Quoting bluefltspecial (Reply 5): |
Quoting DTWPurserBoy (Reply 9): |
Quoting audidudi (Reply 8): |
Quoting DTWPurserBoy (Reply 9): am waiting anxiously for someone to post the first photo of the new A321 in DL colors. If the first is to arrive in late February, it should be just about done in final assembly and undergoing engine installation and test flights. I am sure one of our intrepid French a.netters will provide a great picture shortly. |
Quoting larshjort (Reply 12): |
Quoting larshjort (Reply 12): I think you are going to wait a long time to get a picture from a french spotter, unless he goes to XFW or BFM . Airbus Toulouse only produces A320s, not 319 and 321s. |
Quoting skymiler (Reply 11): Any chance of an L2 door for boarding, as used on the 757? Or will it be a jam and cram process, as has been noted on the 737-900ER equipment (horrible experience). |
Quoting skymiler (Reply 11): Any chance of an L2 door for boarding |
Quoting Transpac787 (Reply 15): |
Quoting FlyASAGuy2005 (Reply 16): That's the case with the 75Xs. The seats are right there by L2. |
Quoting skymiler (Reply 11): Any chance of an L2 door for boarding, as used on the 757? |
Quoting larshjort (Reply 12): Airbus Toulouse only produces A320s, not 319 and 321s. |
Quoting audidudi (Reply 8): Are you saying that these non-NEO A321s are going to have the new A350 style interior? I'm surprised that it wouldn't be introduced on the NEOs instead! |
Quoting lightsaber (Reply 18): If the A321 does as well as I believe, Toulouse will have to adapt to the longer model. |
Quoting DL_Mech (Reply 17): Actually, there are no seats in front of L2 but there are two seats in front of R2. The LOPA of the A321 on the Deltanet shows seats in front of L2 and R2. |
Quoting flyboy80 (Reply 23): Obviously the Airbus floor plan doesn't tapper as much in certain areas, as does the 737s, but this airplane with 192 seats including 20F, is going to be quite tight I imagine. |
Quoting DL_Mech (Reply 17): Quoting FlyASAGuy2005 (Reply 16): That's the case with the 75Xs. The seats are right there by L2. Actually, there are no seats in front of L2 but there are two seats in front of R2. The LOPA of the A321 on the Deltanet shows seats in front of L2 and R2. |
Quoting FlyASAGuy2005 (Reply 24): Quoting flyboy80 (Reply 23): Obviously the Airbus floor plan doesn't tapper as much in certain areas, as does the 737s, but this airplane with 192 seats including 20F, is going to be quite tight I imagine. I thought so too but actually, not really. Those big exit doors makes a difference. US Airway's config. is 187 pax and I always find their Y to be quite comfy/roomy. |
Quoting mjoelnir (Reply 21): Anyway with XFW and BFM, the capacity for A321 should reach 28 per month this year and that is more than half of the 46 frames capacity for all lines reached after BFM is up to speed end of this year. |
Quoting FlyASAGuy2005 (Reply 22): Are you saying they are pretty much directly in front the door on the A321 like row 19DE on the 75X? |
Quoting cschleic (Reply 25): For the DL 321, here's a link to a French article, with what's clearly a photoshop image. Aside from the L2 being an R2, and the baggage compartment doors on the wrong side (looks like a reversed image), it's probably a good representation. http://www.aeroweb-fr.net/actualites...6/delta-commande-15-airbus-a321ceo |
Quoting lightsaber (Reply 28): Well if production goes to the rumored 63/month and the A321 breaks half the demand (I believe it will approach 60 percent), then Airbus will need to look. |
Quoting lightsaber (Reply 28): I am curious if Toulouse could make A321s. If not, what is needed.. |
Quoting flyboy80 (Reply 4): I know Delta is supposedly the launch customer for this interior |
Quoting audidudi (Reply 8): these non-NEO A321s are going to have the new A350 style interior? I'm surprised that it wouldn't be introduced on the NEOs instead! |
Quoting mjoelnir (Reply 31): XFW is supposed to get the next new FAL. That would bring XFW to 32 frames a month, with BFM at four or upped to 8, that would make 36 to 40 frames possible capacity for A321. |
Quoting Alitalia744 (Reply 34): Anyone have the LOPA or seat map that can be posted? |
Quoting FSDan (Reply 38): |
Quoting 747d10 (Reply 13): It's interesting to see the German flag on the tail. |
Quoting FlyASAGuy2005 (Reply 44): |
Quoting jetmarc (Reply 39): I wanted to ask the same! If they are using space-flex galley, no mid cabin lavs at all? Maybe one fwd of 2L/R? Are they going to mirror the 739ER layout as much as possible? |
Quoting cschleic (Reply 25): AA has seats more or less in front of L2 on the 757, but they use it for boarding anyway. I believe they use L2 for boarding for their 321 transcon planes, but that was a requirement they had for their customer base on those planes. |
