flymco753 wrote:I just learned about this in my Regulations class. When a passenger is removed from a flight involuntarily due to an oversell or whatever reason like that the passenger should be compensated. Is there an exact regulation for this?
jetmatt777 wrote:flymco753 wrote:I just learned about this in my Regulations class. When a passenger is removed from a flight involuntarily due to an oversell or whatever reason like that the passenger should be compensated. Is there an exact regulation for this?
If it's the airlines fault compensation is required (oversell, aircraft weight purposes, aircraft performance etc). I believe the OP is referring to situations in which the customers was no longer allowed on board. This could be a myriad of reasons (physical threat or altercation, security threat, visible health concerns (drunk, mental episode causing a physical threat, passing out, etc.). How the airline handles that is case by case.
