RAGAZZO777
Avianca Launches Cuzco-Bogotá
Fri May 20, 2016 7:59 pm
From 18 July Avianca (TACA Perú) will fly Cuzco-Bogotá-Cuzco three times per week on an Airbus A319.
AV 144 CUZ 16:01 19:44 BOG Mon, Wed, Fri
AV 145 BOG 07:44 10:52 CUZ Mon, Wed, Fri
Source: avianca.com
JESÚS, TE AMO !!
pipeafcr
RE: Avianca Launches Cuzco-Bogotá
Fri May 20, 2016 9:32 pm
Second international destination for CUZ, congrats to both destinations and AV! From the schedule we can see that it'll connect best with flights to/from LHR, PTY, MIA, JFK and MEX.
Felipe Carrillo
winGl3t
Fri May 20, 2016 9:37 pm
Cool!! It was about time for huge leisure destination like CUZ to get connected to a major hub like BOG. I'm sure they will succeed.
I would really like to see a GRU-CUZ flight 3 times per week as well
[Edited 2016-05-20 15:13:58]
RCS763AV
Sat May 21, 2016 12:22 am
This is so cool! And definitely out-of-the box thinking by AV! Well done!
I wish this route all success! Can't believe they jumped the gun on CM with this one!
2travel2know2
Sat May 21, 2016 1:04 am
Quoting RCS763AV (Reply 3):
CM doesn't have any equipment suitable to operate at CUZ and LPB altitudes.
I'm not on CM's payroll.
SJOtoLIR
Sat May 21, 2016 3:17 am
Quoting winGl3t (Reply 2):
It makes a resemblance to AV BOG-LPB, taking into account the unusual elevation at either LPB or CUZ.
The 319 seems to be suitable for this purpose.
Regards.
"Goin' up to the spirit in the sky"
LAX772LR
Sat May 21, 2016 4:41 am
Quoting 2travel2know2 (Reply 4):
CM still has 73Gs, at least for now. They could do it more or less equivalently to the A319 being used here.
2travel2know2
Sun May 22, 2016 3:35 pm
Quoting LAX772LR (Reply 6):
Yes, CM still has B737-700 but none of CM aircraft has the kit to operate at CUZ or LPB.
As there are ETOPS modifications there also are high-altitude operations modifications offered by the aircraft manufacturers.
SJOtoLIR
Sun May 22, 2016 11:01 pm
Quoting 2travel2know2 (Reply 7):
One more point: PTY-CUZ and PTY-LPB are farther than BOG-CUZ and BOG-LPB, respectively.
Thus, more load penalties apply in those planes heading to PTY.
Regards.
[Edited 2016-05-22 16:01:49]
RCS763AV
Tue May 24, 2016 2:02 am
Anyhow, this is a very cool route. IMHO, CUZ is one of the most underserved airports regarding international ops in the world. Think of the amount of pax that go through LIM just to get to the inca capital!
I wonder why the departure from BOG is so early. I guess it has to do with aircraft utilization. If it were do depart on the noon-2pm bank it would catch so many more connections. It also offers a seamless connection from LHR, in direct competition with BA's new LGW flight to LIM.
By the way, the new airport in Chinchero is going to have a higher elevation (3700M) compared to the current CUZ (3300m). Although the runway will be 600m longer (4000 vs 3440m), I still wonder how aircraft performance will be affected.
I'm saying this because currently, AA's 757s struggle to make it to MIA from LPB (which is just a tad further and higher than the new CUZ will be), and have to stop at VVI (also for commercial reasons). However, the airport's concessionaire and Proinversión have announced that this new airfield will be MIA-capable. (Wonder if AA's A319s will make it by then).
OB1504
Tue May 24, 2016 9:39 pm
Quoting RCS763AV (Reply 9):
Didn't AA briefly operate MIA-CUZ-LIM-MIA with a 757 also?
superjeff
Tue May 24, 2016 11:27 pm
Faucett used to operate MIA-CUZ using 707's years ago. So it has been done. PTY-CUZ should be well within the range of PTY, but I don't know how the altitude would affect 738's of CM. The distance can't be more than about a 4 hour flight time.
RCS763AV
Wed May 25, 2016 2:04 am
Quoting OB1504 (Reply 10):
They did, yes.
Quoting superjeff (Reply 11):
CM has 73Gs! How penalized can it leave CUZ if it can make it to SFO (almost twice as long a distance)...
Yet again, CM doesn't operate to LPB either, presumably for the same reason. What is this specification we're talking about that the 73Gs need in order to handle those high airports? DL's and UA's 73G's handle themselves pretty well from BOG to New York (1+ hour longer than the hypothetical flight). Even CM* flies MEX-BOG (4+ hour flight, so a slightly longer flight time) on one of those 73Gs, both high airports with limitations (2300 meters for MEX and 2600 for BOG).
Could it be that CM just doesn't see a commercial appeal for this route?
On another note, the 7:44 AM departure from BOG is not ideal for domestic connections. Only the main cities will be able to connect onto this flight. Yet again, the demand from secondary cities to Cusco direct has to me marginal at most.
Summa767
Wed May 25, 2016 8:39 am
Quoting RCS763AV (Reply 12):
It is very clear to me that the main connection to CUZ is going to be LHR. But JFK and MEX will provide significant feed to. Others will be GRU, GYE, UIO. Domestically it is only CLO and and MDE (both actually have not just one, but 2 flights that allow connection to CUZ). BGA, AXM, CUC, CTG and BAQ would make for very short tight connections,and are not offered,
Given that the loads on the LHR-BOG flight have bee non the poor side apart from the holiday travel seasons, connections to and from CUZ will be of much needed help.
a320fan
Wed May 25, 2016 11:40 am
Why 5 hours on the ground in CUZ?
EDIT: On second look it appears it's not a BOG originating flight, and the aircraft night stops in Bogota.
[Edited 2016-05-25 04:42:01]
A319, A320, A321, A330-200, A350-900, A380, 737-700, 737-800, 777-200ER, 777-300, 777-300ER, 787-8, Q300, Q400
DolphinAir747
Wed May 25, 2016 11:55 am
Very true, it seems whenever I meet a tourist headed to LIM they only plan on transfering to go to Machu Picchu
2travel2know2
Wed May 25, 2016 1:20 pm
The issue with CM not flying to CUZ or LPB isn't how much weight restricted the take-off would be but that none of CM aircraft has the very high altitude operation kit. CM just hasn't ordered any aircraft equipped with that.
Pretty sure they see it but CM isn't willing to have a sub-fleet of 1-2 CUZ and LPB capable B737.
Quoting a320fan (Reply 14):
AV planning a tag-on to AQP or LPB?
winGl3t
Wed May 25, 2016 1:44 pm
Quoting 2travel2know2 (Reply 16):
It is a BOG-CUZ-LIM-CUZ-BOG rotation:
"Avianca from mid-July 2016 is expanding operations at Cuzco, Peru, as TACA Peru plans to introduce new International route. From 18JUL16, the airline will offer 3 weekly Bogota – Cuzco service, on board Airbus A319 aircraft.
AV145 BOG0744 – 1052CUZ 319 135
AV144 CUZ1601 – 1914BOG 319 135
In addition, the airline’s Cuzco – Lima service will also see frequency increase from 35 to 38 weekly from the same date.
AV842 CUZ1150 – 1315LIM 319 135
AV843 LIM1400 – 1525CUZ 319 135"
http://www.routesonline.com/news/38/...on-from-july-2016/?highlight=CUZCO
SJOtoLIR
Thu May 26, 2016 12:38 am
CM PTY-SFO is served with 738 instead.
Same with almost all their "long-haul" segments: CM PTY-EZE, CM PTY-LAX, CM PTY-EZE, CM PTY-MVD, CM PTY-GRU, CM PTY-GIG, CM PTY-POA and so on.
Regards.
doug_or
Thu May 26, 2016 12:57 am
CUZ is 3,300 meters, that is significant on its own, but I believe it is also in a valley (meaning further restrictions for engine-out climb gradient). Beyond that many aircraft have a max landing elevation, max flap extension, or max gear extension altitude which may interfere with CUZ ops.
When in doubt, one B pump off
