blacksoviet
Where Did Korean Air Fly The 747-300?
Mon May 09, 2016 2:47 am
These aircraft had less range than the 747-200s?
eal
RE: Where Did Korean Air Fly The 747-300?
Mon May 09, 2016 2:56 am
I could be mistaken but these aircraft where mostly used on high density inter-Asian routes, NRT, HKG, PVG, GUM, FUK, etc. they where also used on two stop services to Australia (Brisbane and Sydney) and Canada (Vancouver and Toronto).
[Edited 2016-05-08 19:58:26]
Viscount724
Mon May 09, 2016 2:57 am
Higher passenger capacity in the premium classes due to the stretched upper deck was no doubt the reason. Range isn't always the #1 priority.
hoons90
Mon May 09, 2016 3:01 am
Immediately prior to retirement in 2005, the last 3 routes were GMP-HND, ICN-NRT and ICN-BKK.
Flown: 2L 7C 9E 9L AA AB AC AF AY AZ BA BR BX B6 CA CO CP CX DL EK EY JL KE KL LA LH LX MQ NW OZ PD RW SQ TG TP TR TS US WG WN WS XE XJ
blacksoviet
Mon May 09, 2016 3:06 am
Did they make a fuel stop between ICN and YVR?
N1120A
Mon May 09, 2016 3:09 am
They flew to LAX. I think via NRT.
Quoting blacksoviet (Reply 4):
Not a chance. A 741 could have done that route.
Viscount724
No.
RayChuang
Mon May 09, 2016 3:55 am
I'm pretty sure KE flew the 743 to LAX, though.
Viscount724
Mon May 09, 2016 4:37 am
SQ also used the 743 SIN-ICN-YVR for a couple of years in the mid-1990s. JL used the 743 NRT-YVR for quite a few years. If memory correct, KE, JL and SQ were the only 743 operators to YVR. I don't think KE used them very often as there are only 2 KE 743 photos at YVR.
Photo © John Kelley
Photo © Edge to Edge Photography
Photo © Erik Johannesson
aerorobnz
Mon May 09, 2016 4:54 am
AKL has had 742/74L/743/744/74H from KE
Flown to 147 Airports in 62 Countries on 83 Operators and counting. Wanderlust is like Syphilis, once you have the itch it's too late for treatment.
COSPN
Mon May 09, 2016 1:17 pm
One crashed in Guam due to overworking the crew
SpaceshipDC10
Mon May 09, 2016 1:28 pm
Quoting RayChuang (Reply 7):
Both pax and cargo.
Photo © Brian Bartlett
Photo © Frank C. Duarte Jr.
The cargo version also flew to ANC.
Photo © Sokol Ymeri
jfk777
Mon May 09, 2016 1:54 pm
Korean flew their 743 from Seoul nonstop to LAX in the years before the 744 came along, flying time to Seoul was about 13 hours.
kaitak
Mon May 09, 2016 2:56 pm
If I recall correctly. a Korean Air 743 made a cameo appearance in the 1990s movie "Speed" with Sandra Bullock and Keanu Reeves; it was just a "blink and you'll miss it moment", but I'm pretty sure it was a 743.
The 743 also made several visits to HKG.
titus95
Mon May 09, 2016 6:39 pm
743 KE was regular visitor at CDG , on the route SEL-CDG-SEL.
TWA902fly
Mon May 09, 2016 6:42 pm
If I recall correctly, they flew it into mountains
http://en.wikipedia.org/wiki/Korean_Air_Flight_801
'902
[Edited 2016-05-09 11:42:41]
life wasn't worth the balance, or the crumpled paper it was written on
SpaceshipDC10
Mon May 09, 2016 6:44 pm
Quoting TWA902fly (Reply 15):
You recall correctly, however it's not like they only had one in their fleet, like MH.
blacksoviet
Mon May 09, 2016 6:48 pm
How do you know it was a 743 and not a 744 in the movie Speed?
N1120A
Mon May 09, 2016 8:33 pm
Quoting blacksoviet (Reply 17):
Winglets
Jayce
Mon May 09, 2016 8:35 pm
Quoting Viscount724 (Reply 8):
KLM also used the 743 to YVR back in the mid 90s. Though I suppose some were technically 206 SUDs.
"Trying is the first step towards failure" -Homer Simpson
Adipasquale
Mon May 09, 2016 11:42 pm
Quoting N1120A (Reply 18):
Winglets
And engines. Here's what JT9s looks like on the 743:
Photo © Moyo
Here's what CF-6s look like on the 743:
Photo © Javier Rodriguez - AirlinersGallery
Which is slightly different than what CF-6s look like on the 744:
Photo © Rainer Bexten
Here's the PW4000s look like on the 744:
Photo © Markus Schmal
And here's what the RB211s look like on the 744:
Photo © Len Schwartz - NYC Spotting Team
Obviously looking at the winglets (or lack thereof) is easier, but looking at the engine differences is fun too!
DH8A DH8B CR1 CR2 CR7 CR9 E45 E70 E75 E90 D93 M88 318 319 320 321 333 343 712 732 733 734 73G 738 739 744 752 753 762 763 772 77L 77W
blacksoviet
Re: Where Did Korean Air Fly The 747-300?
Fri Jan 20, 2017 2:02 am
Were any 743s delivered with a 744 cockpit? What happened to Korean Air's 747-300s with the long starboard galley?
Users browsing this forum: Brianpr3, DylanHarvey, Ishrion, JacksonAviation, Lennundus, milhaus, Sokes, VS11, Wenlee and 176 guests
