HB-IWC
TG To Remove A380 From FRA Route?
Wed Mar 16, 2016 3:29 am
Thai Airways has updated its S16 schedule, which will see the A380 deployed on the BKK KIX midnight departure. With a 6-strong A380 fleet, this new flight is incompatible with flights to FRA, CDG and LHR in that same midnight departure hub. While the A380 is still displayed on the BKK FRA route, the airline has closed First Class availability for these flights, indicating that a swap to B77W equipment may be imminent for the TG920/921 rotation. A380 equipment remains scheduled for CDG, LHR and NRT.
sq_ek_freak
RE: TG To Remove A380 From FRA Route?
Wed Mar 16, 2016 8:15 am
Wow a high premium config A380 for a sub 7 hour redeye from Bangkok to Kansai? Seems extremely aggressive to me!
Keep Discovering
TC957
Wed Mar 16, 2016 8:16 am
Good spot there, yes, it does look like it. I'd call that sensible use of the A380 fleet to meet seasonal demand. I'm sure the 380 will be back on FRA in winter 16/17 season, as it looks like KIX will get the 744 then.
SJOtoLIR
Wed Mar 16, 2016 11:51 pm
Thai Airways has already updated the planned Bangkok - Frankfurt route for summer 2016 season.
From March 27th, TG will continue to operate 13 weekly flights as described: TG BKK-FRA [7x 380 + 6x 77W].
However, this will be temporary reduced to 11 weekly from April 29th to June 26th: TG BKK-FRA [7x 380 + 4x 77W].
Regards.
"Goin' up to the spirit in the sky"
TC957
Thu Mar 17, 2016 12:18 pm
Still doesn't explain why F class is blocked off sale as per opening post.
jumpjets
Thu Mar 17, 2016 12:22 pm
Quoting TC957 (Reply 4):
Maybe its already all full...
SQ22
Sat Mar 19, 2016 7:20 pm
No issues with F availability in May also showing A380 on TG's webpage.
EMAman
Mon Mar 21, 2016 4:15 pm
what happened to the LHR route in the end, from memory not clear if reduced to 1xD or not?
TC957
Mon Mar 21, 2016 4:21 pm
Quoting EMAman (Reply 7):
LHR - BKK with TG will stay as it is now except the evening flight will go from daily to 5 a week.
So still daily A380 and 5 a week 77W this summer.
jumpjets
Mon Mar 21, 2016 4:24 pm
Still showing on the timetable as 2 a day through the summer and into W16. 1x A380 and 1x777
TC957
Mon Mar 21, 2016 7:20 pm
Quoting jumpjets (Reply 9):
The Tuesday & Thursday 77W rotations have been cancelled for the summer season.
Re-instated back to full double daily from 30 Oct.
N14AZ
Fri Mar 25, 2016 2:00 pm
http://airlineroute.net/2016/03/25/tg-fracdg-s16/
Just found this link on http://fraaviation.forumsfree.de ...
Do TG's 777-300ER have real flat beds in business class similar to the one they have on their A380's?
Just came home with one of their A380's. A colleague of mine once took their 777 and told me they do not have real flat beds but maybe that changed in the meantime...
lawair
Fri Mar 25, 2016 2:21 pm
Quoting N14AZ (Reply 11):
The business class product is the same on A380s and 777-300ERs: 1-2-1 with fully flat beds.
The business class product on all other 777s is angled lie-flat, with slight variation. That includes the -200, -200ER (used for a couple non daily European routes), and -300. The -200 and -300 are limited to regional and possibly Australian flights (unless I'm out of date on that last point)
EI320
Fri Mar 25, 2016 3:16 pm
To be replaced by a B744
nethkt
Sat Mar 26, 2016 3:51 am
The 380s will be under check and maintenance work, and the 777-300ER will be utilized iso 747-400 due to low demand in F class and economical reasons (fuel, crew rotation and YIELD)
Brgds.
Net-HKT
N14AZ
Sun Mar 27, 2016 12:43 pm
@ lawair, reply no. 12: thank you very much for your feedback. I am not sure if my next flight will be before the A380's are back on this route. So good to know that business class is the same on both aircraft. Thank you.
