Quoting FSDan (Thread starter): 1) Are all flights loaded and unloaded via jet bridges, or do some flights deplane directly from hardstands with passengers needing to ride buses? |
Quoting FSDan (Thread starter): 2) Do airlines other than SA)">DL have their own assigned gates, or are they all common use? |
Quoting FSDan (Thread starter): Is there a certain set of airlines that always use the B gates (from looking at pictures and satellite view on Google Maps, it seems like SA, W3, VS, KL, LX, KU, and CI are all usually over there; are there others?) vs. the A gates? |
Quoting FSDan (Thread starter): Do KL and VS share SA)">DL's gates, or do they operate out of B27, B29, and B31 along with the other airlines that use concourse B? |
Quoting FSDan (Thread starter): What about SA)">DL/SkyTeam partners that aren't in JVs with SA)">DL such as WS, UX, CI, and CZ? |
Quoting DiscoverCSG (Reply 2): Which DL flights use T4 and which use T2? |
Quoting panamair (Reply 3): - T2 cannot handle any aircraft bigger than a 763ER, so if your flight is scheduled for a 777, A330, or 764, you will be departing out of T4. |
Quoting panamair (Reply 3): |
Quoting JetBlueCLT (Reply 6): Slightly off topic, but what does IROPS stand for. |
Quoting jfklganyc (Reply 4): The 380s park at the end of B. There is a hard stand for the 380/747 in between the two gates (Almost looks like the top of a star with the 3 tails). They shuffle them around as needed. I don't know if other gates can handle a 380 in a pinch. |
Quoting jfklganyc (Reply 4): The 380s park at the end of B. |
Quoting FSDan (Reply 5): I just did a quick check of the summer schedule and this principle seems to hold in all cases except one - the JFK-IST flight is #272 and is scheduled to operate on the 764. |
Quoting jfklganyc (Reply 4): As for tightness of gate scheduling, T4 has nothing on T1. If you want to discuss a clusterf**k, |
Quoting panamair (Reply 1): KL shares SA)">DL's dedicated gates (usually KL is at B24 or B26 or B28). VS uses the A gates 99% of the time (the VS Clubhouse is also on the A concourse side) though occasionally you do see a VS flight departing out of B27/29/31. |
Quoting panamair (Reply 10): Yup...T1 is a real mess both inside and out. The terminal is handling way more passengers and aircraft movements than it was originally built for. LX moved over there for a short period some years ago to be closer to parent LH but then moved back to T4 rather quickly as their flights were constantly delayed. LO is also moving out this year (going to T7). |
Quoting EddieDude (Reply 11): There are rumors AM is relocating from T1 to T4. It would make sense, if there is space, that KL, VS and AM share space with DL. Any news? Thoughts? |
Quoting panamair (Reply 10): LX moved over there for a short period some years ago to be closer to parent LH but then moved back to T4 rather quickly as their flights were constantly delayed. |
Quoting BDL757 (Reply 12): I would definitely make sense for AM to move to T4. I wonder if eventually all SkyTeam airlines could/will move to T4. It would make it a lot easier for connecting pax. |
Quoting delimit (Reply 15): That won't happen. AF and KE are part owners of T1. Connections between them and Delta happen in other cities. The NYC seats are better used for O & D. |
Quoting jetblue1965 (Reply 8): I thought all the 380s are at T4-A. What do you mean by "B" ? |
Quoting DiscoverCSG (Reply 18): So, which T4 gates are DL's? |
Quoting DiscoverCSG (Reply 18): Somebody mentioned KL or occasionally VS parking in the DL area. Do any others do this? |
Quoting DiscoverCSG (Reply 18): Do all DLConnection flights use the spider web in T2? |
Quoting panamair (Reply 19): DL has all of the B gates currently except for B27, B29, and B31. |
Quoting panamair (Reply 19): The 'spider web' is gone and three mainline gates have replaced it in T2 (gates C64, C65, C66). DL Connection flights now use gates at the T4B extension (gates B42-B55). Gates B42-B55 were built for the DCI operation although mainline aircraft do sometimes use gates B42 and B43. Also, one or two of the DCI gates also have 'sterile' walkways to the Immigration areas as Delta has flights from YQB to JFK that don't have preclearance at YQB. |
Quoting DiscoverCSG (Reply 22): So, if I'm counting correctly, DL+KL have 40 gates at JFK. Not unimpressive! |
Quoting jfklucky777 (Reply 21): just recently a new gate was renovated to accommodate 380 operations on the B concourse. It's either gate B28 or B30. |
Quoting jetblue1965 (Reply 16): The same can be said about KL too, but apparently KL co-locates with DL at T4-B. |
Quoting jetblue1965 (Reply 16): I'm sure if AF wants to sell their T1 stake there's always someone willing at the right price. |
Quoting delimit (Reply 25): I'm not sure why. They have a huge, recently renovated club space in 1 that they would have to rebuild somewhere else. What would they gain by moving? They connect very few passengers over JFK. It's an O & D market. |
Quoting jetblue1965 (Reply 26): You're underestimating it. Per PANYNJ 2014 report, the entirety of JFK is 22.8% connecting. In comparison, LGA is merely 10.8%. |
Quoting delimit (Reply 27): The majority of connections happening at JFK are AA to AA, B6 to B6, and DL to DL. Every seat that can be sold by AF and KL to NYC is prioritized over lower margin secondary US destinations. There are definitely some passengers who connect, but not nearly enough to prompt AF to move. You're basically suggesting they go from being homeowners to renters. It makes no financial sense. Greater passenger convenience is nice, but there's no financial incentive for them to do it. |
Quoting jetblue1965 (Reply 28): By that argument, KL should move back to T1 with AF then, since your argument is that connections are low margin and not worth the effort. |
Quoting jetblue1965 (Reply 28): It's also a self-fulfilling prophecy - few connect there because the setup makes the connection process a hassle and stressful. Your assumption is that pax lost is merely routed at DTW/ATL when in fact it could've been lost to another alliance. |
Quoting jetblue1965 (Reply 28): Just look over to T8 - AA is co-locating with as many oneworld carriers as they can fit, with only major exceptions being BA, and maybe CX. |
Quoting FSDan (Reply 13): Have there been any rumblings recently regarding the completion of the T4 A concourse expansion? When that is done, DL should be able to move the rest of their operations to T4 and close T2, which could then allow for additional expansion of T1 or T4 on the ground where terminals 2 and 3 originally stood. |
Quoting jetblue1965 (Reply 28): By that argument, KL should move back to T1 with AF then, since your argument is that connections are low margin and not worth the effort. Where KL was pre-merger is no longer relevant as the importance is to achieve synergy, which a split terminal is hardly the case. |
Quoting LJ (Reply 33): Isn't T4 (partially) owned by Schiphol Group? If so, I would say a "package deal" would probably be teh reason why KL isn't going to move to T1 (plus the fact that T1 is crowded). |
Quoting jetblue1965 (Reply 28): |
Quoting panamair (Reply 3): - T2 cannot handle any aircraft bigger than a 763ER, |
Quoting Global2 (Reply 35): I vividly recall departing from the Northwest Terminal (today's T2) on a 742 bound for Tokyo in 1983. I think it was Gate 4 or 5. |
Quoting phatfarmlines (Reply 38): |
Quoting beeweel15 (Reply 40): DL should have fixed T3 and take down T2 and work with T1 since most of the skyteam airlines are there. |
Quoting jfklganyc (Reply 41): Only downside is the walk...but there are plenty of walkways to help |
Quoting delimit (Reply 42): As someone who is flying, rather than waiting in a car for people, T4 is great. |
Quoting beeweel15 (Reply 43): Yes you are flying and not working there or waiting for family there so you really wont see what people are talking about especially since If you was there for the construction of the terminal from the beginning |
Quoting beeweel15 (Reply 43): T4 had specific expansion plans which would have expanded the terminal and there would be much less walking etc. but DL spent more money and did not follow the original expansion plan which would have saved them money. |
Quoting DiscoverCSG (Reply 45): However, some of DL's ex-JFK flights have flight numbers beginning with other digits - is there rhyme or reason to these? |
Quoting DiscoverCSG (Reply 45): And, does the 4/2 flight number scheme also apply to inbound flights? |
Quoting panamair (Reply 46): There aren't any. All DL or DCI-operated flights departing out of JFK have flight numbers beginning with a 2 or 4. |
Quoting DiscoverCSG (Reply 47): A quick search for June 6 turns up: DL1359 900 AUS 319 DL1312 1830 DEN 320 DL1729 1925 TPA 717 DL741 1115 ATL 738 DL1870 1845 SEA 752 DL1443 1700 SFO 763 DL5598 1315 PHL CR2 DL5513 1500 SYR CR7 DL3926 1500 YQB ER4 DL740 1130 MIA M88 |
