Quoting LAXintl (Reply 1): Ordinance makes no adjustments for weather. |
Quoting AirCalSNA (Reply 5): Do the noise-restriction rules apply to take offs from 2L on Santa Ana wind days? |
Quoting barney captain (Reply 6): We had to abandon the noise abatement profile once due to wind shear. Although the convective activity wasn't directly along our path, shortly after engine cutback we encountered the wind shear. |
Quoting wnflyguy (Reply 2): Some may alter their thrust and take off paths in the event of wind shear or advised by the tower for traffic in the area. So in the those 2 events any excess noise is exempt. |
Quoting BoeingGuy (Reply 7): Last time I flew out of there in an AS 73G, there was no noise-abatement procedure. He flew a standard climb thrust reduction. I wasn't sure why. Although the 73G noise abatement procedure is fairly tame, they usually do it. |
Quoting AAR90 (Reply 11): AA 738s have had no special noise abatement procedures at SNA for more than a decade. It took 4+ years to convince the SNA folks to conduct actual test flights in order to prove the 738 noise footprint in a standard departure procedure was considerably quieter than the SNA noise standards. After 4 months of historical data, SNA agreed and AA 738s have no special noise procedures at SNA. I would assume other airlines using 738s could "piggy-back" on that data and get authorization for no special noise procedures at SNA. |
Quoting AAR90 (Reply 11): It took 4+ years to convince the SNA folks to conduct actual test flights in order to prove the 738 noise footprint in a standard departure procedure was considerably quieter than the SNA noise standards. |
Quoting B747400ERF (Reply 13): Isn't the noise abaitment to full throttle using the highest rate of climb possible? That never made sense to me, it is much louder than a reduced thrust takeoff and throttle back after reaching min height. |
