Quoting deltadawg (Thread starter): d) IR - with Fokker 70/100 and MD-82's still active this could be a real possibility as long as Iran puts their new money into infrastructure instead of terrorism |
Quoting deltadawg (Thread starter): b) Will BBD increase production rate if they garner future orders similar to DL's? If so, how much can the Mirabel facility push out the door and how many orders are needed for BBD to start a second line? |
Quoting GE9X (Reply 1): I think I asked this in a previous thead and admittedly I have very little knowledge of Hawaiian Airlines and so the suggestion may be crazy, but how old are their 717s? I realize fuel burn savings are not that important on interisland short haul, but the CSeries could replace them *and* add the tremendous flexibility to have long and thin TPAC routes to smaller West Coast airport, or from the smaller Hawaiian airports to LAX/SFO/etc, + routes to Pacific islands, places like Tahiti or American Samoa being well in range. The CSeries 100 has a real-world range of 3000+ miles (3100 nautical miles nominal range) and the 300 even more, which is enough to go as far as Salt Lake City, although it could take an elevation penalty there. The aircraft would also need ETOPS certification but I'm sure there wouldn't be a problem at all there. Maybe Hawaiian could get a sweet deal selling their 717s to Delta. |
Quoting Paolo92 (Reply 6): It would surprise me if Bombardier's sales team had not approached HA yet. Indeed, the CS100/300 would be a great replacement for their 717 fleet. |
Quoting GE9X (Reply 1): I think I asked this in a previous thead and admittedly I have very little knowledge of Hawaiian Airlines and so the suggestion may be crazy, but how old are their 717s? I realize fuel burn savings are not that important on interisland short haul, but the CSeries could replace them *and* add the tremendous flexibility to have long and thin TPAC routes to smaller West Coast airport, or from the smaller Hawaiian airports to LAX/SFO/etc, + routes to Pacific islands, places like Tahiti or American Samoa being well in range. |
Quoting skyhawkmatthew (Reply 7): As we know Airbus is having a hard time with rotor bowing issues on the A320neo, so it remains to be seen whether the Cseries will be well suited to inter-island operations. |
Quoting Amiga500 (Reply 12): Quoting skyhawkmatthew (Reply 7): As we know Airbus is having a hard time with rotor bowing issues on the A320neo, so it remains to be seen whether the Cseries will be well suited to inter-island operations. I gather that is due to the mounting arrangement from engine to pylon. |
Quoting INFINITI329 (Reply 11): LX is the guinea pig for the LH group. If the CSeries is a knockout (or at minimum meets expectations) LH will come asking for a tad bit more CSeries aripanes. An order approaching 100 airplanes split among the group I estimate. |
Quoting skyhawkmatthew (Reply 7): |
Quoting MIflyer12 (Reply 8): HA is going to have A321NEOs for that. HA also needs to be concerned with how much it fragments its network (US-48 routes from OGG or KOA vs. |
Quoting Amiga500 (Reply 12): I gather that is due to the mounting arrangement from engine to pylon. The CSeries uses quite a different arrangement, thus should not have that problem. |
Quoting lightsaber (Reply 13): I suspect it is also due to the industry leading differential RPM/bearing velocity of the PW1100. There are reasons the PW1100 is more efficient than the smaller siblings, but that requires a different bearing/ shaft interface. While the mounting interface plays a role, I personally believe there are other design factors. |
Quoting lightsaber (Reply 13): I speculate sticking with proven bearing designs is why the LEAP went with co-operation as the benefit of today's higher Mach# compressors and in particular turbines is more than contra-rotation's 2 to 3 percent benefit in fuel burn reduction. Higher Mach# ( which requires higher RPM and thus a more stressed bearing) is good for 3% in the compressor and 4%+ in the turbine. With CNCs, it can be a 6% benefit. Or... The less turbine cooling required, the greater the aerodynamic benefit of high Mach# gas flow through a Turbine. In a compressor, the higher the Mach#, the greater the benefit of scimitar blades too. |
Quoting rbavfan (Reply 17): That would mean an increase in airframes to cover the current operations. A huge cost increase. |
Quoting rbavfan (Reply 17): No its due to uneven cooling of the shaft. It stays hotter on top causing it to bend & rub till it cools down. If it cannot be fixed it would mean hawaiian would have to have aircraft sit to cool. That would mean an increase in airframes to cover the current operations. A huge cost increase. |
Quoting Paolo92 (Reply 6): It would surprise me if Bombardier's sales team had not approached HA yet. Indeed, the CS100/300 would be a great replacement for their 717 fleet. In terms of ETOPS, both CSeries variant will be ETOPS120 at EIS, while ETOPS180 will come approximately 1 year after EIS (old PR), although, with the delays the program incurred into, I could see ETOPS 180 coming much earlier than that. This chart shows the CS100/300 range (3100nm + 3300nm) from HNL with shaded areas showing the ETOPS 120 area (light gray) and 180 (dark grey). Once ETOPS 180 is certified, that would slam open the door for HA's potential order. |
Quoting Amiga500 (Reply 18): I had thought P&W were running a faster shaft than CFM? I guess this is not the case? |
Quoting skyhawkmatthew (Reply 5): I think eventually we may see an order for the QF group. Whether that ends up being QantasLink themselves, Network or Cobham, who knows – but those F100s (and eventually the 717s) will need replacing soon enough, and Qlink is already a fairly major BBD customer on the turboprop side. The downturn in the mining industry will probably slow down any near-term plans though, I suspect. |
Quoting deltadawg (Thread starter): as long as Iran puts their new money into infrastructure instead of terrorism |
Quoting GE9X (Reply 1): may ease up, Canada's relationship with Iran is no better than America's. |
Quoting solarflyer22 (Reply 31): Oh the Georgia is strong in this Dawg. I have not seen any "terrorism" definitively linked to Iran in the past decade. I have seen ISIS killing people in Paris and Belgium. Resisting US/Saudi Arabian/Israel boneheaded foreign policy is also not terrorism. |
Quoting skyhawkmatthew (Reply 5): Whether that ends up being QantasLink themselves, Network or Cobham, who knows – but those F100s (and eventually the 717s) will need replacing soon enough, |
Quoting r2rho (Reply 23): Surely, some EU airlines will want to plug that gap |
Quoting wrongwayup (Reply 21): -IAG (already discussed): I think it's a great fit for EI in particular. Lower volume, longer distance routes and a desire to up frequency while offering a mainline product and remaining reasonably competitive against LCCs. Similarly applies to BA and to a lesser extent IB. |
Quoting wrongwayup (Reply 21): Africa (KE, ET, others?): Mainline product, long routes, lower volume flights, good field performance and apparently the GTF does well in harsh environments. Not sure about the immediate fleet requirements at each carrier, but an aircraft with the characteristics of the C would be a good fit. |
Quoting YVRLTN (Reply 33): Add Arik to the list too. |
Quoting YVRLTN (Reply 33): Others not mentioned I think are candidates if you look at their fleets and routes are LATAM, Garuda, Westjet, Avianca & COPA. AR if they ever get themselves cash postive. |
Quoting r2rho (Reply 23): n Europe, the A320NEO will effectively be a 180 seat aircraft on legacies and 186 on LCCs (I shudder at the thought, but that is the state of things...). The A319NEO is unattractive in comparison, and will be a niche aircraft. That creates quite a huge gap between 100-seat RJ's and 180-seat A320NEOs, into which the CSeries fits nicely (and also to a lesser extent the E2). Surely, some EU airlines will want to plug that gap... |
Quoting Paolo92 (Reply 6): This chart shows the CS100/300 range (3100nm + 3300nm) from HNL |
Quoting LAX772LR (Reply 36): that can support a nonstop to Hawaii |
Quoting lightsaber (Reply 13): Add IAG to the speculation. |
Quoting AirbusCanada (Reply 40): Hitler reacts to Delta's Bombardier CSeries order . funny.. http://youtu.be/ul7KVapsJO4 |
Quoting GE9X (Reply 37): What the CSeries proposes to do is serve long and thin markets that *don't* currently support a nonstop, but could potentially do so with an economical 110-130 pax aircraft. Specially, places like Long Beach, Burbank, etc, that serve significant populations but where pax are forced to drive to LAX if they want to fly to Hawaii. It could also easily open up overdue markets like SLC, YVR, and ANC, where Hawaiian competitors are the only ones flying, although the A321 they're expecting could probably do that as well. |
Quoting wrongwayup (Reply 39): Not at the moment |
Quoting CANPILOT (Reply 34): Do you think Westjet will buy C Series after ordering the 737-7MAX? |
Quoting YVRLTN (Reply 44): Quoting CANPILOT (Reply 34): Do you think Westjet will buy C Series after ordering the 737-7MAX? I dont know if they will take the 7, I believe the order is totally flexible. All recent deliveries have been 800's and 700's are going back to the lessors (and onwards to WN). The 600's will stay. |
Quoting wrongwayup (Reply 21): -NZ: Long distances overwater and smaller markets would make the aircraft a good fit. Although now they're big into A320s for this kind of mission so the C would be a subfleet. Too bad for BBD they didn't keep the Classics in service longer... |
Quoting L0VE2FLY (Reply 28): The CSeries would be perfect for QF Group / NZ to start thin Trans-Tasman flights like CBR-AKL/WLG/CHC, HLZ-SYD/MEL, etc... |
Quoting Boeing778X (Reply 46): Regarding the 40x CS300 Republic order, we all know that's not going to happen. How easy would it be for AA to acquire that order? |
