EthanMcLean
Is it possible to see which aircraft will operate my flight?
Wed Oct 11, 2017 11:00 am
Hi,
I want to know if there is any way to find out which specific registration a/c will be operating my flight: BA253. I would imgine BA don't make this public but i just want to check as this route is commonly operated with a 777-200 which all have old economy. and occasionally operated with G-VII series aircraft.
george77300
Re: Is it possible to see which aircraft will operate my flight?
Wed Oct 11, 2017 11:54 am
You can see on the BA database if you have access but the odds of changing is incredibly high. However a few days ahead you can sometimes see on sites such as Flightradar24. BA 253 is usually G-YMM? fleet though.
A306 A313 A319 A320 A321 A332 A333 A343 A345 A346 A388
B712 B733 B734 B735 B738 B742 B744 B752 B763 B772 B77E B773 B77W B788
AT75 AT76 B190 C208 DH3T P46T SF34 SR20 SR22 TBM8
BA EI EK EY FR GT H3 IG JQ KX PG PW QF QR SQ TG TP UA U2 VK VS WS WY ZB 8P
gunnerman
Wed Oct 11, 2017 12:24 pm
The LHR-NAS-GCM route is operated with the 275-seat 777-200ER (48 Club World, 24 World Traveller Plus, 203 World Traveller). Previous aircraft used include G-YMMC, G-YMME, G-YMMU and G-YMMT.
Gonzalo
Wed Oct 11, 2017 12:30 pm
Hi, don’t know if you can do the same with BA, but when I fly I usually check on FR the flight coming to my departure airport and see the reg there. For example, when my flight number is 323, searching the flight 322 shows the aircraft that I will board later.
Good luck anyway, and smooth landings.
Rgds.
G
Gear Up!!: DC-3 / EMB-110 / Fairchild-227 / Ab318-19-20-21 / B732 / B763 / B789
EthanMcLean
Wed Oct 11, 2017 3:46 pm
Rgds.
G
Yeah, I always do that, and will do a day in advance by looking at 772's that land about an hour before. But this could always change due to aircraft being pulled out of maintenance or a last minute swap.
ChrisKen
Wed Oct 11, 2017 10:19 pm
G
Fine at a limited service outstation (ie if he was in NAS or GCM awaiting his rtn leg) but all but useless at the home hub as the aircraft rotate through maintenance and other destinations
@Ethan
BA usually use the 275 seat 3 class CW/WT+/WT (G-YMM*) fleet on this route afaik.
You'll maybe pick up a reg# on FR a few hours beforehand but I'm guessing you'll be on the flight regardless of aircraft anyway so not worth fretting over.
VapourTrails
Thu Oct 12, 2017 12:59 am
Yes, I also check FR24 a few hours before, but it is subject to change occasionally too. If I am at the airport I check the Gate number for the incoming flight that is my Gate number for departure, then I can track the incoming flight with the detail like tail number.
Users browsing this forum: classicjets and 5 guests
