Quoting jfklganyc (Reply 1): 5 EK 1 KE 1 AF 1 LH seasonal 1 Singapore 1 Ethiad |
jfklganyc wrote:The old UA gates.
Gates 11 and 12 are widebody, domestic gates. If you look at the diagram there is plenty of ramp space for that to be converted to 1 380 gate if desired. It would need to get connected to the lower level customs. Very doable if desired.
As I write this at 515 ET, there are 5 BA 747s, 1 BA open skies 757, 1 BA 318, 1 ANA 777, and 1 Qantas 747. The terminal can handle a 380 load of pax.
The point is moot though...rumor around JFK...T7s future lies with B6. We'll see what happens. I remember when T5s future lay with UA. Wasnt that long ago either
jfklganyc wrote:Not really.
There's
5 EK
1 KE
1 AF
1 LH seasonal
1 Singapore
1 Ethiad (which has the best 380 paint job imo)
How many more gates do you want for 10 flights per day?
T8 can easily add for Qatar if they wanted to and T7 has plenty of space as well if BA decided to bring it in. Just need to add a jetway with a ramp down.
There are 2 at terminal 1 and 2 at Terminal 4.
The Emirates gate has a dedicated jetbridge from the lounge.
The other gate at the end of T4 A (across from EK) has 3 jetbridges but the third one is a movable up and down bridge that connects to the same level as the first two jetbridges.
There's
5 EK
1 KE
1 AF
1 LH seasonal
1 Singapore
jeffh747 wrote:jfklganyc wrote:There's also one Asiana. They use T4 I think?
lesfalls wrote:jfklganyc wrote:Not really.
There's
5 EK
1 KE
1 AF
1 LH seasonal
1 Singapore
AF operates 2 A380s a day now to JFK. Ethiad from June will also have 2 A380 flights a day. There was also a rumor that China southern wanted to send the A380 also to JFK but it couldn't due to no gates being available.
Web500sjc wrote:In the international area of terminal 4 passengers board by going down the switch back ramps down to aircraft level, which is even with the the customs level. When international aircraft arrive, passengers are barred from going up the ramp to the domestic area.
FSDan wrote:Web500sjc wrote:In the international area of terminal 4 passengers board by going down the switch back ramps down to aircraft level, which is even with the the customs level. When international aircraft arrive, passengers are barred from going up the ramp to the domestic area.
Isn't all of T4 international?
jeffh747 wrote:FSDan wrote:Web500sjc wrote:In the international area of terminal 4 passengers board by going down the switch back ramps down to aircraft level, which is even with the the customs level. When international aircraft arrive, passengers are barred from going up the ramp to the domestic area.
Nope, most of the B concourse is Delta, and Virgin America has a couple gates in A. Sun Country also used to go to T4 but I'm not sure if they still do anymore.
FSDan wrote:lesfalls wrote:jfklganyc wrote:Not really.
There's
5 EK
1 KE
1 AF
1 LH seasonal
1 Singapore
And I believe KE has both daily flights on the 388. So the count should be:
AF x2
LH x1
EK x4
EY x2
KE x2
OZ x1
SQ x1
That's 13 per day.
AA787 wrote:FSDan wrote:lesfalls wrote:AF operates 2 A380s a day now to JFK. Ethiad from June will also have 2 A380 flights a day. There was also a rumor that China southern wanted to send the A380 also to JFK but it couldn't due to no gates being available.
AF x2
LH x1
EK x4
EY x2
KE x2
OZ x1
SQ x1
That's 13 per day.
1x KE is a 748
jfk777 wrote:jfklganyc wrote:The old UA gates.
If T7 is going JetBlue where is BA going ? AA T8. JFK needs to address the old Pan Am T3 sight with a new terminal attached to T1 or T4. Where are all the old IAB airlines, seems most are at T1 which can't handle all those airlines. JFK needs more terminals desperately and there seems to be no rush from the PANYNJ. The T3 site has been empty for years now so build something on it please.
Right, I get that there are domestic flights that operate from T4, but I thought the whole terminal was international-capable. Are there gates that don't funnel into the FIS?
