Quoting airliner371 (Reply 2): |
Quoting ouboy79 (Reply 4): |
Quoting wnflyguy (Reply 3): I'm predicting a July 4 th start date! Giving LGB the Freedom from bag fees , change fees and the freedom to connect to more than 80 WN destination. |
Quoting wnflyguy (Reply 8): May 8th 1971 was the first day the Queen Mary opened to the public in the port of long beach. So I can see opening service to on MAY 8th 2016 giving the Air Port of Long Beach connection to 71 southwest destinations. |
Quoting ASFlyer (Reply 9): You're just guessing at this stuff, aren't you? |
Quoting wnflyguy (Reply 8): May 8th 1971 was the first day the Queen Mary opened to the public in the port of long beach. |
Quoting avi8 (Reply 7): But that wouldn't allow many west coast connections (going all the way to Denver isn't really convenient). At least one west coast "hub" like OAK, PHX or LAS seems logical |
Quoting ASFlyer (Reply 9): |
Quoting ouboy79 (Reply 10): |
Quoting airliner371 (Reply 2): My guess is 2 OAK, 1 LAS and 1 DEN. |
Quoting wnflyguy (Reply 3): Quoting airliner371 (Reply 2): I agree I see OAK,DEN and LAS or lose DEN and add a MDW. |
Quoting BeachBoy (Reply 6): My predictions: DAL, HOU, DEN, MDW Maximizes "connections" and doesn't compete w/ B6. |
Quoting enilria (Reply 16): |
Quoting wnflyguy (Reply 18): Quoting enilria (Reply 16): I could see 2 OAK and 2 LAS. |
Quoting LAXintl (Reply 20): If Southwest wants to market to LB residents then it needs a strong solid business schedule to a destination with good frequency to lure them away from current LAX or SNA flights. Having a few random flights to different destinations wont do much to move the needle. But if Southwest however instead simply wants to show LGB as another destination option for those coming to SoCal then it can offer a lower frequency option to multiple markets that connect across the larger network. |
Quoting BeachBoy (Reply 6): My predictions: DAL, HOU, DEN, MDW |
Quoting LAXintl (Reply 20): If Southwest wants to market to LB residents then it needs a strong solid business schedule to a destination with good frequency to lure them away from current LAX or SNA flights. Having a few random flights to different destinations wont do much to move the needle. |
Quoting cageyjames (Reply 22): Honestly I see 4x OAK. SNA/LAX/BUR/ONT all can handle trips to the east. |
Quoting slcdeltarumd11 (Reply 29): The southwest model is usually to only serve cities they can have a minimum number of flights and LGB will never be that. |
Quoting aalaxfan (Reply 30): 2x PHX, 2x LAS Do all catering in PHX and LAS |
Quoting cschleic (Reply 26): The only problem with the latter scenario is, travelers from other parts of the country may not know about LGB and may not look for it or find it. True, there are packages, etc., But I've run into regular travelers from the east coast who've never heard of SNA, for example, and didn't know about its location and volume of flights. Maybe it would work better for the originating side of the L.A. basin connecting throughout the WN system. |
Quoting SWADawg (Reply 32): It's not like WN will be stuck with just 4 slots in perpetuity. Eventually LGB will reevaluate and release more slots that WN and other Airlines will be able to bid on. |
Quoting LAXintl (Reply 35): Well the way the southwest.com works is that that unless you specifiy only a single airport, the current 4 LA basin airports are listed under "Los Angeles" banner which gives the consumer visibility and choice. |
Quoting aalaxfan (Reply 30): Workforce arrives at 8:45 and leaves at 5:45 one shift. |
Quoting SWADawg (Reply 32): It's not like WN will be stuck with just 4 slots in perpetuity. Eventually LGB will reevaluate and release more slots that WN and other Airlines will be able to bid on. How do you think WN gradually acquired their impressive portfolio of SNA slots. Patience grasshopper. |
Quoting a380787 (Reply 36): How can one get that done for WAS or NYC or SF regions ? It seems that southwest.com wants me to search LGA EWR ISP or DCA BWI or SFO OAK SJC all separately. |
Quoting mercure1 (Reply 34): Is Los Angeles the only market where any airline service so many airports? |
Quoting wnflyguy (Reply 25): They could easily do 3 OAK with a daily MDW or DEN. |
Quoting SurfandSnow (Reply 37): I've been expecting something like a 3x daily OAK service all along, likely complemented by DEN for network connectivity purposes (not to mention the benefit of being a niche route free of direct competition). |
Quoting LAXintl (Reply 35): All airlines being issued slots this year have been told, these slots are the first ones to be withdrawn should airport noise increase pushing cumulative noise above the allowed maximum. |
Quoting icebird757 (Reply 42): I was told by Southwest employee that the station will be contracted out for both above and below the wing. |
Quoting a380787 (Reply 46): So pretty much everyone up thread guessed incorrectly =) |
Quoting enilria (Reply 19): The problem is that WN tends to only outperform the competition when they have a frequency advantage and 2 OAK's would give them a weaker schedule. I don't think frequency is as important to LAS as it is a leisure market. |
Quoting enilria (Reply 16): If you think about it, the only reason to fly to LGB is to take share back from B6. So, it would make sense only for them to fly only where B6 operates. I think that pushes them toward OAK/SFO and LAS. Maybe 3 to OAK/SFO and 1 to LAS. |
