eirbus06
Ethiopian 737 ADD-MAD
Tue Feb 16, 2016 4:32 am
I came across this flight on flight aware and noticed the average flight time of 07hrs 45mins on a 737. I wonder how they make any money with the penalty they must be taking. Is this more of a privatair type of service?
https://uk.flightaware.com/live/flight/ETH712
TC957
RE: Ethiopian 737 ADD-MAD
Tue Feb 16, 2016 11:18 am
Looks we have a new contender for the longest 738 regular scheduled flight, and that out of hot & high ADD. Quite impressive !
I don't think ET have any 737's in an all-biz class config a la Privatair.
[email protected]
Tue Feb 16, 2016 11:28 am
As the crow flies, PTY-MVD (11x weekly) is slightly longer (3,385mi) than ADD-MAD (3,382) and is by the 738. CM have a number of routes within the 2,750-3,385mi range all by 73s.
TC957
Tue Feb 16, 2016 11:34 am
Ah yes, PTY - MVD is 8 miles more according to Galileo GDS. Showing as 3396 v 3388 for ADD-MAD.
winGl3t
Tue Feb 16, 2016 12:32 pm
The main difference is that both PTY and MVD are almost at sea level, while ADD and MAD sits at 7600 ft and 2000 ft, respectively.
qm001
Tue Feb 16, 2016 12:54 pm
I wonder what the pax hit would be on this routing?
I wish there was still a flying boat service on the African Lakes!
SCQ83
Tue Feb 16, 2016 1:04 pm
This flight is to feed Ethiopian's hub in ADD, so I don't think they need a huge load to make it work. TK's short haul flights to Europe have on average relatively low loads.
TC957
Tue Feb 16, 2016 2:50 pm
Quoting SCQ83 (Reply 6):
Flown on many half-empty TK services from point in Europe to IST have you ?
SCQ83
Tue Feb 16, 2016 3:20 pm
Quoting TC957 (Reply 7):
Yes I have  .
In any case I remember reading here loads for TK services in Europe, and while there were all over the spectrum, most were between 60-70-80%, which is already a big "load penalty" so to speak.
clrd4t8koff
Tue Feb 16, 2016 5:16 pm
Don't they fly 757's? Seems like a more capable aircraft of handling the challenges of the route, with not that much greater capacity, no?
N1120A
Tue Feb 16, 2016 6:20 pm
Quoting clrd4t8koff (Reply 9):
They only have 2 of them. I'd imagine a 73G would make more sense.
seabosdca
Tue Feb 16, 2016 6:49 pm
ET operating this route westbound with a 738 is kind of remarkable. Under typical conditions at ADD the 738 can manage a takeoff weight of only around 72 t. At an OEW of 42 t and with a full fuel load of ~20 t (given altitude), that only allows ~10 t for payload. Eastbound is far less of a problem.
By contrast a high-thrust, high-TOW 73G should usually take off at MTOW from ADD and wouldn't have any problem flying this route with a full passenger load.
winGl3t
Tue Feb 16, 2016 8:12 pm
Quoting seabosdca (Reply 11):
ET is indeed flying 73G on the route configured with 118 pax (16C 102Y).
N1120A
Tue Feb 16, 2016 10:41 pm
Quoting winGl3t (Reply 12):
Now that makes a lot more sense
TS-IOR
Tue Feb 16, 2016 10:59 pm
I have asked that same question on the Tech-Ops forum sometime ago and didn't get any answer! I wondered if these 737s were HGW or payload restricted or something. The -700 has the longest range among the NG family but wouldn't imagine a non-BBJ would be able for it.
seabosdca
Thu Feb 18, 2016 3:57 am
There have been a few subs with 738. It operated the route nonstop in around 7:40. Passenger loads must have been terrible.
But then again 118 on a 73G is almost a BBJ configuration.
Quoting TS-IOR (Reply 14):
You can pretty much always assume that any aircraft ET flies has the highest thrust option given the conditions at ADD, and the highest MTOW given the long stages ET flies and the typical baggage/cargo loads coming into ADD. They may be the single airline in the world with the most demanding field performance requirements.
[Edited 2016-02-17 20:00:01]
aerorobnz
Thu Feb 18, 2016 6:17 am
I flew a 763 ADD-FCO which was continuing onto MAD. Is this 738 supplementary or replacing this MAD service?
Flown to 147 Airports in 62 Countries on 83 Operators and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
N1120A
Thu Feb 18, 2016 10:20 am
The -700 has the longest range and best takeoff performance. The -700 has truly excellent performance, so that it is able to take off out of ADD and fly to MAD isn't so far-fetched, especially configured only to 118. CM is running longer routes with 738s.
Quoting aerorobnz (Reply 16):
73G
vinniewinnie
Thu Feb 18, 2016 3:21 pm
Quoting seabosdca (Reply 15):
Passenger loads are not that good from what I heard. Addis may be hot & high during the day, but it is definitely cold & high during the night.
ET is one of the strangest airlines there is I find. They will fly any plane to any destination. I don't know whether they just tailor the size of aircrafts according to demand, but you will find 777L to Nigeria, 738, 767's, 787's to Kinshasa, and sometimes a 737 followed by a 777 from JNB.
I just don't get it...
[email protected]
Thu Feb 18, 2016 3:28 pm
Quoting vinniewinnie (Reply 18):
Right-sizing supply with demand
vinniewinnie
Thu Feb 18, 2016 5:04 pm
Quoting [email protected] (Reply 19):
Which airline has that luxury? There is fundamentally something very wrong with Ethiopian's business model from Addis I believe. Time will tell.
[email protected]
Thu Feb 18, 2016 5:52 pm
Quoting vinniewinnie (Reply 20):
Because it can right-size when it is required because of sufficient flexibility? As ET is Africa's only meaningfully successful airline, let's hope you're wrong.
vinniewinnie
Thu Feb 18, 2016 6:34 pm
Quoting [email protected] (Reply 21):
Well there is something fundamentally wrong in the African Aviation sector: Prices are sky-high! African countries were meant to implement the Yamassoukro treaty, but never did. Thus, competition has been stiffled, largely leading to these sky-high prices.
Could Ethiopian survive if African skies were a bit more freer? I'm not sure.
Not all success is beneficial...
seabosdca
Thu Feb 18, 2016 6:36 pm
ET's fleet usage is either a marvel of flexibility or a frantic juggling act, and I'm never quite sure which. It will be even more fun to watch as they add 359s, 789s, and low-TOW "teen" 788s to the mix.
[Edited 2016-02-18 10:38:37]
Flaps
Thu Feb 18, 2016 6:45 pm
Quoting vinniewinnie (Reply 22):
Given the obstacles and challenges faced by much/most of African aviation I would suggest that ANY success is beneficial. ET is one of the few successful operators in that arena. I would most definitely say that they of all operators on the continent "have their shit together".
ETinCaribe
Thu Feb 18, 2016 7:49 pm
This is something ET's CEO always complains about.
Actually, the biggest beneficiaries of this reality are non African carriers: EK, TK, AF/KL, BA, etc. The same carriers are ET's competitors, so I am not sure ET is that privileges for being an African airline.
Not sure, when they have more profits than all other African carriers put together, I would say they know what they are doing and it is not just pure luck.
jetsetter629
Thu Feb 18, 2016 8:29 pm
Quoting ETinCaribe (Reply 25):
A recent article in The Economist shows just how much African nations lose in GDP because of their inability to open up their skies
Source
ACDC8
Thu Feb 18, 2016 9:28 pm
Quoting N1120A (Reply 17):
Not wanting to go off topic, but we had a -700 flying from SJD to YYC the other week, which is just under a 5 hour flight, so no biggie on that. But during the crew announcements, the captain mentioned due to our weight, we'll be doing a series of step climbs for our flight before levelling off at FL400. I found that interesting that he informed us (not that anyone other than myself cared LOL) but it got me thinking, while its pretty much routine on large long haul aircraft, is this a common practice on smaller aircraft as well?
A Grumpy German Is A Sauerkraut
N1120A
Thu Feb 18, 2016 9:59 pm
Except that they are, by far, the most financially solvent African carrier.
They would make even more money.
Quoting ACDC8 (Reply 27):
Not as common, but still possible
vinniewinnie
Fri Feb 19, 2016 5:34 am
Agreed
Well given how Ethiopia is managed (state control of many strategic enterprises is common), I wouldn't be too sure how profitable they are without government help.
I'm in Addis at the moment: The government hand is heavy and that is in every sector of the economy.
Quoting N1120A (Reply 28):
Not sure. Check any OD piair such as Entebbe to Nairobi, Ouagadougou - Abidjan, Yaounde to Libreville etc. 1 to 2 hours sectors cost 400-600 euros return no matter.
With a freer market, U'd expect these fares to tumble by 50% at least, but unlike Europe, lower prices may not bring that much demand, given how unaffordable aviation is for the masses.
Developing markets are not as price sensitive as developed market
Quoting jetsetter629 (Reply 26):
Exactly
Tristarsteve
Fri Feb 19, 2016 11:16 am
We have a daily Ethiopian at ARN. It arrives around 0900 and departs at 1900. The aircraft type and the routing varies daily. In the last six months I have seen B787 B777 (various types) B767 and two B737NG parked on the ramp. The routing is also via Rome or Vienna or Frankfurt. How anyone keeps track I don't know.
[email protected]
Fri Feb 19, 2016 11:17 am
Quoting Tristarsteve (Reply 30):
Because that's their job?
Viscount724
Sat Feb 20, 2016 3:35 am
Canadian North has been operating SJD-YYC-YEG on behalf of Air Transat using a 737-300 recently.
