Quoting hiflyer (Reply 1): Normally in a expected high wind environment the aircraft is attached to a pushback unit as well as all main chocked and extra fuel loaded. There was an expected frontal passage of storms thru the area this morning showing bright reds on radar. Tower shows 52kt gusts on the metar at 30950z with a steady at 31kt from the west....be 0450 lcl there. |
Quoting dfwjim1 (Reply 7): Why weren't the aircraft just flown out of AUS until the severe weather threat went away? |
Quoting Q (Reply 15): They learned lessons next time MOVE IT! |
Quoting chrisair (Reply 9): Whenever I see this video, I always laugh at the guy trying to hold the plane from moving with his foot... |
Quoting yeelep (Reply 11): Ideally the plane should be fully fueled and ballasted to 6%MAC. Nobody does it that I am aware of but that is the ideal if you follow the 737 AMM. |
Quoting BWI5OH (Reply 14): Will they send a crew to patch her up just to fly her back to IAH? Or will she be fully repaired in AUS? There are no hangers big enough in AUS, and I can't see it flying like it is. So how is this type of damage handled? |
Quoting Q (Reply 15): They should moved aircraft to stay away from jetways and vehicles each gates if the strong storm coming into. They learned lessons next time MOVE IT! |
Quoting ramprat74 (Reply 18): Are you God and can predict when a thunder cell will form over an airport? |
Quoting Q (Reply 22): What is a bit of lot money to move plane to put overnight remote parking? It doesn't that much cost money. Just one or two persons take a tow to plane push back then park it. Tow truck just as little as 1/3 of gallon burn gas. If plane moves it would burn as 200-400 times than tow burns gas! Q |
Quoting Alasizon (Reply 23): |
Quoting ramprat74 (Reply 28): Stop feeding the troll guys. |
Quoting Q (Reply 22): What is a bit of lot money to move plane to put overnight remote parking? It doesn't that much cost money. Just one or two persons take a tow to plane push back then park it. Tow truck just as little as 1/3 of gallon burn gas. If plane moves it would burn as 200-400 times than tow burns gas! |
Quoting BWI5OH (Reply 14): but I do know airlines would love to have their birds home when a MX problem arises. Will they send a crew to patch her up just to fly her back to IAH? Or will she be fully repaired in AUS? There are no hangers big enough in AUS, and I can't see it flying like it is |
Quoting Q (Reply 22): Just one or two persons take a tow to plane push back then park it. |
