Quoting rutankrd (Reply 2): I really couldn't imagine anything worse than 23 hours in a tube and modified air at 10,000 feet pressure even in a bath chair and £10,000 the lighter ! |
Quoting kurtverbose (Reply 1): LHR-SYD |
Quoting stealthz (Reply 3): Quoting rutankrd (Reply 2): I really couldn't imagine anything worse than 23 hours in a tube and modified air at 10,000 feet pressure even in a bath chair and £10,000 the lighter ! Can that be much worse than 14hrs + 2 or more hrs wandering DXB/AUH then another 7or so hours in the same tube? |
Quoting VV701 (Reply 6): If a 772ER can do it I am pretty sure a 380 could. But this would not be possible with anywhere near a full load. |
Quoting PatrickZ80 (Reply 7): Quoting VV701 (Reply 6): If a 772ER can do it I am pretty sure a 380 could. But this would not be possible with anywhere near a full load. You realize the 772 does have a longer range than the A380, it's currently the aircraft with the longest range in the world. |
Quoting classiclover (Reply 8): Therefore, I'd say the A380 could do it just fine under similar conditions. |
Quote: The flight took place on 16-17 August 1989, a few months short of 70 years after the Smiths set out. In order to maximise range, a special high-density fuel was used, the tanks were filled to overflowing and the aircraft was towed to the runway holding point before starting engines. The engines themselves were specially chosen examples. Although the aircraft was fully fitted out inside, to save weight all non-essentials, such as galley equipment, were removed. |
Quoting PatrickZ80 (Reply 7): You realize the 772 does have a longer range than the A380, it's currently the aircraft with the longest range in the world. |
Quoting PatrickZ80 (Reply 7): |
Quoting PatrickZ80 (Reply 7): I'm not able to find any info about it, but I remember something about the longest non-stop flight ever performed on a 777. It departed from SYD flying eastbound across the Pacific, overflying America and the Atlantic and finally landing at LHR. |
Quoting kurtverbose (Reply 1): No. http://www.airbus.com/aircraftfamili...eraircraft/a380family/performance/ |
Quoting Hagic (Reply 18): There's nothing more refreshing that a layover at SIN, the best airport in the world in my opinion. It has the best restaurants, high-quality food courts (not expensive at all), relaxing areas, and a great view of the A380 landings on either runway. |
Quoting Hagic (Reply 18): Why would you need a non-stop LHR-SYD? There's nothing more refreshing that a layover at SIN, the best airport in the world in my opinion. It has the best restaurants, high-quality food courts (not expensive at all), relaxing areas, and a great view of the A380 landings on either runway. For me, a stop in SIN is part of the trip. |
Quoting Mortyman (Reply 21): Stop overs cost money ... |
Quoting Stitch (Reply 22): (as the fuel loads for LHR-DXB and DXB-NRT together are less than the fuel load for LHR-NRT). |
Quoting Stitch (Reply 22): They do, but shorter stage lengths need less fuel and can carry more payload (less fuel weight means more payload weight). So if you have the traffic / cargo loads on each leg, you can make more money than a non-stop. |
Quoting Mortyman (Reply 25): I was commenting on "Hagic" post and from a passenger perspective, not an airlines economic perspective. I don't wanna spend money on a hotel etc in a city that is not really part of a desired travel plan if I can avoid it. |
Quoting Stitch (Reply 22): (as the fuel loads for LHR-DXB and DXB-NRT together are less than the fuel load for LHR-NRT) |
Quoting tommy1808 (Reply 23): I very,very highly doubt that. |
Quoting Stitch (Reply 27): Perhaps not on that specific mission, but the fuel burn should not be significantly more than doing a non-stop. And the revenue from the extra payload would comfortably cover it. |
Quoting rbrunner (Reply 29): Really? Longer than the A340-500? |
Quoting LH707330 (Reply 30): So does filling up with more fuel to carry the fuel you need to carry later. |
Quoting LH707330 (Reply 30): This makes sense, but the market seems to have voted with its wallet. If there were a strong demand to save the 2-3 hours of a SIN stop, some airline would offer the LHR-SYD nonstop with a hefty (>50%) price premium. |
Quoting Hagic (Reply 18): Why would you need a non-stop LHR-SYD? |
Quoting Stitch (Reply 27): It's why a number of freight operators put in a stop in Anchorage on Asia-North America runs. |
Quoting Viscount724 (Reply 38): The problem is that you need a lot of those high-fare passengers on such a long nonstop route to offset the costs and I doubt there would be enough demand. |
Quoting LAX772LR (Reply 39): There's probably enough for at least one flight... the question is, how does any one airline (of the ones who'd have the right to operate nonstop) aggregate all of those pax onto a single segment? |
Quoting tommy1808 (Reply 32): Around 4% if you split a 6000nm mission into 2x 3000nm missions. And that is without a long taxi on a crowded hub airport in the middle. Unless your midpoint airport is right in the middle and smack under the optimum flight path, you won't save fuel. |
Quoting tommy1808 (Reply 33): That would take an 77L with 3 aux tanks and without a meaningful payload. I'd say there just isn't a frame that could do it with a 50% premium. |
Quoting LAX772LR (Reply 39): the question is, how does any one airline (of the ones who'd have the right to operate nonstop) aggregate all of those pax onto a single segment? |
Quoting TWA772LR (Reply 45): I'll start with: 77L VC-25 744 (as proven in QFs demonstration some years ago) |
Quoting AirbusA322 (Reply 36): Virgin flew an A330 on Delivery nonstop a few years ago. Was about 20 hours from memory |
Quoting gemuser (Reply 46): Both have been delivered non stop from TLS to SYD |
Quoting TWA772LR (Reply 45): Can tanker planes tap into their fuel that they pass on to other aircraft? If so, I'd think the KC-10 would be a contender also. |
Quoting gemuser (Reply 44): Quoting LAX772LR (Reply 39): the question is, how does any one airline (of the ones who'd have the right to operate nonstop) aggregate all of those pax onto a single segment? Which is only QF & BA and it wouldn't be the first time they jointly operated flights. There is NO Australia/EU bilateral so the other EU airlines don't have the rights. |
Quoting gemuser (Reply 44): Which is only QF & BA and it wouldn't be the first time they jointly operated flights. There is NO Australia/EU bilateral so the other EU airlines don't have the rights. |
