Quoting American 767 (Thread starter): |
Quoting American 767 (Thread starter): I would not think so, because LAX sees only twice or three times daily the 763, and only to or from MIA, and it would be flown by MIA based crews. |
Quoting SESGDL (Reply 5): Boring... I long for the days of tri-holers and four-holers. |
Quoting phillyramp270 (Reply 1): Quoting American 767 (Thread starter): Most of the 321s and 320s come from PHL and CLT.. You got some of the 321Ts from New Yorks as well |
Quoting phillyramp270 (Reply 1): Most of the 321s and 320s come from PHL and CLT.. You got some of the 321Ts from New Yorks as well Must be an interesting sight |
Quoting N1120A (Reply 14): |
Quoting GG22 (Reply 13): Is there an overview showing the remaining AA MD-80 operations ? LAX-LAS does not see any AA MD-80 operations by the End of 2016 ? |
Quoting N62NA (Reply 17): I just hope LAX-MIA can keep the daily 77W for years and years and years to come! That will more than make up for the inevitable trend to 738 / A32B on the route. |
Quoting wn676 (Reply 15): If I've got the right numbers, it looks like the Ts represent a little over 20% of AAs 321 ops at LAX. By far the largest of the subfleets represented there currently is the standard config LAA 32B (including the ETOPS birds) which comprise about 50% of their 321 departures. |
Quoting MAH4546 (Reply 18): Five out of eight daily MIA-LAX flights are a widebody looking at a random day in June. There isn't such a trend. |
Quoting N62NA (Reply 23): The equipment on that route fluctuates every few months such that half or slightly more than half of the flights could be narrowbody 738/32B and at other times half or slightly more than half of the flights could be widebodies/75L. Very inconsistent hard product on such a "prestige" route. April 6th: 3x 738 1x 32B 2x 763 1x 772 1x 77W May 4th 3x 738 1x 32B 3x 763 1x 77W |
Quoting rta (Reply 24): Not really sure what you're getting at. The only difference is that the 772 switched to a 763. |
Quoting dfwjim1 (Reply 25): What is considered a "prestige" route? |
Quoting cageyjames (Reply 26): MIA - anything |
Quoting cageyjames (Reply 26): |
Quoting N62NA (Reply 27): |
Quoting dfwjim1 (Reply 28): Are you guys taking swipes at the sacred cow? |
Quoting N62NA (Reply 27): And that's the point. It's a wildly varying array of hard product on this route. |
Quoting N62NA (Reply 29): Getting back to the topic, it was mentioned earlier that a 75L will once again make an on again off again appearance on MIA-LAX. Would be nice if there was some way to get more of those on the route to replace some of the 32B and 738 flights, and that way the AA 757 would continue to visit LAX too! |
Quoting cageyjames (Reply 33): I used to spend time trying to figure out which equipment was flying LAX-MIA and pick accordingly. I can only assume in my older age I go on schedule and care less as long as it's non-stop. That said, I'm happy to be on a larger aircraft than |
Quoting N62NA (Reply 34): So long as they keep the 77W on the late afternoon departure, that's the flight I'm picking. |
