audidudi
Yellow Alert At OAK For WN2547
Wed Dec 23, 2015 4:51 pm
There is currently a Yellow Alert at OAK right now for WN2547, N7709A, which departed for MDW at 06.12 and is currently circling to burn off fuel. It apparently has a landing gear problem.
http://www.flightradar24.com/SWA2547/8592109
[Edited 2015-12-23 08:54:48]
[Edited 2015-12-23 08:57:25]
dabpit
RE: Yellow Alert At OAK For WN2547
Wed Dec 23, 2015 4:57 pm
What is a Yellow Alert?
Carpe Diem
SonomaFlyer
Wed Dec 23, 2015 5:00 pm
Better than a RED ALERT!
badgervor
Wed Dec 23, 2015 5:10 pm
Appears to be holding off the Manteca VOR (ECA)
http://flightaware.com/live/flight/SWA2547
kbmiflyer
Wed Dec 23, 2015 5:29 pm
Wow, it has made at least 18 loops so far. Wonder how many more before they burn off enough fuel. 3 hours going in circles with a possible plane issue has to be stressful for the passengers. The plane was schedule to land at MDW at 11:55, so you think they would land pretty soon.
nikeson13
Wed Dec 23, 2015 5:45 pm
Just left hold, descending towards OAK.
Nikolas
audidudi
ATC just advised the ground units that she's landing in 10 mins!
audidudi
Wed Dec 23, 2015 5:56 pm
She just did a fly-by the tower and all appears to look normal!
[Edited 2015-12-23 09:58:02]
kbmiflyer
Wed Dec 23, 2015 5:58 pm
Deleted - prior post was edited
[Edited 2015-12-23 09:58:58]
Siren
Deleted... Mods Please delete
[Edited 2015-12-23 10:01:44]
jporterfi
Wed Dec 23, 2015 6:01 pm
The aircraft executed a low approach so ATC could check for a possible blown tire. OAK Tower and an aircraft holding short of the runway reported that they didn't see anything unusual. The aircrafft is now executing a missed approach.
PPC (ASEL) | Aircraft Flown: PA28, C172, DA20
AWACSooner
Based upon FR24, it looks like she did a low approach to verify the gear was down.
nickflightx
Wed Dec 23, 2015 6:06 pm
It's live on ABC7, it looks like though the nose gear may be sideways, can't tell though.
audidudi
Wed Dec 23, 2015 6:08 pm
One Bay Area TV station is reporting that a front tyre has blown.
audidudi
Wed Dec 23, 2015 6:15 pm
Perfect landing! Great news!
StrandedAtMKG
While on one level I understand the edict to stay close to an airport, what is the advantage to circling OAK for three hours instead of just continuing on to MDW? You're going to have a tough landing anyway, and it seems like you may as well complete the flight first. There are certainly plenty of suitable diversion airports between OAK and MDW if you ended up needing one.
AWACSooner
She's down...non-event...safe landing
kbmiflyer
Wed Dec 23, 2015 6:18 pm
Quoting StrandedAtMKG (Reply 15):
Speculating here, but if they had a landing gear issue they would not have retracted the landing gear. That would have prevented them from flying to MDW with the increased drag of the landing gear being exposed. Also, even if they could have made it to Chicago, they likely would have had to divert to ORD since MDW runway's are so short
apfpilot
Wed Dec 23, 2015 6:41 pm
My guess would be that you don't know what other damage the tire caused when it shred the tread. Could have damaged something in the nose gear assembly. A piece of tread could have smacked a slat or a flap track or the undercarriage, could be stuck in the horizontal stab. Why take that risk?
Opinions are my own and do not reflect an endorsement or position of my employer.
Brick
Wed Dec 23, 2015 6:46 pm
At least the media didn't report that he plane is circling "dumping fuel".
A noble spirit embiggens the smallest man...
N766UA
Wed Dec 23, 2015 6:47 pm
LOL what is a yellow alert?!
FredrikHAD
Wed Dec 23, 2015 8:01 pm
Quoting N766UA (Reply 20):
Rescue services use colors green, yellow and red for alert status. Green is obviously for "no alert" and red for an actual accident. Yellow is like "hot stand-by" where trucks are manned, ready to roll any second. A pending landing with an identified problem with the potential to cause an accident or a plane that goes missing near an airport are examples of yellow alerts.
/Fredrik
apfpilot
Wed Dec 23, 2015 8:07 pm
Quoting FredrikHAD (Reply 21):
When I worked in Airport Ops (granted this was almost 8 years ago) we had Alert 1, 2, and 3 from least severe to most. The only color we used was Code Red for lightening in the area and ramp being closed, and code Pink but that wasn't an official term
nkops
Wed Dec 23, 2015 8:08 pm
Never heard of that , we use Alert 1,2 or 3
Turn left heading 080 contact departure
fsnuffer
Wed Dec 23, 2015 8:27 pm
Don't know the particulars about this incident but the emergency procedure for a blown tire in a T-43 (B-737) was not to raise the gear. USAF lost a T-43 when the gear was retracted after blowing a tire. The rotating tire with shreds tore loose the hydraulic lines in the wheel well and the hydraulic fluid ignited when it hit the hot breaks. Again, our EP was to hit the call button and say "Pilot the gear" when we thought we blew a tire on take off and we would then proceed to hold with our gear down until we could burn off enough fuel.
So to make a short story long, it would be a very long flight from OAK to MDW with the gear down.
badgervor
Wed Dec 23, 2015 8:35 pm
All the talk of a blown tire makes me think of this incident...
http://www.youtube.com/watch?v=_66mlsFwB9I
KELPkid
Wed Dec 23, 2015 9:12 pm
Quoting nickflightx (Reply 12):
It couldn't have been. The B737, unlike the A320, does not pivot the nose gear 90 degrees before retraction. The gear system probably has something in it to guarantee that the nosewheel is straight before retraction (like if, for example, crosswind correction was being applied with the rudder pedals during the takeoff roll).
So, on another note, did the aircraft arrive on 6 good tires? What triggered this-a gear unsafe indication?
as739x
Wed Dec 23, 2015 10:01 pm
Pilots land when they have an emergency of a mechanical issue, period. There are rules to adhere to.
As said above, if one of the gears was not retracting then you have a tremendous amount of drag and don't have the fuel, unable to keep speed required on airways, etc. The max gear extension alone would prevent this as its only around 270kts I believe
Quoting nkops (Reply 23):
Quoting apfpilot (Reply 22):
Different airports use different Alert Systems. But all the same that each level is different in levels of emergency.
FredrikHAD
Wed Dec 23, 2015 11:03 pm
Quoting as739x (Reply 27):
Seems like a hazzle in the US with different codes for different airports! In Sweden we used the red/yellow/green system during my short time as an airport firefighter and I know it was the same for all airports in the country at that time.
Quote from:
http://forums.radioreference.com/cal...llow-alert-aircraft-emergency.html
"I can speak for Oakland Airport, as I worked in the control tower there for a number of years. A Yellow Alert is used when an air carrier type aircraft is coming in for a landing with some sort of problem. You must have heard Alameda FD being dispatched this afternoon. They roll to assist the OFD to stand by in case the plane crashes. Now, an actual crash is a Red Alert. On the North Field, where smaller planes fly, you will hear Alert 1 for an inbound emergency and Alert 2 for an actual crash. Most Yellow Alerts are for airliners with flap problems, hydraulic problems, bad gear indication, etc. "
Practically the same airfield, and still different terminology. Amazing!
/Fredrik
flightsimer
Thu Dec 24, 2015 7:09 am
Quoting KELPkid (Reply 26):
The A320 does not pivot the nose landing gear in the retraction. The JetBlue incident was a failure that caused the landing gear to deflect the full 90 or so degrees of motion.
https://youtube.com/watch?v=87QsjhGGRnU
Commercial / Airline Pilot
