoid oscillation in pitch was observed." |
Quoting litz (Reply 39): I'd add to your points that in almost every single other instance of inflight fire, the crew was able to Mayday ... including probably the worst instance of inflight fire in modern times, Valujet 592. |
Quoting litz (Reply 39): Fascinating! so a 777 is actually capable of maintaining a somewhat stable flight with nobody at the controls, and both engines flamed out |
Quoting litz (Reply 39): I would have figured it would have just rolled over and nosedived. |
Quoting Pihero (Reply 35): Quoting 777Jet (Reply 24): The article's headline: """Exclusive: MH370 Was Crippled by Sudden Electrical Failure"""" That wording is nothing more than clickbait and irresponsible reporting. Yet I've ne'ver saw you object to the far more irresponsible ones on this forum. |
Quoting Pihero (Reply 35): May I remind all of you that the origin of the article is an*official Australian ATSB report* ? |
Quoting Pihero (Reply 35): I left the Flight 370 threads because I did not want to be associated with the various attitudes of most of the posters, attitudes which could be ascribed as xenophobic / racist / self-righteous... backed by the very efficient interventions of the BDCS ( Boeing Damage Control Squad) which never accepted that anything could be wrong with the plane (... ... as if ...). |
Quoting Pihero (Reply 35): So much for the reliability of a Boeing so-called test piloit on his system knowledge. |
Quoting litz (Reply 39): Quoting 777Jet (Reply 24): Some fire! I'd add to your points that in almost every single other instance of inflight fire, the crew was able to Mayday ... including probably the worst instance of inflight fire in modern times, Valujet 592. That fire was so intense, the recreation of the incident almost burned down the test facility. Temps were in excess of 3000 degrees F literally within minutes. |
Quoting britannia25 (Reply 12): The worst part is for the families and not knowing what happened to their loved ones! |
Quoting Curiousflyer (Reply 19): They are also amazing airplane pilots and members of the Cat Guild can fly an A380 from SYD to LHR non-stop |
Quoting Kevil (Reply 44): |
Quote: It seems the pilots Zaharie and Farriq both knew they had a communications problem and tried to establish VHF voice contact around 17:30 UTC as detected by Japan Airlines Flight JAL750. |
Quoting WingedMigrator (Reply 46): I have a theory |
Quoting lancelot07 (Reply 45): .... [....] .... and than the article is by someone who is about to write a book, with some freedom for artists obviously. |
Quoting abba (Reply 47): Interesting - and how would you then explain the turns later on? |
