Quoting LAX772LR (Reply 98): sDL's original JV partner (SR) did not either. |
Please provide evidence that Delta had a "joint venture" - in today's context/meaning - with Swissair. Correct me if I'm wrong - but I do not believe that the two, for example, coordinated schedules or fares, nor did they share revenue.
Quoting LAX772LR (Reply 98): It seems you're attempting to emphasize the equity purchases as if they were somehow a preferred method of j/v integration for DL to the point of scuttling a deal if they can't get it |
Nope, not at all. What I'm emphasizing is that it appears equity purchases have clearly greased the skids for several of the JVs/"strategic partnerships" Delta has created.
The bottom line in all the semantic back and forth is that it takes two. I'm not suggesting that the reason Delta and Korean have not been able to do a deal is because of big, bad Delta, nor do I subscribe to the view - expressed here on A.net as recently as a few years ago - that it was just a matter of time until intransigent Korean bent to Delta's will. But I do think there's some truth to both sides. Is Korean less than enthusiastic about given up as much control to Delta as what Delta is used to getting from its other partners? Quite likely, yes. But on the flip side, is Delta also likely a very demanding and assertive "partner?" Quite likely, yes. I have absolutely no doubt that both are acting in their own interests - or at least that's how they see it.
The point I'm making is that in this case, whether Delta likes it or not, it apparently doesn't have the same amount of bargaining leverage to get a JV on the terms it wants in the same way it's managed to do with some of its other partners (in some cases facilitated, again, at least partly by cash). Similar story with Alaska. Try as they might, Delta cannot get its way. And so at some point Delta is going to have to decide what is in its long-term interests, and whether it's better to continue holding out to get the deal it wants from Korean, and in the meantime accepting that the potential network opportunities that could be enabled by a Korean JV are simply not worth the "cost" that Korean wants in return.
Quoting panamair (Reply 99): Technically, Delta is currently only in three separate JVs and only one of them involves a stake in the partner (the Virgin Atlantic JV). The AF/KL/AZ JV - no equity involved. The VA JV - no equity involved. |
Precisely as I said.
Notice how I've repeatedly referred to "JVs" as well as "strategic partnerships?" Delta itself refers to its relationships with Aeromexico, GOL and China Eastern as "strategic" - but nobody ever said they were JVs.
