TC957
LH And Their 2 A320NEO's
Thu Jun 09, 2016 2:57 pm
Just spent a few days at FRA and the 2 LH A320NEO's were in & out, so I'm wondering how LH being the first operator of them are getting on with them.
Are the promised fuel burn reductions being met ? Any unforseen / unplanned Operational issues ?
When will LH take their next NEO's ?
Thanks for any updates.
TheSonntag
RE: LH And Their 2 A320NEO's
Thu Jun 09, 2016 3:11 pm
Quoting TC957 (Thread starter):
If you look at the flight rates of D-AINA and D-AINB, the rates were low in the beginning, only 4 flights a day. This has changed, they now fly more, 8-9 flights a day.
Public comments on issues were rather quiet, but it seems they actually like the plane and that it seems to deliver on fuel burn spec.
So, it seems it is doing ok. There were some issues, but the fuel burn is fine.
FRAEDDF
Thu Jun 09, 2016 3:31 pm
Two more this summer and one later in the year.
Quoting TheSonntag (Reply 1):
Right, I noticed this too. Reliability seems to be pretty good. Still only flying intra-German routes from FRA, though (HAM/MUC/TXL/DUS).
seahawk
Thu Jun 09, 2016 3:34 pm
99%+ reliability, Fuel Burn per Seat Mile -20%, start up time 350 seconds
PanHAM
Thu Jun 09, 2016 3:40 pm
Having LH Technik smoothening the path is by far better than screaming.....
Was Erlauben Erdogan!!!
flyby519
Thu Jun 09, 2016 3:46 pm
Quoting seahawk (Reply 3):
What do you mean by this? 350 seconds for the motor startup? That's a looooong time, does it include a required warmup period before T/O thrust?
chiad
Thu Jun 09, 2016 4:56 pm
Quoting flyby519 (Reply 5):
So that's what the whole hubbub is all about? 6 minutes?
Is it so har dot incorporate startup while boarding?
N1120A
Thu Jun 09, 2016 5:19 pm
Quoting chiad (Reply 6):
With ground workers there?
KarelXWB
Thu Jun 09, 2016 5:23 pm
Lufthansa CEO also mentioned that fuel burn is better than promised.
Luftymatt
Thu Jun 09, 2016 6:24 pm
Quoting PanHAM (Reply 4):
Very true.... It doesn't get you much attention in the press though.
chase the sun
Navion
Thu Jun 09, 2016 7:31 pm
The only real issue with the engines has been the extended start up time. It is a fully certified engine which is meeting or exceeding all of it's promises but the start-up time is a problem. I hadn't read it was almost 6 minutes, I had read it was about 3 minutes although if the two engines are being started up in sequence then that would take almost 6 minutes.
Pratt has started shipping the "new" engines with refined hardware and software to airbus which should alleviate some of the problem.
tigerotor77w
Thu Jun 09, 2016 8:58 pm
Quoting FRAEDDF (Reply 2):
In late February and late March, this was not the case. I flew on D-AIUQ twice -- both unplanned -- one time from BCN - MUC and one time from OSL - MUC.
Plane was nice. Couldn't tell if it was quieter than other A320s (they're not particularly noisy to begin with in flight). Interior didn't seem a whole lot different from new-build A320s or A330s.
Someone83
Thu Jun 09, 2016 9:05 pm
Quoting tigerotor77w (Reply 11):
D-AIUQ is not a NEO, but a CEO version
bgm
Thu Jun 09, 2016 9:28 pm
That's probably because it was exactly the same as the other A320s...
You probably got confused because it had sharklets. LH has a number of A320ceos with sharklets.
D-AINA/B are the NEO variants.
████ ███ █ ███████ ██ █ █████ ██ ████ [redacted]
FRAEDDF
Registrations for the two NEO´s currently in service for LH are D-AINA and D-AINB.
Quoting Someone83 (Reply 12):
alyusuph
Fri Jun 10, 2016 3:04 am
So the fuel burn has improved which is good. Does LH also rant about the hydraulics, or that is just something affecting NEOs operations in hot climate.
I am not an Airbus or Boeing fan, just an aircraft fan
hongkongflyer
Fri Jun 10, 2016 3:07 am
6 mins startup time per flight * 8 flights per day means you will likely lost one rotation for intra-Europe flight.....
Not good for utilization
lightsaber
Fri Jun 10, 2016 3:11 am
That is good news. I was... concerned on the 4 flights per day on such short flights.
Reliability needs work (LH expected 99.3%+ out of the gate). The climb fuel burn has beat promise, so I'm waiting to see the fuel burn on a route that 'stretches the legs' of the NEO. The plane has about 700nm more range than the CEO, but is doing very short routes.
The whole issue has been:
1. Reliability (99% isn't good enough) and
2. The added turn time.
Besides the already mentioned ground workers who would become 'ground chuck,' the rules require the doors during startup (I just realized, does this include the cargo doors, I do not know...). So this is serial time. For 9 flights that is an added 4 minutes per flight or 36 minutes per day...
The Highest utilization I know of is HA at 17 flights/day during busy season. That would be (6min-2min)*17=68 minutes, or a limited utilization for HA of 15 flights per day (more aircraft would have to be purchased). Now, every other airline will be less sensitive to this than HA, but for high frequency flights such as U2 or FR, it is the loss of one leg per day. That is one less leg of revenue.
Much to my surprise, this seems to be consistent with the C-series 1525G engines too (ish). A 4 minute start time per reports I've read.
But I note Pratt is quoting the per engine start times:
http://economictimes.indiatimes.com/...-williams/articleshow/52502052.cms
Customers have been pushing Pratt & Whitney to speed up the start time to 90 seconds from 180 seconds.
Now, it should be possible to initiate the start of the 2nd engine before the first is fully going.
CFM claims 50 seconds per engine:
https://www.flightglobal.com/news/articles/cfm-claims-50-second-start-up-time-for-a320neo-engin-421665/
What matters is if the added turn time results in one (or more) lost legs flown per day. For an 8 flight per day schedule, it is a lost leg. For Jetblue that tends to fly longer distances (but more hours per day), it would matter far less.
CFM is making a big deal of this as they do no want the fuel burn compared. So short flight airlines (typical in Europe) will probably favor the CFM LEAP-1A unless the fuel burn advantage of the PW1100G is enough to pay the difference. Long flight airlines (North America) will favor fuel burn. The LEAP-1A will not have the compressor fix until next year, so we're a year away from a comparison and then just a year away from PIP #1 for the Pratts... So I expect Pratt to have the advantage in fuel burn for a while (this is a Marathon, mind you...). CFM also has better design practices for maintenance, so high cycle airlines will probably also end up favoring the CFM LEAP-1A.
For the 'mid-market' (most airlines), it will be a toss up. Thus a competition.
Lightsaber
zkncj
Fri Jun 10, 2016 3:14 am
Quoting hongkongflyer (Reply 16):
Not really that much of an impact in an busy airport, start one during push-back then the other during taxi.
lightsaber
Fri Jun 10, 2016 4:28 am
I should note the latest A320NEO have exceptional reliability from Pratt:
http://www.bloomberg.com/news/articl...meets-benchmarks-for-airbus-planes
“I’m just going to state the facts … We’ve got three airlines in service, seven airplanes flying … without any flight shutdowns, no air turn-backs, no rejected takeoffs, at a dispatch reliability of 99.75%.”
It seems the software fix really helped.
Quoting zkncj (Reply 18):
Agreed. But for some reason your quote was another user for my post.    But it still is a substantial delay over a large number of legs. When it is 90 seconds per engine, it will be one on and the 2nd during taxi.
Lightsaber
chiad
Fri Jun 10, 2016 5:30 am
Quoting N1120A (Reply 7):
Quoting lightsaber (Reply 17):
Thanks guys. I know nothing about engines at all.
I just imagined them to be more like car engines that can be switched on and run in idle.
minister
Fri Jun 10, 2016 6:02 am
Word from IndiGo in India is that Fuel Burn is closer to ~16% over the CEO
The start-up time is also reported around the 6-7 minute mark
Utilisation is closer to 7 hours here. They have 4-5 NEOs which do very specific route sets out of DEL. Factor in the 40+ degrees C temperature, and you can wonder why it is lesser than LH
The bigger problem I believe with the GTF is that the engine doesn't start if winds exceed 10 knots. The aircraft has to be repositioned at a particular angle to compensate against the wind direction
The issue is that due to the bending of the main shaft, irregular gaps are created between the fan and the engine casing, this causes wind to bypass the fan (even though the gap is already very small) so the engine cannot generate enough thrust at start up in a high wind scenario. This is what I've understood of the issue, I'm sure a technical focused person may be able to explain this better!
WIederling
Fri Jun 10, 2016 6:52 am
Quoting minister (Reply 21):
That reasoning sounds a bit fishy/fantastic !?
For getting the core running tip losses on the fan should not be relevant at all?
Murphy is an optimist
starbucks
Fri Jun 10, 2016 6:57 am
I believe LH's 20% number is based on saving per seat, they've added a number of seats in their neo's compared to the ceo. (180 seats in neo, 168 seats in ceo)
For as far as I can see Indigo only has 180 seat configs, so their fuel saving is a direct comparison to a ceo.
//Edit: Eventhough I can't find it directly, I believe LH even spoke about a 25% cost reduction on the neo when they factored in some other cost saving measures introduced with the aircraft
[Edited 2016-06-09 23:59:34]
rheinwaldner
Still more than Airbus was saying in their Indigo delivery press release:
http://www.airbus.com/presscentre/pr...kes-delivery-of-its-first-a320neo/
The difference could come from what is exactly compared with the NEO. LHs oldest A320 might indeed burn 20% more fuel than the NEO. Indigos much younger CEOs on the other hand could already be 4% better than LHs CEOs, so they see only a 16% improvement...
Many things are difficult, all things are possible!
BobMUC
Fri Jun 10, 2016 7:15 am
Quoting starbucks (Reply 23):
Sorry in German but the article from February is quoting Carsten Spohr:
http://www.wiwo.de/unternehmen/diens...gen-billigkonkurrenz/12948404.html
- Savings per seat up to 25%
- After the first flights we are seeing savings up to 17%
(probably based on per flight and not on per seat)
starrymarkb
Fri Jun 10, 2016 7:51 am
That also applies to the IAE engine, so it's not a new thing.
KarelXWB
Fri Jun 10, 2016 7:53 am
Quoting BobMUC (Reply 25):
That's because the A320neo has 12 additional seats.
Block fuel burn is clearly above the promised 15%.
TC957
That's not surprising since the two LH frames are doing such short sectors, hardly need to fully use the take off thrust available.
As you say, once the 2000nm + flights start, we'll see better how climb fuel burn matches expectations.
Listening to them climbing out of FRA, they have a distinct low-revving hum to them more akin to washing machines than a jet engine.
TheSonntag
Fri Jun 10, 2016 8:07 am
How does the lower fuel burn affect the amount of fuel an airplane is having on board?
Lets say we have Standard metereological conditions in all of Europe, so no fancy alternate planning is required, and LH wants to fly FRA-HAM.
LH could use D-AIPA (A320 from 1988) or D-AINA.
Will D-AINA in such a case carry less fuel, or the exactly same amount of fuel? As I said, conditions are the same and the Pilot is the same, too  .
oly720man
Fri Jun 10, 2016 9:41 am
They have ventured further afield occasionally, to LHR
http://www.flightglobal.com/news/art...sa-a320neo-visits-heathrow-424138/
and to ARN
http://www.instagram.com/p/BFjWfhuHkwb/
minister
Fri Jun 10, 2016 10:15 am
Quoting WIederling (Reply 22):
I too was skeptical of the explanation when I first heard it. But I don't have any more knowledge to judge what the real problem is
Quoting rheinwaldner (Reply 24):
Ah, Thanks! Now I fully understand why IndiGo is fairly happy with the ~16%
douglasyxz
Fri Jun 10, 2016 8:35 pm
Wasn't the long start time only required when the engine was off for a certain time, IIRC something between one and two hours due to different cooling of different parts of the engine? Assuming short turnaround times of less than one hour, shouldn't the GTF be prepared to be started without requiring the windmilling?
tigerotor77w
Fri Jun 10, 2016 9:06 pm
Quoting FRAEDDF (Reply 14):
Quoting bgm (Reply 13):
 Wow!
Well don't I feel terrific now!
I looked up the registration and thought the date was close enough to the delivery date of an NEO that it would be an NEO. My assumption wasn't helped by both captains announcing that this was (at the time) the newest A320 in the fleet. (I didn't realize LH was still taking delivery of CEOs.) I did think it was strange that there was no painting on the side of the craft with the "first to fly the NEO" message, but I didn't put much thought into it. Now I know why...
Well thanks for the clarifications!
KarelXWB
Fri Jun 10, 2016 9:12 pm
Regarding the startup time, it is less worse than the media tries to sell.
A good read:
The GTF and start-up issues on the neo – Much Ado About Nothing?
rbrunner
Fri Jun 10, 2016 10:31 pm
Quoting KarelXWB (Reply 34):
I agree. Will the existing A320neos be upgraded or will they swap engines?
IFixPlanes
Sat Jun 11, 2016 7:20 am
To get rid of the longer startup time software update must be combinated with a change of hardware.
Hardware change could only be done in shop, so we have some engine changes in the near future.
never tell an engineer he is wrong ;-)
KarelXWB
Sat Jun 11, 2016 8:09 am
Quoting rbrunner (Reply 35):
A retrofit kit will be available.
Unflug
Sat Jun 11, 2016 10:43 am
Quoting douglasyxz (Reply 32):
Exactly, the longer start time only applies if the engine has not been running for some time - according to this source 2.5 hours:
http://aeroturbopower.blogspot.de/20...-business-model-threatened-by.html
On fast turnarounds this is no issue at all.
On slow turnarounds I don't see how it should matter...
seahawk
Sat Jun 11, 2016 11:12 am
350 seconds is a worst case scenario any way and the worst case time for a IAE V2500 is 160 seconds. So we are talking 3 minutes difference at most, even with the basic configuration. Now LEAP X is promising 50 seconds worst case. We will see how it goes.
