ua900
RE: ORD Terminal 5 Operations
Thu Jan 07, 2016 11:48 pm
Quoting STT757 (Reply 99):
UA has an FIS in Terminal C.
That's true but unlike ORD B/C for example LH doesn't fly out of EWR C gates, so B becomes a quasi int'l terminal for all the *A carriers save for UA.
2020: AMS | BRU | DEN | DFW | EWR | FRA | GUA | IAH | LAX | LIM | MCO | MUC | ORD | PTY | SAL | SCL | SFO | TXL
ORD Boy 2
Fri Jan 08, 2016 3:59 pm
Interesting to see this pop up this morning on Crain's (subscription may be needed)
Article title - City floats $1 billion plan for final new runway at O'Hare..
I would think FIS and gates have to be discussed.
http://www.chicagobusiness.com/artic...tm_campaign=ccb-morning10-20160108
compensateme
Fri Jan 08, 2016 4:06 pm
Quoting jetblue1965 (Reply 97):
No point to continue a mature adult debate with someone who uses this nonstop.
Except you're not having a mature adult debate. You made several assumptions without any factual basis and when I casted doubt on them, you started playing verbal jousting and attacking.
You claimed that only a "small portion" of consumers transfer between T1 & T2, maintained that UAX is a "small subset" and "limited" at ORD and insisted that the "vast majority" of passengers stayed within T1. I responded by pointing out that UAX - having operated about half of UA's physical seats at ORD this decade - is hardly a small subset and stated that there was a "fairly larger number" of passengers making the transfer, a "higher percentage" than what you believe. You responded by playing a verbal jousting game -- insisting that the % of seats operated by UAX is closer to 45% and demanding I prove that more than half of UA passengers transferred from T1 & T2.
I made no such claim. I merely pointed out that your original assertion that only a "small portion" is false -- given that about half the seats this decade have been operated by UAX, and the local market disproportionately flies mainline equipment & UAX flights within T1 (since UA historically keeps local market heavy destinations with T1), it's statistically improbable. Yet you continued a verbal jousting game.
You then insisted the transfer was no big deal because the vast majority of UA's passengers are road warriors, which again is a false statement. While the majority of revenues are from road warriors, the majority of passengers are not. AA just stated that nearly 90% of its passengers flew on it just once in the year. While the spread is going to be different at a UA hub in ORD, I can guarantee you that the majority of its passengers are not road warriors.
I'm sorry that you're such a fanboy of UA that you can't get past its shortcomings. UA is my former employer and I was very proud with what we achieved there, but I long recognized that the T2 mess (again, it wasn't until recent that UA cleaned up the terminal) was turning passengers away. And for the record, I knew what the % was during the time period I worked there (and I doubt it's changed significantly) but a) it's proprietary and b) even if I shared it, you would still attack it. Hence why I walked you through a logical argument, which you couldn't handle.
We don’t care what your next flight is.
Cubsrule
Fri Jan 08, 2016 4:07 pm
Quoting ua900 (Reply 98):
Check out the AA area once you're past UAX while you're at it, and B/C will seem modern and spacious by comparison
AA is sort of the inverse of UA. G is nicer than Terminal 2, but B/C are nicer than H/K.
compensateme
Fri Jan 08, 2016 4:10 pm
Quoting ORD Boy 2 (Reply 101):
Why? There's no reason to believe at this point either AA or UA would be interested in absorbing the cost of adding a FIS in their respective terminals, which would cost hundreds of millions to build and millions annually to operate.
jfk777
Fri Jan 08, 2016 4:18 pm
Quoting compensateme (Reply 104):
At some point it will happen. That is like saying AA should have never done the A-D thing in Miami or Terminal E in DFW or UA should have not done Terminal C FIS at Newark.
jcwr56
Fri Jan 08, 2016 4:23 pm
And might not even be staffed to begin with by CBP, Immigration or Agriculture. Sure there's always a possibility they could invest, but what's the ROI timeline.
compensateme
Fri Jan 08, 2016 4:33 pm
Quoting jfk777 (Reply 105):
No, it's not.
-- ORD will not be a large growth center internationally for AA or UA going forward;
-- Pre-Clearance is expanding globally;
-- The logistics of building a FIS for AA and/or UA will likely push the cost beyond 1B.
I can't perceive either UA or AA willing to absorb the cost.
AmricanShamrok
Fri Jan 08, 2016 7:40 pm
AmricanShamrok, great job with ORD, could you do TBIT next?
Thanks. Unfortunately I am not familiar with LAX; I've never been there but am a (relatively) frequent visitor to ORD which helps me fill in blanks with info I can't get online.
