klm617 wrote:With today's technology why is CVR and FDR information still stored on airplanes this data should be broadcast back to a ground based computer system
rfields5421 wrote:Another thread quoted prices for real-time high-speed internet for private jets across the North Atlantic - $20,000 per flight or more.
Automated data backup could easily equal that costs.
Then the amount of data to be backed up - FlightAware currently shows over 2,800 commercial flights in the air over the US. That's a need for hundreds of terabytes of data storage per hour.
rfields5421 wrote:Not saying you are not correct but your math does not hold.Modern FDR's record over 2048 words per second in 8 bit format. Each hour of FDR data is over 1 GB in size.
o0OOO0oChris wrote:According to AVHerald, the ACARS-sequence was:
00:26Z 3044 ANTI ICE R WINDOW
00:26Z 561200 R SLIDING WINDOW SENSOR
00:26Z 2600 SMOKE LAVATORY SMOKE
00:27Z 2600 AVIONICS SMOKE
00:28Z 561100 R FIXED WINDOW SENSOR
00:29Z 2200 AUTO FLT FCU 2 FAULT
00:29Z 2700 F/CTL SEC 3 FAULT
rfields5421 wrote:A 32GB CVR records only 120 minutes of voice from four input sources
rfields5421 wrote:Each hour of FDR data is over 1 GB in size.
rfields5421 wrote:The AF 447 investigation reports are especially disturbing in that they reveal Air France maintenance reported to AF ops very soon after the last data transmissions that the aircraft might be in danger. Yet it was over seven hours before an ATC official cut across the red tape and issued an alert for a missing aircraft.
planewasted wrote:o0OOO0oChris wrote:According to AVHerald, the ACARS-sequence was:
For me that sequence looks like a fire that started when the right window anti ice overheated.
Anti ice overheats, starting a fire, after a while it fails completely, giving the first message
Then fire takes out the window sensor
Then the fire continues to spread
But what speaks against it is: How could something flammable be in or close to the window?
rfields5421 wrote:Transmitting basic course, speed, altitude, position data is already a part of the ACARS system. Flight24 and FlightAware might not be in business without that data transmission being a standard.
sovietjet wrote:Like I've said before, you don't need to transmit ALL the CVR/FDR data via satellite. Off the top of my head, the most important data you need is location, speed, altitude. If you have this, finding the wreckage will be much easier.
spacecadet wrote:And like I've said before, I'm not sure why you or anyone thinks an airplane will continue transmitting this after it's lost the electrical power that allows it to already transmit its position, speed and altitude via ADS-B to ATC. What *exactly* are you asking for that's not already being done?
spacecadet wrote:And was this airplane not found using this exact data set?
The crash site of EgyptAir Flight 804 deep in the eastern Mediterranean has given up all its secrets. Investigators into the crash now have a complete and detailed map of the field of debris. The Daily Beast can reveal that the specialized deepsea search vessel John Lethbridge has completed its mission and left the area after completing the mapping.
Although Egyptian officials have yet to announce what has been disclosed by data downloaded from the flight recorders of the Airbus A320, the picture of the debris field is equally important to understanding what happened. Small details can provide big clues—in this case the role that control surfaces played when pilots lost control of the flight.
spacecadet wrote:sovietjet wrote:Like I've said before, you don't need to transmit ALL the CVR/FDR data via satellite. Off the top of my head, the most important data you need is location, speed, altitude. If you have this, finding the wreckage will be much easier.
First priority of the search after the retrieval of the flight recorders was to use the ROV to get close-up images of the forward section of the A320’s fuselage, including the flight deck. This quickly established that there was evidence of heat damage, possibly from a fire
klm617 wrote:Is it possible that the chain of events happened slower than we are expected to believe because the flight crew was doing something there were not suppose to be doing in the cockpit or had something up front that was not allowed and as the emergency unfolded they were trying to defuse it without calling a mayday to cover up what it was that caused the fire to break out in the cockpit.
EgyptAir Flight 804 Broke Up in Midair After a Fire, Evidence Suggests
CAIRO — Evidence gathered in an investigation into the crash of EgyptAir Flight 804 in the Mediterranean Sea in May indicates that the plane most likely broke up in midair after a fire near or inside the cockpit that quickly overwhelmed the crew, according to Egyptian officials involved in the inquiry.
But the officials could not determine whether the fire thought to have caused the crash had been set off by a mechanical malfunction or by a malicious act....
spacecadet wrote:PeterB wrote:Maybe I missed something in your argumentation. You rule out terrorism because they tried to extinguish a fire ? This doesn't make any sense! Unless it is not clear what the source of the fire was you cannot rule out anything! The source of the fire could have been a bomb as well.
It technically could be, but think about what a stretch of logic that is at this point. Setting an on-board fire through the use of some sort of incendiary device is not a tactic any terrorist organization has used before. And the reasons are obvious - it's not that they haven't thought of it (if you or I have, they have). It would be a really unreliable way of downing a plane, for one thing - pilots and even planes themselves have equipment to fight fires, and lots of planes have landed safely with a fire on board. Others have not, but is that a chance a terrorist is going to take?
rcair1 wrote:As far as reliability. I don't think they care that much. If it doesn't work - so what. If it does - then they win.
JAAlbert wrote:I hope he didn't have a Samsung 7!
asdf wrote:hmmm
arent those electronic devices usually known for flaming up
- during loading or
- in case of bent or crushing
neither of these seems probable near the cockpit side window, does it?
asdf wrote:hmmm
- during loading or
stasisLAX wrote:Per United Press, the co-pilot was carrying an iPad and an iPhone, along with several bottles of perfume in his carry-on bag. French investigators have, according to the French press, singled out these items as potential ignition sources of an inflight fire in the cockpit.
Source: http://www.upi.com/Top_News/World-News/ ... 1484325737
Dreamflight767 wrote:I thought it was determined that this crash was a result of a bomb.
