TWA772LR
United And The Sharklet
Fri May 27, 2016 1:25 pm
United has a large fleet of A319s and A320s. With the Sharklet now being available for retrofit, and UA having just purchased additional A319s as well as doing cabin mods for the rest of the Airbus fleet, will they choose to have the fleet retrofitted with Sharklets?
When wasn't America great?
INFINITI329
RE: United And The Sharklet
Fri May 27, 2016 1:46 pm
The average age of UA A319s is 16 years and 17.7 years for the A320. I may not be worth it to UA to do the conversion. The sharklets on older Airbuses are not plug and play. They require a good bit of wing modification. I don't see it being worth the hassle for UA
jetmatt777
Fri May 27, 2016 1:56 pm
I'm sure they have ran the numbers, the things I can think of that work against it:
Fuel is cheaper and will remain cheaper for a few more years at least.
Age of the fleet is getting older, there are less years and thus less cycles left to spread the cost over.
The cost to install on older models is greater as there are more modification to undergo to the wing.
United is aggressively trying to add mainline capacity. The opportunity cost to park airplanes for a week or two at a time to undergo the modifications will mean less ability to upgrade markets to mainline.
If United had some recent builds I'm sure they would install them.
AA737-823
Fri May 27, 2016 4:15 pm
Jetmatt touched on the big reason, but allow me to amplify it:
The line numbers of United's old birds are too early for the sharklet mod to be sensible. While I'd like to see it done, it simply requires too much work to the wing and wingbox structure to have a decent ROI with oil at $40, $50, or $60.
I don't expect to see it happen to these birds, unless oil skyrockets unexpectedly.
A388
Fri May 27, 2016 4:35 pm
What about DL and AA and even B6 and NK? Will they retrofit their non-sharklet A320/319 fleet with sharklets? Does it make sense for them to do it or is it the same as UA's being too old for modifications?
A388
N757ST
Fri May 27, 2016 5:19 pm
B6 already has a couple modified.
diverted
Fri May 27, 2016 5:29 pm
Quoting A388 (Reply 4):
I think DL is in much the same boat as UA with the 320's. IIRC only frames >LN1200 are even eligible for the retrofit, and that's with significant wing work. It was only a few years ago that Airbus included the necessary structure to make the sharklets a true plug and play installation.
In DL's case, they only have something like 8 320's above LN1200
United1
Fri May 27, 2016 5:46 pm
Quoting diverted (Reply 6):
About a third of UAs Airbus fleet could get sharklets (later than ln 1200) with some wing rework but none of them are plug and play....39 A320 and 27 A319s.
Any of the "new" ex NK/CZ ones should be eligible as well.
I know the voices in my head aren't real but sometimes their ideas are just awesome!!!
A388
Fri May 27, 2016 8:06 pm
I can imagine since those are ex-NW aircraft of which a few are one of the early built models. Please correct me on this.
A388
a380787
Fri May 27, 2016 8:07 pm
Exactly how much SFC can be saved with the sharklets ? 4%? 7%?
diverted
Fri May 27, 2016 8:38 pm
Quoting A388 (Reply 8):
Oh yeah, some of them are amongst the oldest still flying. In North America, I'd imagine only AC has older ones. DL's oldest is cn 118, N309US. The majority of DL's 320s seem to be under cn 500. AC has 4 older frames, cn 59, 68, 73, 84
DL's 319 fleet is newer on the whole, oldest frame delivered 1999, and only 4 frames appear to be under the cn 1200 threshold. Then of course they have a handful of 321s which are brand new.
pasu129
Fri May 27, 2016 10:34 pm
AA's A320 inherited from PMUS, which means they have some of the oldest Airbii on States side. Of which most are not eligible for refit.
Viva Las Vegas
cageyjames
Fri May 27, 2016 10:37 pm
Quoting pasu129 (Reply 11):
How many of the ex PA/BN A320s are still left?
prebennorholm
Fri May 27, 2016 11:25 pm
Quoting a380787 (Reply 9):
Airbus claims "up to" 4%. That type of wording is the salesman's way of writing "less than 4%" in everyday ops.
That seems less than claims on other plane types. That is likely due to the old wingtip fences doing a rather good job.
It is not possible for Airbus to be more specific than that without delivering very detailed performance charts for every flight regime.
To be "perfect" at all times winglets would need to have variable toe-out angle depending on wing angle of attack, and also the slight twist of the winglets themselves should be variable. Such features are hardly technically possible, and if they are, they will add unrealistic weight and costs.
Winglets are therefore fixed and designed to optimal effect at most average flight regime (weight, altitude, center of gravity position, etc.). When diverting from that, effect goes down, and can in extreme cases be negative.
caljn
Sat May 28, 2016 3:09 am
They're "winglets". Let's not make up words for existing nouns.
jolau1701
Sat May 28, 2016 4:41 am
Quoting caljn (Reply 14):
Winglets go up, Sharklets go down. That's how I tell them apart (unless I'm wrong)
a380787
Sat May 28, 2016 6:22 am
Quoting jolau1701 (Reply 15):
I'm not following ... The A32x sharklets also look like they bend upwards ...
spahrtan
Sat May 28, 2016 7:51 am
Airbus calls them Sharklets, so unless you'd like to correct them, that is actually what they are called when they are installed on the A320 family of aircraft.
[Edited 2016-05-28 00:53:32]
s.p.a.s.
Sat May 28, 2016 1:15 pm
The technical name of it, despite Airbus marketing team effords, is winglet.
The name they choose to market it, does not change that fact.
"ad astra per aspera"
jetmatt777
Sat May 28, 2016 1:23 pm
Quoting s.p.a.s. (Reply 18):
Technical name or not, it's okay to refer to a product by a brand name. A good example that comes to mind is Kleenex. People say "Hand me a Kleenex" more often than "hand me a tissue". Neither is wrong unless you are only interested in splitting hairs.
N1120A
Sat May 28, 2016 4:10 pm
If United's purchases of used A319s include newer ones, I'd imagine sharklets will be on the table.
They both go up. You are thinking of the split scimitar on the 737.
Quoting jetmatt777 (Reply 19):
That is for a genericized trademark. The name winglet has been used for decades, including on Airbus planes.
DocLightning
Sat May 28, 2016 6:10 pm
Quoting N1120A (Reply 20):
If you want to be really pedantic, it is a non-planar wingtip device consisting of an upward wing-like element.
Airbus calls them "Sharklets."
In any event, most of UA's A320s are not in any way eligible for the modification. The few that are would require the wingtip to be sawed off, extensive strengthening applied, and then the new Sharklet to be attached. Given the age of these aircraft and given that UA has just made a huge narrowbody order, I can't imagine that they consider this to be worth 1) the aircraft downtime and 2) the cost of the modification.
[Edited 2016-05-28 11:16:09]
-Doc Lightning-
-Carl Sagan
IPFreely
So one arbitrary made-up name is correct and another arbitrary made-up name is wrong? That's rich.
caljn
Sat May 28, 2016 7:03 pm
Quoting IPFreely (Reply 22):
Ok then, from this day forward I shall refer to wings as flying surfboards...and flout conventional parlance.
prebennorholm
Sun May 29, 2016 1:31 am
Quoting DocLightning (Reply 21):
Not entirely correct. They call them "Sharklets (TM)", but only when they sit on an A320 family plane, not on A330 and A340.
Funny thing is that the web site, where Airbus explains their introduction of Sharklets, has the headline "Winglets": http://www.airbus.com/innovation/proven-concepts/in-design/winglets/
They are all winglets, never mind if they sit on a Boeing, Bombardier, Embraer, MDD, Mitsubishi, Tupolev or Airbus plane.
A Sharklet is a winglet, just like a Coca Cola is a soft drink and a Budweiser is a beer. Well, the latter has often been questioned.
DualQual
Sun May 29, 2016 1:34 am
Ah, what might have been. Another potential interesting thread derailed by "I'm the smartest guy in the room" pissing matches.
There's no known cure for stupid
intotheair
Sun May 29, 2016 1:58 am
Quoting DualQual (Reply 25):
At least (surprisingly!) it hasn't turned into a tulip vs. globe food fight like every other UA thread does!
300 319 320 321 332 333 345 346 380 717 733 734 735 73G 738 739 744 752 753 762 763 772 77W 788 789 CR2 CR7 CR9 CRK Q400 E175 DC10 MD82 MD90
AA AF AS AY AZ B6 BA BR DL F9 FI GA HA KF LH MI QX SK SN SQ UA US VY WN
DualQual
Sun May 29, 2016 2:12 am
Quoting intotheair (Reply 26):
Good point  I guess that's progress!
antoniemey
Sun May 29, 2016 3:04 am
Quoting AA737-823 (Reply 3):
In which case we have another round of flight and route cuts, the older birds get parked in favor of the new birds that they're committed to leasing or buying for efficiency, and the question becomes a moot point anyway.
And someone would then, a year or two later, come along and ask "Why did UA dump their Airbuses for old generation 737s?"
Is wingtip device.
Give it a couple more days.
Make something Idiot-proof, and the Universe will make a more inept idiot.
bomber996
Sun May 29, 2016 3:57 am
Quoting prebennorholm (Reply 24):
Excuse me. It is now called America.    And it is still a crappy beer.
Peace (box)
"We've recently upped our standards, so up yours." - Federal Aviation Administration
DocLightning
Sun May 29, 2016 6:00 am
Correct. The Sharklets are the trade name only for the A320 family winglets. On the A330/A340 they call them winglets. I haven't seen a name for the weird raked wingtip/winglet hybrid on the A350 and A330NEO.
-Doc Lightning-
-Carl Sagan
B6JFKH81
Sun May 29, 2016 4:13 pm
A lot of back and forth about the term "Sharklet" vs. "Winglet". I get it, no need to reinvent the wheel on the name of a wingtip device that is similar to others out there. But, that is what Airbus has done.
When we see a commercial for a new medication, it has a name that is easy and catchy. But then you also see the technical name that is about 40 letters long and 15 syllables. The technical data will refer to the technical name. The same goes with aircraft parts. In this case:
As per Airbus IPC (A320/321) 57-31-23-01A & -02A, the technical nomenclature of the wingtip device assembly is a Sharklet. Part number D5735672000400 or 600 or 601 for the L/H, Part number D5735672000500 or 700 or 701 for the R/H.
As per the EASA FORM1, Airbus Serviceability Tag, FOLIOs/Constituent Assembly Inspection Reports, the documents used to certify them as airworthy and receive these items into airline inventory and deem them acceptable for use on my aircraft (I received 3 sets a week ago while in LCQ), all list the technical nomenclature as Sharklet, not once is the term Winglet used.
So on the technical side of the house, I have no option but to use the term Sharklet as that is the term used by the aircraft manufacturer, it's manuals, and it's airworthiness certificates and is therefore also the terminology and technical nomenclature used in our M&E system.
We may not like it, especially since the Sharklet design got watered down to its current design which looks much like what we have seen on other aircraft over the years, but that is the technical name we have.
~JKS
IPFreely
Sun May 29, 2016 6:33 pm
Kind of. Those who post links to various websites in a futile attempt to prove how smart they think they are only end up proving their foolishness and stupidity.
