Quoting UA444 (Thread starter): What is the status on the FX DC-10 retirements? |
Quoting SpaceshipDC10 (Reply 1): They have no more DC-10 |
Quoting UA444 (Reply 5): What is status of N365FE? |
Quoting UA444 (Reply 3): Semantics. MD-10s are still the same DC-10s with the same DC-10 fuselage, engines, flight characteristics, etc. |
Quoting adipasquale (Reply 9): I don't know a ton about FX, but what I understand is they are retiring the MD-10s as they cycle/time out and new 767s are delivered. As it was stated above, apparently some MD-10s are going through C-checks due to low fuel prices and 767s not coming online fast enough. |
Quoting awthompson (Reply 13): This aircraft became N370FE with Fedex and as far as I can see it is still active at around 44 years old. I saw it on flightradar not that long ago. |
Quoting panampreflight (Reply 17): Sometimes two at a time in PHX. |
Quoting DUSdude (Reply 19): Speaking of FedEx MD10s, here in Chicago in the evening I see one regularly approaching ORD. When I look it up on flightradar it turns out to be a flight from MKE. How does it make any economical sense to fly a 40+ year old three holer on such a short route when you could put all that cargo on a truck and still make it in the same business day (especially since it's an evening flight)? |
Quoting TZTriStar500 (Reply 10): Its actually not semantics. The MD-10 modification is a change to the type certification as an amendment to the TC and not an STC. The data plates of a DC-10-10, -10F, -30, -30F are changed to a MD-10-10F or -30F, respectively. They are separate models in the TCDS. |
Quoting atypical (Reply 24): The difference is in a retrofitted cockpit so only 2 crew members are required instead of 3. I don't see that this change makes the aircraft any less of a DC-10 than it was before. The change in crew required a change in flight certificate and that was the name they chose. The performance characteristics of the 2 aircraft are identical except the Flight Deck. None of the general posts in this thread would have suffered at all if DC-10 was used instead of MD-11. |
Quoting iahcsr (Reply 28): I could be wrong but I think it was 1980 (?) FE bought eight DC-10-10CFs from CO N68049-056. |
Quoting ltbewr (Reply 29): It says a lot about the original design, over-engineering and quality of MX by FedEx that these DC/MD-10's are still in daily use for decades. |
Quoting nikeherc (Reply 31): I would say that, structurally and functionally, the DC-10 was over engineered. The engineering for some systems was probably deficient. Namely all three hydraulic systems were routed throug a small area near the center engine and there was no interlock to prevent asymmetric operations of the leading edge slats. Also, the floor vent system was inadequate as was the cargo door locking system. These four design issues led to three of the most notorious airline accidents in history, ruined the reputation of the DC-10 for a long time and killed its sales. |
Quoting wrenchon727 (Reply 23): 68049 is next to retire within the next couple days. |
Quoting SpaceshipDC10 (Reply 1): Quoting wrenchon727 (Reply 23): 68049 is next to retire within the next couple days. This must be it on its final flight to VCV: http://flightaware.com/live/flight/F...X9038 |
