SpaceshipDC10
AC835 Diverted To LHR
Tue Feb 23, 2016 4:28 pm
It happened about three hours ago while the flight to YUL was cruising south of ORK. It's now back in the air since about one hour.
I guess it was probably a medical deiversion.
http://www.flightradar24.com/data/airplanes/c-ghlm/#8e61010
fraT
RE: AC835 Diverted To LHR
Tue Feb 23, 2016 5:12 pm
FRA-YUL should be AC875.....
AC835 is FRA-YOW when it comes back
SpaceshipDC10
Tue Feb 23, 2016 5:49 pm
Quoting fraT (Reply 1):
What?
Whiteguy
Tue Feb 23, 2016 6:58 pm
AC835 is GVA-YUL-YYZ, has nothing to do with FRA.....
YOW-FRA AC838, 839 for the return.....summer only!
fraT
Tue Feb 23, 2016 8:48 pm
Sorry, blackout on my side. I mixed up the numbers....
TonyBurr
Tue Feb 23, 2016 10:00 pm
OK, where is this flight coming/going to? Best to put airports not just flight numbers. Some of us are not able to memorize all the flight numbers of all the airlines.
SpaceshipDC10
Tue Feb 23, 2016 10:42 pm
Quoting TonyBurr (Reply 5):
I understand that. Did you open the link?
DAL763ER
Wed Feb 24, 2016 11:26 am
You can open the link or, say, google it, though, right?
Boeing744
Wed Feb 24, 2016 1:25 pm
If just medical why would this flight not have diverted to DUB or SNN? Seemed much closer.
I am taking the YUL-YYZ portion of this flight tomorrow...
SpaceshipDC10
Wed Feb 24, 2016 2:27 pm
Quoting Boeing744 (Reply 8):
I asked myself the same question. I guess, if it was a medical, it didn't require an asap landing. Also, since the flight was heading to YUL and YYZ, there are more options from LHR for that person to continue her/his journey when in better health again.
StarAC17
Wed Feb 24, 2016 3:14 pm
If it is a non emergency then I think landing at LHR would make more sense because AC has ops there to make handling of the flight easier and if a crew change would be needed they would have that available at LHR.
One question.
Would this flight have to dump fuel or could it land heavy? It is listed as a 333 which has a much longer range than GVA-YUL so I would think they could land but I am not sure of the rules regarding this.
Engineers Rule The World!!!!!
Whiteguy
Wed Feb 24, 2016 4:21 pm
Quoting StarAC17 (Reply 10):
AC A333 cannot dump fuel, I'm sure it was a heavier than normal landing but perfectly capable...
SpaceshipDC10
Wed Feb 24, 2016 6:08 pm
GVA-YUL is about 8 hours long. Then you have to add all the fuel reserves necessary. The aircraft was airborne about 2 and a half hours before landing at LHR. I don't know what's AC A333s MLW but I think it was a heavy landing.
skipness1E
Wed Feb 24, 2016 7:01 pm
Air Canada have substantial engineering cover at as well as substantial lift each day going West if they had to retoute the passengers so way more operational flexibility than DUB/SNN. Unless there was an imminent threat to life this makes way more sense.
Whiteguy
Wed Feb 24, 2016 7:54 pm
Quoting SpaceshipDC10 (Reply 12):
Probably a heavier than normal landing but not overweight, they weren't on the ground long so there probably wasn't an over weight mtc inspection done or it was fairly quick. With no fuel dump capability the aircraft max landing weights are usually pretty close to take off weights, and being a couple hours into the flight already, it probably wasn't an issue.
Viscount724
Thu Feb 25, 2016 1:41 am
Quoting Whiteguy (Reply 14):
Not the case for many aircraft including the A330. Airbus shows a difference of roughly 60,000 to 80,000 lbs between max takeoff weight and max landing weight for the A330. There are numerous variations depending on optional gross weights etc.
Whiteguy
Thu Feb 25, 2016 4:12 am
Quoting Viscount724 (Reply 15):
Fair enough but in a typical operation I wonder how close it would actually be....
SpaceshipDC10
Thu Feb 25, 2016 11:26 am
I wonder how much the main landing gear design allows for greater margin?
