Osiris
1 hour 40 mins to connect at ORD (DEN - LHR)...
Sat Jul 01, 2017 6:40 pm
It looks even worse now I've written it down! Is this too tight of a time to connect at ORD on my way back to LHR?
Flying with AA if that makes any difference.
fbgdavidson
Re: 1 hour 40 mins to connect at ORD (DEN - LHR)...
Sat Jul 01, 2017 7:43 pm
Should be plenty of time, assuming everything is on time. AA's terminal at ORD is pretty large but it is well laid out. FWIW, I've made connections at ORD of as little as 35mins and bags made it!
11725Flyer
Sat Jul 01, 2017 8:29 pm
You should be fine. I'm flying through ORD in two weeks with an hour and a half layover. I would get nervous with anything less than an hour.
ChrisKen
Sat Jul 01, 2017 8:50 pm
If it was sold as a through ticket then it's AA's problem anyway so I wouldn't worry if you do miss it.
ASQ400
Sat Jul 01, 2017 8:53 pm
Should be fine with 1h40. You would stay in the same terminal for the whole time
TLV, BRU, ZRH, CDG, FRA, EWR, JFK, DEN, SFO, AUS, RNO, SEA, YYC, YYZ, IAH, ATL, IAD, DCA, ORD, SJC, SNA
BENAir01
Sat Jul 01, 2017 9:45 pm
Yeah you'll have absolutely no issue
Why is flying so expensive? And why is flying well so much more?
Osiris
Sun Jul 02, 2017 8:17 am
Oh ok - that seems pretty unilateral then :lol: Thought it'd be tight for some reason!
Cheers guys.
cskok8
Sun Jul 02, 2017 11:23 am
If you are connecting from domestic to international, there is no security and immigration to clear at ORD. Won't work in the other direction (LHR-ORD-DEN)
DDR
Sun Jul 02, 2017 5:59 pm
Your only problem will be if flow control is in effect and you have a wheels up time more than 40 minutes after your scheduled departure time.
Users browsing this forum: Miguel1982 and 35 guests
