rj777
Air WI Leaving MKE; UA Mainline Coming?
Thu Jun 09, 2016 10:07 pm
I saw there was a thread before that Air Wisconsin was shutting down MKE, but now I can't find it. I saw that UA was bringing mainline aircraft in. I was going to ask when that was going to happen because I can't see anything on the UA website search.
jpetekyxmd80
RE: Air WI Leaving MKE; UA Mainline Coming?
Thu Jun 09, 2016 10:12 pm
DEN will be mainline come fall and ORD will be occasionally.
The Best Care in the Air, 1984-2009
ericm2031
Thu Jun 09, 2016 10:22 pm
Ground handling will be switching to United Ground Express
rj777
Thu Jun 09, 2016 10:24 pm
What will be the frequency? Will DEN be ALL mainline?
flyua
Thu Jun 09, 2016 10:25 pm
I see two mainline flights from MKE to DEN starting September 8th, and one mainline from MKE to ORD starting October 6th.
About time!
(Looks like DEN will have only those two mainlines from September 8th. ORD will still have plenty of Express.)
[Edited 2016-06-09 15:27:22]
N1120A
Thu Jun 09, 2016 10:41 pm
Air Wisconsin hasn't been a UAX carrier for about a decade now. Their role with UA has been doing UAX ground handling at certain stations, most (in)famously IAD.
CHI787ORD
Thu Jun 09, 2016 10:48 pm
A mainline flight between MKE and ORD has to be one of the shortest mainline flights in the U.S. correct?
FWAERJ
Fri Jun 10, 2016 12:52 am
Quoting N1120A (Reply 5):
ZW also handled SBN for years, but SBN is in the process of switching to United Ground Express.
FWA was once a ZW ground station as well, dating back even before the formation of the United Express network. Then FWA went to OO for a while, and has been with DGS for the past few years (to the point where DL and UA even share a bagroom and crew lounge at FWA).
[Edited 2016-06-09 17:53:35]
B721/722/731/732/733/735/73G/738/739/742/752/753/762/763, A300/319/320, DC-9/10, MD-82/83/88/90, ERJ-140/145, CRJ-200/700, Q200, SF340, AS350
mke717spotter
Fri Jun 10, 2016 3:02 am
Quoting rj777 (Thread starter):
Air Wisconsin Closing MKE Base (by mke717spotter Jun 6 2016 in Civil Aviation)
Quoting CHI787ORD (Reply 6):
Its a surprising upgrade to be sure, but UA also has mainline on ORD-MSN. Some of the ORD-MKE flights have also been upgraded to CR7, albeit there will now be less frequency.
N1120A
Fri Jun 10, 2016 9:47 am
Quoting mke717spotter (Reply 8):
They've been moving to a higher capacity, lower frequency model for a while.
Tan Flyr
Fri Jun 10, 2016 1:03 pm
[quote=CHI787ORD,reply=6]A mainline flight between MKE and ORD has to be one of the shortest mainline flights in the U.S. correct?[/quote
Currently, probably one of the shortest. this has been covered a few times before..a few quick examples come ti mind from years ago when some routes were CAB controlled. UA had a flight from SFO-OAK, about 12 miles or so. another old California route of short distance was VIS- BFL, about 65 miles..also UA in the 70's.
there were a number of international tag -on years ago such as BWI-PHL on TW as I recall..
Do a search and you'll discover more about it.
usxguy
Fri Jun 10, 2016 1:38 pm
I thought I read that Air Wisky is only closing the maintenance base in MKE.... is there more to the equation? Are they still based up in ATW?
xx
atwinstructor
Fri Jun 10, 2016 2:03 pm
Quoting usxguy (Reply 11):
The maintenance base is not going anywhere, this is in relation to the United ground handling. HQ is still in ATW.
n7371f
Mon Jun 13, 2016 11:37 pm
Yes. Back in the late 80's, even into the mid-90's, UA flew mainline into MKE out of ORD. And, believe it or not, a DC-10 depending on the schedule.
I flew a D13, 73A, 727, 72A over the years on that route.
