kotoka
DL Inaugural RDU-CDG
Fri May 13, 2016 2:12 am
DL's inaugural RDU-CDG flight departed this afternoon. The flight is on a 757 and is daily year-round. With the addition of CDG, DL has direct connections to all its US hubs from RDU (except SEA) and CDG as well. Not to mention a large P2P network. It will be interesting to see how much further DL grows at RDU.
Article and short video of inaugural:
http://www.newsobserver.com/news/business/article77332437.html
[Edited 2016-05-12 19:15:12]
[Edited 2016-05-12 19:32:58]
LAX772LR
RE: DL Inaugural RDU-CDG
Fri May 13, 2016 2:25 am
Quoting kotoka (Thread starter):
DL has direct connections to all its US hubs (except SEA) and CDG as well.
Huh?
DL032 is SEA-CDG nonstop.
I'm guessing you meant LAX?
[Edited 2016-05-12 19:28:10]
alasizon
Fri May 13, 2016 2:28 am
Quoting LAX772LR (Reply 1):
I believe he meant that RDU has links to everywhere but SEA on DL.
kotoka
Fri May 13, 2016 2:37 am
Quoting Alasizon (Reply 2):
Yes, that's exactly what I meant
lesfalls
Fri May 13, 2016 3:20 am
When you mean by P2P do you mean french dispora in RDU(which I could never imagine   ) or just people going from RDU for sightseeing in Paris?
CIDFlyer
Fri May 13, 2016 3:22 am
Quoting lesfalls (Reply 4):
he means point to point flights on Delta to cities that arent Delta hubs. off the top of my head DL also flies to cities like IND, CMH, CLE, TPA, FLL, MCO etc etc from RDU
DL does have a nice little operation going on at RDU for sure.
[Edited 2016-05-12 20:23:48]
sv11
Fri May 13, 2016 3:27 am
Is this the current longest 757 flight? Seems longer than United's EWR-Berlin. Another route that only a 757 can make, apart from the widebodies.
sv11
MSJYOP28Apilot
Fri May 13, 2016 3:45 am
Quoting sv11 (Reply 6):
Other carriers need to fairly frequently fuel stop 757s on shorter routes than CDG-RDU westbound in the winter months. I wonder if DL may reduce service in the winter to certain days of the week or suspend service entirely during the worst of winter headwinds. It may also just be a route where DL will just take the frequent fuel stops in the winter. If the loads are light and/or there are not many onward connections in RDU, fuel stops do not matter as much as they do to flights going to a hub airport where many passengers miss connections due to the fuel stops.
ROCDLFAN
Fri May 13, 2016 3:58 am
Quoting MSJYOP28Apilot (Reply 7):
From what I understand it's purely summer seasonal, so winter OPS shouldn't be a concern.
"The strength of the turbulence is directly proportional to the temperature of your coffee."
Aesma
Fri May 13, 2016 4:15 am
For French people Raleigh is a brand of bikes.
LAX772LR
Fri May 13, 2016 5:23 am
It's 63nm longer than EWR-TXL
Transpac787
Fri May 13, 2016 5:38 am
If you're referring to UA, keep in mind that all DL 752's are PW-powered, where UA oceanic 752's are RR-powered. The PW motors have better long range payload lift and fuel efficiency. Not by a significant amount, but it is definitely noticeable.
http://www.boeing.com/assets/pdf/commercial/airports/acaps/757_23.pdf
Pages 34 and 35 for the payload/range curves of the respective RR and PW models. Take, for instance, a 180.0 OEW+payload, and you get the following [rough] range figures:
RR (535E4B): 3450nm
PW (2040): 3600nm
So for those rather long 752 flights like RDU-CDG, the PW motors on the DL fleet do have a marked performance advantage.
LAX772LR
Fri May 13, 2016 5:54 am
It's not just the engines. IINM, the PW 752s have different piping/tankage, and can hold (slightly) more fuel as well.
panamair
Fri May 13, 2016 7:23 am
Quoting ROCDLFAN (Reply 8):
As of now, it's planned as a year-round service (e.g., it's bookable even in Jan and Feb or 2017).
Quoting CIDFlyer (Reply 5):
Yes, other non-hub cities served nonstop from RDU include PHL, BOS, BWI, and soon, DCA. In total, DL has about 70 flights daily out of RDU.. But this flight isn't about connections on the RDU end, it's geared towards the Research-Triangle area traffic to/from Europe/Middle East/Africa/India....
MIflyer12
Fri May 13, 2016 11:39 am
If by 'other carriers' you meant United, then yes, United had a problem year after year with Labrador (or Bangor?) fuel stops. Let's see if DL (by virtue of PW capability or better booking discipline) achieves better results. IMHO it's 757 RDU-CDG or nothing on DL. The market isn't deep enough to support anything like daily year-round on a 767.
DolphinAir747
Fri May 13, 2016 12:19 pm
TXL-EWR, once a serial diverter, is now a 767.
airbazar
Fri May 13, 2016 12:41 pm
Quoting MIflyer12 (Reply 14):
With fuel as cheap as it is, this route should be able to support 767 service. Maybe not daily in the off season but at least 5x per week. Look at DL's load factor on BOS-LHR, it's consistently in the 50-60% range in the off season and the flight keeps operating, presumably because there is enough demand up front. RDU should have a similar profile of passengers. With a huge hub in CDG, wouldn't surprise me one bit to see this route go to 767 if range becomes an issue with the 757.
kotoka
Fri May 13, 2016 12:47 pm
As someone said, this is year-round service. CDG traffic patterns from RDU are a lot different than what they were back in the 80s when AA flew to ORY from its RDU hub. There is consistent year-round business travel from RDU to Europe and India. BLR in particular comes to mind. I think that's the reason this was launched as a year-round service and not summer seasonal.
spinkid
Fri May 13, 2016 1:41 pm
So, is it year round or seasonal?
There seems to be a conflict amongst the posters here.
deltadawg
Fri May 13, 2016 1:56 pm
If this route sticks around and is successful one would have to wonder what the plans are for the future considering that DL's recent fleet upgrades and the apparent future of the 757's? It may be that the 757's have 5-10 years of service in them for DL, especially since DL has their own tech ops in house but this route is exactly the kind of route that DL and other carriers are looking at for a true 757 replacement. The A321LR still cannot perform this kind of route with the same capacity if I recall correctly. I realize it may get close but still cannot match it though. Perhaps in the future a A322LR could match and exceed the 757's capabilites?
GO Dawgs, Sic' em, woof woof woof
airbazar
Fri May 13, 2016 1:59 pm
Quoting kotoka (Reply 17):
I have friends and co-workers who do this trip to BLR often. Currently it's a 2 connection trip because the LHR flight does not offer a same day connection Westbound. They are thrilled that they can now do this route with a single connection, and based on the timings it's as perfect a connection as you can hope for. I guarantee you that DL looked at the amount of connections they were getting to India from BLR when they decided to introduce this flight.
AVLAirlineFreq
Fri May 13, 2016 2:00 pm
Quoting spinkid (Reply 18):
Year-round
OA412
Fri May 13, 2016 2:13 pm
There's no AMS link either.
Hughes Airwest - Top Banana In The West
Thenoflyzone
Fri May 13, 2016 2:14 pm
No,
DL's JFK-PSA is longer by 69 nm. 9h 39 min gate to gate, westbound.
ATL-BSB was even longer distance wise (not time wise), but is no longer served.
[Edited 2016-05-13 07:29:21]
us Air Traffic Controllers have a good record, we haven't left one up there yet !!
b727fa
Fri May 13, 2016 2:17 pm
Quoting deltadawg (Reply 19):
Yeah, in this case "close" requires some swimming. LOL
My comments/opinions are my own and are not to be construed as the opinion(s) of my employer.
Lexy
Fri May 13, 2016 2:57 pm
This is what high prescription drug prices are paying for.
Nashville, Tennessee KBNA
tlecam
Fri May 13, 2016 3:18 pm
Great news for RDU. RDU is similar to BOS for DL in a lot of ways. Not a full fledged hub, but service beyond flights just to DL hubs. As AirBazaar mentioned, these international flights from BOS have done pretty well - LHR-BOS doesn't have great load factors, but routinely sells out most of the front of the plane.
For CDG, AirFrance has served the route for many years. Several years ago, DL started an additional 757 summer service. That was upgauged to 763 and then last year, it was a mix of 763/764 and A333. I can see a similar trajectory for RDU. I also wouldn't be surprised to see AMS service launched at some point.
BOS-LGA-JFK | A:319/20/21, 332/3, 346 || B:717, 735, 737, 738, 739, 752, 753, 762, 763, 764, 787, 772, 744 || MD80, MD90
incitatus
Fri May 13, 2016 3:23 pm
Quoting Lexy (Reply 25):
That is funny. Drug companies use marketing and pricing tricks that would make airlines blush.
I do not consume Murdoch products including the Wall Street Journal
EMB170
Fri May 13, 2016 4:31 pm
How are the aircraft for RDU-CDG being routed? I know last summer, DL was operating the following pattern for the PA-Europe flights ex JFK:
JFK-PIT-CDG-PHL-LHR-PHL-CDG-PIT-JFK
Will DL do something similar, such as JFK-RDU-CDG-RDU-JFK?
IND ORD ATL MCO PIT EWR BUF CVG DEN RNO JFK DTW BOS BDL BWI IAD RDU CLT MYR CHS TPA CID MSP STL MSY DFW IAH AUS SLC LAS
winGl3t
Fri May 13, 2016 4:43 pm
Quoting EMB170 (Reply 28):
Considering this schedule planes should rotate among themselves:
CDG 11:15 RDU 14:45
RDU 17:58 CDG 08:10
CDG 13:35 PHL 16:11
PHL 18:43 CDG 08:35
CDG 16:10 PIT 18:56
PIT 21:30 CDG 11:20
Plane 1: PIT-CDG-PHL-CDG-RDU-CDG-PIT...
Plane 2: PHL-CDG-RDU-CDG-PIT-CDG-PHL...
Plane 3: RDU-CDG-PIT-CDG-PHL-CDG-RDU...
Sightseer
Fri May 13, 2016 4:59 pm
Quoting winGl3t (Reply 29):
They would still need a flight to another hub to rotate through the rest of the system somehow.
airbazar
Fri May 13, 2016 5:06 pm
This topic has been discussed repeatedly. Assuming that we're talking about missions at the edge of the envelope, the A321LR and B752 will be incredibly similar with the LR actually having LONGER range than the B752. Where the A321LR loses to the 752 is field performance and of course cargo volume. But there aren't any airports in Europe where altitude and runway length are an issue save for maybe MAD, and I guarantee you that the 752's aren't carrying much cargo either if they're having to make refueling stops at this length.
This thread has a lot of interesting comments on it:
757 Vs A321LR (by DocLightning Mar 12 2015 in Tech Ops)
ERJ170
Fri May 13, 2016 5:10 pm
The routing is ATL-PIT-CDG-RDU-CDG-PIT-ATL
Aiming High and going far..
Thenoflyzone
Fri May 13, 2016 5:44 pm
Quoting airbazar (Reply 31):
What's wrong with MAD? 2000 ft altitude, shortest runway is 11,482 ft, longest 14,268 ft. Seems very much doable to me, even at 30C.
YULWinterSkies
Fri May 13, 2016 6:59 pm
Which are airports with non-stops to CDG, in general.
This remains to be seen how large the point to point with CDG is.
Quoting panamair (Reply 13):
Among them, PHL and BOS have non-stop CDG service and the other two involve significant backtracking.
RDU is an o&d on this route, essentially. Most pax will probably be connecting to the rest of the Eastern hemisphere in CDG.
When I doubt... go running!
PITrules
Fri May 13, 2016 7:02 pm
I know its anecdotal, but by looking at the fares and (full) seating charts in the days ahead, seams like DL is already killing it on the route. Especially up front where there are only three oversold tickets left to be sold until Tuesday.
FLYi
tlecam
Fri May 13, 2016 7:05 pm
Quoting YULWinterSkies (Reply 34):
Off the top of my head for Delta. (Edit to note that some are seasonal on Delta metal)
JFK
DTW
MSP
SLC
SEA
ATL
BOS
PIT
PHL
RDU
CVG
LAX is served entirely by AirFrance as far as I know - 3 flights a day. Not sure if DL adds a 4th summer seasonal.
[Edited 2016-05-13 12:08:17]
panamair
Fri May 13, 2016 7:20 pm
Quoting tlecam (Reply 36):
JFK
DTW
MSP
SLC
SEA
ATL
BOS
PIT
PHL
RDU
CVG
You missed EWR....So far, only PHL and PIT are seasonal. No DL metal on LAX...
airbazar
Fri May 13, 2016 7:22 pm
Quoting thenoflyzone (Reply 33):
I don't know, hence why I said maybe. Although 2000ft alt at 30+C can be rough on twins and as I understand it, it's one reason why IB was so slow to adopt the A330.
LAX772LR
Fri May 13, 2016 7:29 pm
A321LR will actually have longer range, but not at the same payload.
Then again, we don't know what DL's payload goals are on this, so tough to say if an A321LR would be able to do it.
They don't.
I'm sorta shocked that they aren't on LAX-AMS, a rather static route, either... figured for sure they'd join KL on that by now.
BravoOne
Fri May 13, 2016 7:35 pm
Quoting LAX772LR (Reply 12):
Where did you come up with that factoid? If in fact it's true, which I doubt, it would be meaningless in the scope pf things.
deltadawg
Fri May 13, 2016 8:03 pm
That is funny. Drug companies use marketing and pricing tricks that would make airlines blush. [/quote]
I believe he is making a point about the large numbers of pharmaceutical companies in the Raleigh area. If I recall correctly the Research Triangle is second only to the Boston area in terms of pharmaceutical and life sciences companies.
The fact that many of these companies are either based in Europe or have sister plants in Europe is no mistake as this new RDU-CDG route will make connecting to home offices and sister plants far easier and more palatable.
sparkingwave
Fri May 13, 2016 8:10 pm
Didn't AA start RDU-ORY when they had their hub in Raleigh (80s/90s)? I believe they used a 767. What were the circumstances around that route compared to the new DL flight now?
Flights to the moon and all major space stations. At Pan Am, the sky is no longer the limit!
factsonly
Quoting LAX772LR (Reply 39):
Understand your point, but the route is not static - it has grown every year in the past 3 years.
DL/KL has expanded in all stations in California and Utah in recent years, with LAX now 14x/week (KL) and SFO 9x/week (KL), and SLC 10x/week (DL/KL).
It is only in S16 that KLM - for the first time - reached the full 14x/week LAX-AMS, that is 2x daily in July-August only.
If DL continues to expand its LAX presence, S17 could see DL on LAX-AMS for the first time in peak season. But don't count on it, as KLM may have to reach 2x daily for a full summer season first.
In addition the two airlines tend to have routes to themselves, ATL-AMS is the only duopoly, though SLC-AMS is for this summer as well.
panamair
Fri May 13, 2016 8:18 pm
Quoting factsonly (Reply 43):
JFK-AMS as well (2x DL and 2x KL this summer)
Sightseer
Side note, they both also serve JFK.
AVLAirlineFreq
Fri May 13, 2016 10:39 pm
Quoting sparkingwave (Reply 42):
The two biggest are that RDU was an AA hub then, and the very strong population and business growth in the Triangle over the last 20 years.
MSPNWA
Fri May 13, 2016 11:24 pm
Good for RDU! But man, that's a long time on a 757. I'll take a connection, please.
LAX772LR
Sat May 14, 2016 2:39 am
Quoting BravoOne (Reply 40):
DL and sUA birds are at 43,490L
sCo birds at 42,680L
When did they go full 2xD??? Totally missed that, but happy to see.
What's the eqp?
factsonly
Sat May 14, 2016 5:55 am
Quoting LAX772LR (Reply 48):
What's the eqp?
Turns out the full 2x daily period is much longer 4 July - 28 Oct 2016:
- dep. 1:45pm LAX - arr. 09:05am AMS KL602 B74M Daily ex.FR SU
- dep. 1:45pm LAX - arr. 09:05am AMS KL602 B744 FR & SU
- dep. 4:55pm LAX - arr. 12:10pm AMS KL604 B74M Daily
